[Solved] VP44 Injection Timing Solenoid Valve Issue - Engine Power Loss Post 2-3 Minutes Start-up
TOMEKELE 27774 15
Why does my VP44 pump lose power and throw fault 00550 about 2–3 minutes after startup, and is the injection timing solenoid valve the likely cause?
The most likely cause is a sticking injection-angle adjuster piston/valve in the VP44 pump, not just a simple wiring fault; on these pumps the fault can appear after warm-up as the mechanism expands and begins to seize [#16812896][#17737615] Check the lower adjuster valve and its cracked cables carefully, because its resistance should be about 10 ohms and the current draw is roughly 1.2 A when powered, and voltage checks alone may miss an intermittent short or control problem [#17589406][#16810003] One suggested test was to unplug the coolant temperature sensor, because a bad temp signal or an added resistor can alter injection control and sometimes improve or worsen the symptoms [#16810584][#16822432] If you want to verify the valve itself, measuring current with a clamp and oscilloscope is more useful than only measuring voltage [#16808559][#16810003] In the thread, the final fix was replacing the pump with a used one and transferring the controller, after which normal operation returned, confirming the adjuster piston was sticking mechanically [#17737615]
  • #1 16807220
    TOMEKELE
    Rate: 40
    I think I have a problem with the injection timing solenoid valve in the VP44 memory
    After starting the engine, everything is ok for 2-3 minutes.
    After this time, an error appears:
    00550 - Adjustment of the injection start angle
    08-10 - Regulation limit exceeded - Occasional
    as you can see below, in the attached picture in the green frame after these 2-3 minutes. appear: 0.0 PGMP, engine loses power - works unevenly.
    Now I have a question, can it really be this: "injection solenoid valve"?
    I will add that the insulation from the cables from this valve has crumbled. So I put on a cable T-shirt.
    But the problem remained.
    Everything is ok for 2-3 minutes after starting the engine.
    If this valve were damaged, then there should be some error in the diagnostic program?
    I would like to ask for a tip what else could be the reason?
    Thank you in advance for your response. greetings
    Daro122
    Help: 165
    Rate: 751
    I had a long time ago damage to the controller in the circuit of this solenoid - irreparable, for me there was no control. Check if you have any control during the fault measuring current or oscilloscope would be useful.
    emeryt2
    Help: 717
    Rate: 2302
    Is the fault always there or after starting a cold engine?
  • #4 16809131
    TOMEKELE
    Rate: 40
    Always after starting. I haven't heated the engine since the problem appeared, because as I wrote after 2 minutes. he shakes and lightly kicks.
    another error occurred yesterday:
    17-00 regulation difference.
    Today :
    Still the same .
    17-10 - Regulation difference - Occasional
    At the suggestion of Pensioner 2 I warmed up the engine.
    At the suggestion of Daro122, at idle I measured the voltage on the sensor wires - 3.5 v -. There are slight deviations of 0.1 V.
    Tomorrow I will measure the voltage at high engine speed when the engine is running well.
    Here is a curiosity:
    I wonder what could be the reason? Maybe tomorrow will solve the puzzle.
    And can this be the cause of crazy engine? What do you think?.
    Daro122
    Help: 165
    Rate: 751
    Most likely it will be when you replace the solenoid valve - it can get short-circuited, voltage measurement does not contribute much. It's better as we measure current consumption, but here you need a tick and an oscilloscope.
  • #6 16810097
    TOMEKELE
    Rate: 40
    I am also of the same opinion as you. I will combine some reliable valve.
    Opalony
    Help: 8
    Rate: 48
    Unclip this coolant temperature sensor and see how it goes.
    He should walk with the emergency dose, with the error of this sensor and turn on the cooling fans.
    Well, unless the diagnostic program distorts, but I doubt it. If he will give too much injection because he will think it is 16 degrees and he will not catch the error of the temperature sensor, he may drop it on the valve that he can't.
  • Bypassed airflow meter and removed fake temperature resistor
    #8 16811991
    TOMEKELE
    Rate: 40
    The adventure continues, it gets interesting:
    After disconnecting this sensor, something improved there, not much, but always something. (Strangely not entered into safe mode)
    I decided to disconnect the flow meter. But after thinking, I thought to completely remove the intake pipe from the flow and completely bypass it.
    Well, something shook here :) 70% improvement.
    Well, I decided to adjust the injection accounts.
    it was like that :
    I did this:
    today, as always, will be a curiosity:
    do you remember the curiosity from post # 4 And this cheated temperature?
    Someone put in a resistor to deceive the computer. (maybe to give a larger dose of fuel ?? maybe a couple of horses ...)
    I dropped the resistor and connected the connector to the sensor. The temperature appeared correct. I put everything together, and it's amazingly pretty good. Maybe today I'll take a test drive.
    Returning to this problem with the injection timing solenoid valve, it does not always run smoothly. It is true that it does not hang at zero now as it was before.
    Here it is almost as it should:
    However, it will not always drive to be "too early" e.g. 16.2 PGMP. Sometimes it stands at 0.0 or 6.2 etc. and slowly goes to 16.2 PGMP - But it is sporadic and when it will stand idle for a few minutes. Generally, you can drive a car. (not too far from home ;) )
    Mechanical seizure of the control valve suspected
    #9 16812896
    Opalony
    Help: 8
    Rate: 48
    Maybe try to remove the adaptations, but from what I remember these pumps were emergency.
    And there were probably two types in relation to power, but I'm not sure here. Now, such a topic rarely comes to the workshop.
    As for the resistor, you know when the problem is? Did it travel and fall with this resistance, or did it fall after adding a resistor. (The resistor could be installed so that the glow plugs would heat up at start-up even when it was warm, to bypass the firing problem, if there was one).
    I had such cases with the engine finished and I put on the resistor and relay so that before firing it would see below zero, and then how it lit normally, which helped (But in the case of these engines I did not happen).
    And one more thing that could indicate a damaged valve, but mechanical.
    3 minutes of work = warming up the pump mechanisms, which causes the material to expand, which indicates mechanical seizure of the control valve (and this happened in these models).
    I used to make a circuit on a transistor, which I controlled the valve myself while the engine was running, looking at that time to maintain its operation and injection advance parameters, which helped me determine the mechanical seizure of the valve.
    However, I did not replace the valve itself because the customer brought a used pump and after replacing and setting the problem the problem disappeared.
  • Intermittent VP44 pump timing control fault at 2500 rpm
    #10 16812989
    TOMEKELE
    Rate: 40
    Toy car for a year. Fortunately, it's a mushroom car, etc. so I care about it on average.
    But it would be good to drive.
    This failure is the first to date. What was earlier I do not know. I did nothing with him. And the resistor was apparently when I bought it.
    Today, I also found that this is a problem with the pump. Sometimes it goes like crazy and sometimes an error jumps:
    My guess is that this piston (or valve) cannot change the start of the injection.
    Now, after all these treatments, it may have happened twice.
    We'll see what comes next.
    I'm just surprised by one thing:
    why when I hold the engine evenly at 2500 rpm (the engine works well).
    in the diagnostic program (in the green frame - screenshot below) they will appear for about 2 seconds. 0.0. (Now it appears sporadically)
    then an error appears:
    . After 2 seconds, the engine continues to work well.
    So if I keep the engine even at 2500 rpm (the driver will accelerate and the solenoid valve will overtake (the start of injection and everything works stably) why the controller or this valve (piston) would change the advance accounts for these 2 seconds to 0.0 ?? and after 2 seconds return to normal, and work well
  • Resistor alters injection timing and improves throttle response
    #11 16822432
    TOMEKELE
    Rate: 40
    Tanned thanks for the suggestion. This resistor mixes a little in this engine.
    This morning temp. motor shown with a resistor is -2 degrees and it was +9 (without +9 resistor)
    The resistor actually affects the injection account control (screenshot below):
    Below is a view with a connected resistor. (temp deceived by the resistor + 16 degrees, in fact the motor is heated over + 85 degrees)
    And here without a resistor. (engine temperature + 85 degrees)
    As you can see above, the computer (or this driver there) sets the injection accounts quite differently.
    For now I leave this resistor. Somehow the engine reacts better to the accelerator. (fires well with and without a resistor)
    And as for this "injection solenoid valve" I dare say that it is in working order. Because I cut it off from the controller, the valve closed and the injection accounts changed (accelerated to the max.). The engine began to run like a "tractor". When I connected the valve back to the controller, the controller controlled the pump as it should. After several such tests, always after unplugging the injection account valve accelerated to max. and after connecting to the controller everything stabilized.
    In my opinion, sometimes there is some lack of communication between a computer, controller or a sensor. Or the computer is missing something. If there is a moment, I will look into it, whether it is not flooded or something.
    This piston of the adjuster, after all, had to be checked in the near future whether everything was ok with him
    We'll see what comes next ..
    emeryt2
    Help: 717
    Rate: 2302
    Throw away this resistor or put a circuit breaker on it. As you light up, turn on the resistor, turn it on after turning it on (short-circuit the switch), in the long run you will burn the piston crown, the resistor was installed to turn on the glow plugs.
    You're right, controlling the injection angle to work. Still a question; what is your compression on garach ????
  • Resistor eliminates low-rpm injection timing lag
    #13 16822731
    TOMEKELE
    Rate: 40
    With this resistor I did exactly as you write pensioner2.
    I don't know why yet, but without a resistor, the motor starts to collect well after about 2,200 rpm.
    Up to approximately 2,200 rpm has a light "binge". I can see in the measuring blocks that the computer (or this driver - I don't know anymore) holds as if delayed injection accounts. After exceeding about 2,200 rpm it is only pushing ahead of the account. And everything is ok.
    While the resistor is inserted everything works smoothly, from idle to say max. (I don't push for episodes)
    Oddly, it no longer crashes (no errors)
    I will deal with pressure measurement in the nearest free time. As well as a review of the electrical installation. Probably not one more jumper or resistor.
    Opalony
    Help: 8
    Rate: 48
    As you did the mechanical adjustment of the advance angle on the resistor, now do it again without it.
    naprawa-pomp.com
    Rate: 143
    The lower valve from the injection angle adjustment should first be checked with a meter. Its resistance should be around 10 Ohm plus minus some tenths of a part. Regardless of the pump, vp44 or vp30, the cables from the bottom valve are usually cracked. For any repairs related to this pump, I recommend always correcting the cables from this lower injection angle adjuster valve. The current that the valve draws when connected directly to a 12v power supply or the battery is ohm's right about 1.2 amps and decreases over time. That is, the longer the valve is connected, the smaller the current begins to flow through it, because the valve heats up and its resistance increases. I do not remember too much that a short circuit on these cracked lower cables damaged my controller. After shorting these cables, the voltage on the wires disappears to zero and appears after removing the voltage from the controller and re-feeding it. Indeed, if somehow it was damaged by some miracle, controlling this valve is impossible to repair, because this valve is controlled directly from the controller motherboard by a seven-leg element of unknown specification marked on the added picture borrowed from another topic by a green square VP44 Injection Timing Solenoid Valve Issue - Engine Power Loss Post 2-3 Minutes Start-up
    PUH OMEGA
    brzozowa 57, Ożarów, 27-530 | Tel.: +48XXXXXXXXX (Show) | Company Website: puhomega.pl
  • #16 17737615
    TOMEKELE
    Rate: 40
    I reviewed the entire electrical installation, removed the resistors, etc. However, there was still no satisfactory effect.
    I bought a used pump, translated the driver from the old one, installed it in the car and then everything returned to normal.
    The year is now flashing and everything is ok. However, it was the piston from the ignition accelerator that was getting stuck.
    Thank you for the advice and hints.
    I learned a lot about these pumps ...
    Subject to close.
The discussion revolves around a VP44 injection timing solenoid valve issue causing engine power loss after 2-3 minutes of operation. The user reports an error code 00550 related to the injection start angle adjustment, leading to uneven engine performance. Various suggestions are made, including checking the solenoid valve for damage, measuring current and voltage, and inspecting the coolant temperature sensor. The user experiences intermittent improvements after disconnecting certain sensors and adjusting the injection settings. Ultimately, the user resolves the issue by replacing the pump and driver, indicating that the piston from the ignition accelerator was stuck. The discussion highlights the importance of electrical integrity and proper diagnostics in addressing injection system failures.
TL;DR: VP44 engines that lose power after 2–3 minutes often point to the timing (angle) solenoid: typical ~10 Ω; “Its resistance should be around 10 Ohm.” [Elektroda, naprawa-pomp.com, post #17589406]
Why it matters: This FAQ helps DIY diesel owners quickly confirm a VP44 timing-solenoid vs. wiring or pump-mechanical fault so they can plan an effective fix.
What does DTC 00550 mean on a VP44 and why does power drop?
00550 flags “Adjustment of the injection start angle.” The ECU detects a mismatch between requested and actual advance. When the solenoid or advance mechanism can’t reach target, the ECU limits fuel and timing, causing rough idle or power loss after a short run. The OP logged 00550 with “regulation limit exceeded/difference” right as the stumble begins. [Elektroda, TOMEKELE, post #16807220]
How do I bench-test the VP44 timing solenoid quickly?
Unplug the lower timing-solenoid and measure resistance across its pins. Expect about 10 Ω. Briefly power it from a fused 12 V source; initial draw is around 1.2 A, then it declines as the coil warms. “Its resistance should be around 10 Ohm.” If readings are far off, the coil is suspect. [Elektroda, naprawa-pomp.com, post #17589406]
Can cracked wiring to the lower valve really cause 00550?
Yes. The lower-valve leads often crack near the pump body. Shorts or opens interrupt control, momentarily dropping advance to zero and logging 00550. Repair the loom and strain relief first. After a short, voltage to the valve can drop to zero until the controller is power-cycled. [Elektroda, naprawa-pomp.com, post #17589406]
Why does the fault appear 2–3 minutes after start, not immediately?
Warm-up expands pump internals. If the advance piston/valve is scuffing, it can seize as metal heats, so commanded advance isn’t reached and 00550 appears. This timing aligns with a mechanical stick rather than a cold electrical issue. [Elektroda, Opalony, post #16812896]
Is the ECU/pump controller a known failure point for the timing valve?
It can fail, and when it does, control of the timing solenoid is lost and not repairable at component level. The driver is a seven-leg device on the VP44 ECU board; once damaged, angle control is gone. Use current/oscilloscope checks before condemning it. [Elektroda, naprawa-pomp.com, post #17589406]
How did the original poster finally fix the issue?
After rewiring and removing add‑on resistors, the user installed another pump and moved the original ECU onto it. The problem disappeared and stayed fixed for a year. Diagnosis: the ignition-advance piston was sticking mechanically. [Elektroda, TOMEKELE, post #17737615]
Could a coolant temperature sensor or a resistor mod trigger 00550?
Yes. A spoofed or faulty coolant signal alters warm‑up timing and fueling. The thread shows a series resistor faking lower temperature, which changed advance behavior and drivability. Restoring proper CTS input stabilized control. Avoid permanent “cold” spoofing. [Elektroda, TOMEKELE, post #16822432]
Is it safe to leave a ‘cold-start’ resistor installed for smoother running?
No. Use it only for brief starting aid via a switch, then disable it. Continuous enrichment and extra advance risk overheating and piston crown damage under load. “In the long run you will burn the piston crown.” [Elektroda, emeryt2, post #16822607]
Why did unplugging the MAF/intake tube seem to improve things?
Changing air metering can mask timing faults by shifting requested fueling and advance. In the thread, bypassing the MAF improved response ~70%, but the underlying timing control still misbehaved. Treat it as a diagnostic clue, not a fix. [Elektroda, TOMEKELE, post #16811991]
How do I verify the solenoid actually moves timing on the car?
Unplug the timing-solenoid with the engine idling. Advance should jump to maximum mechanical, and the engine will run like a rough tractor. Reconnect and observe stabilization. This confirms the valve responds and the ECU can command it. [Elektroda, TOMEKELE, post #16822432]
What’s the quick 3‑step plan to isolate electrical vs. mechanical VP44 timing faults?
  1. Repair/loom the lower-valve wiring; measure coil ≈10 Ω. 2. Log timing requested vs. actual around the 3‑minute mark. 3. If wiring/coil pass but advance drops to zero warm, suspect a sticking piston/replace pump. [Elektroda, naprawa-pomp.com, post #17589406]
Why did timing briefly drop to 0.0 at steady 2,500 rpm?
Intermittent control loss from wiring or a sticking advance piston can momentarily force the ECU to zero advance, set 00550, then recover. The OP observed 0.0 for ~2 seconds at steady speed before normal operation resumed. [Elektroda, TOMEKELE, post #16812989]
Should I redo mechanical advance settings after removing a resistor mod?
Yes. If you adjusted timing with a spoofed temperature, repeat the mechanical setting with correct CTS input. Otherwise, your baseline advance will be wrong once the spoof is removed. [Elektroda, Opalony, post #16876565]
Does measuring voltage on the valve help, or should I measure current?
Voltage alone can mislead. Current draw shows coil loading and ECU drive health. Use a clamp meter and oscilloscope to see commanded duty and current shape when the fault occurs. Loss of control indicates valve, wiring, or driver issues. [Elektroda, Daro122, post #16810003]
What is the VP44 timing (injection angle) solenoid in this context?
It’s the lower valve on the VP44 that the ECU drives to advance or retard injection timing. It measures about 10 Ω, connects via two often‑cracked wires, and is directly driven by the pump controller’s power stage. [Elektroda, naprawa-pomp.com, post #17589406]
