Connecting LASKOMEX LM-8W Intercom: Matching 6 Wall Wires to Handset
ebul 27558 9
How do I connect a LASKOMEX LM-8W intercom when 6 wires come out of the wall but the handset has only + and - terminals?
Connect only the two wall wires that measure a constant voltage of about 7 V to the intercom’s + and - terminals, and keep the polarity correct. The green/white/red wires from the handset are not part of this wall connection [#11331313][#11332029] The thread also notes that this is a digital two-wire Laskomex system, so the apartment-side wiring should go only to those two terminals; the jumper shown on the handset is for the apartment number setting [#11331753]
  • #1 11331255
    ebul
    I am looking for help in connecting the LASKOMEX LM-8W intercom. I lived in an apartment where the intercom worked - after renovation it was dismantled (I didn`t note which one...) 6 wires come out of the wall:
    1. BLUE
    2. BEIGE
    3. ORANGE
    4. BROWN
    5. GREEN
    6. GRAY
    There are three wires coming out of the handset to the intercom - GREEN, WHITE, RED
    Everything would be OK if it weren`t for the fact that only two screws marked + and - are visible in the intercom...... no more connections and there are as many as 6 wires!! Please Connecting LASKOMEX LM-8W Intercom: Matching 6 Wall Wires to Handset for a hint.
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    Check, preferably with a meter, which wires have a constant voltage of approximately 7V.
    Regards
    www.alfatech.net.pl
  • #3 11331753
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    I guess you bought the wrong uniphone. The one you show in the photo is for two-wire digital installations. The installed jumper shows that it is currently set to apartment number 4.
    There is probably a 6-wire analog system in your block, because you write that the old uniphone worked, but you did not write down where it was connected. At least remember if all the cables were connected?
    This is irrelevant. This connection is not interfered with.
  • #4 11331837
    ebul
    The control panel system is the CD 2502 N system from Laskomex - the uniphone I have was already working - but the memory of the number of connected wires is volatile... - tomorrow I will try with a meter... "Experts" from the administration said that the uniphone was broken - and they paid PLN 80.. . hahaha ... but that`s just a side note...
  • #5 11332029
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Well, it`s actually a digital system. Do as Ircys wrote. Find two wires with voltage and connect them maintaining the correct polarity.
  • #6 11341860
  • #7 11345629
    relisys-js
    Rate: 11
    So what do you think? Will someone come and install a new uniphone for you, connect it and charge you PLN 40 for the whole thing? or maybe 35? 80 is still quite decent. I also had such "clients" often, and in 70% of cases they called again. Regards.
  • #8 11348105
  • Defending paid intercom installation and troubleshooting services
    #9 11352157
    relisys-js
    Rate: 11
    Well, if there were no anti-electronic people, what would be the need for conservation? Somehow, people still have problems - they call - they pay. Secondly, read what I wrote: PURCHASE, INSTALLATION, CHECKING, CONNECTING. What else can I deliver to someone else by bike? A multimeter for every intercom owner? He will probably go and buy it. The intercom is not working and what is anyone looking for the user manual for this intercom? Probably yes, even if the woman or man is 40-50 years old... I won`t mention that younger people are not more knowledgeable... Unfortunately, nothing is for free, and I value my time because of knowledge, as my colleague wrote earlier that in In this case, you don`t need much.
  • Uniphone polarity reversal is safe; installer code remains readable
    #10 11358372
The discussion revolves around connecting the LASKOMEX LM-8W intercom after a renovation, where the user is faced with six wall wires (blue, beige, orange, brown, green, gray) and three wires from the handset (green, white, red). The intercom has only two visible screws marked + and -. Responses suggest using a multimeter to identify which wall wires carry a constant voltage of approximately 7V, indicating a digital system setup. Users emphasize the importance of maintaining correct polarity when connecting the wires and mention that the intercom is part of a CD 2502 N system from Laskomex. There are discussions about the cost of new uniphones and the challenges of installation and troubleshooting.
