Testing Connection of Single-family House Installation to 3-phase RCD with One Phase Input
15525 5
  • #1 11342638
    fuutro
    Help: 1450
    Rate: 837
    A single- and three-phase differential tester examines the balance of currents in the circuit; there may be no power phase or two, or they may all be the same.
  • #3 11342780
  • #4 11342781
    kkas12
    Help: 1076
    Rate: 4312
    What is the point of such a "research"?
    An RCD switch "powered" in this way may not respond to the use of the TEST button.
    Here it is advisable to measure the insulation resistance and check the continuity of the protective conductors.
    When the results are positive, you can specify the target voltage and perform other tests.
    There is no doubt that this examination can be carried out by a person with appropriate qualifications.
  • #5 11342794
    retrofood
    Help: 1140
    Rate: 4797
    voytaschec wrote:
    Now I'm wondering whether before taking measurements and connecting the installation to the network, test it "hot", i.e. connect electricity from the neighbor to the fuses.
    Sure, and the best way to check a grenade is to throw it into a fire...
    What's the idea of checking "hot" instead of checking and measuring first?
    The logic of mentally fit people seems to be expanding differently...
  • #6 11342827
