Three-Phase RCD in Single-Phase Circuits: Standards, Acceptability & Whole Apartment Use
TWK 26199 26
Can a three-phase RCD be used for single-phase apartment circuits, and can this be challenged during installation acceptance?
A three-phase RCD can be used on single-phase circuits, and the thread says there is no clear legal or standards-based ban that would by itself justify rejecting the installation at acceptance if it matches the approved design [#11878865][#11881507] However, several replies stress that this is poor technical practice: one RCD for the whole apartment makes fault-finding difficult, can shut off all circuits including lighting, and increases the risk of nuisance tripping from summed leakage currents [#11880699][#11879256] One poster cites the standard rule that the installation should be divided into circuits to reduce the chance of RCD malfunction, and another points to selectivity requirements [#11881371][#11881673] So the main objection is technical quality and functionality, not a clear prohibition in the regulations [#11879113][#11881507] In practice, the suggested route is to persuade the designer/contractor to split the protection into separate RCDs, especially for a new build [#11880838][#11881371]
  • #1 11878668
    TWK
    Electrician specialist
    Help: 220
    Rate: 510
    Is there any provision in the standards regarding the non-use of three-phase RCDs in single-phase circuits? Is it possible to question the solution with one 3-phase circuit breaker for the whole apartment when accepting the installation?
  • #2 11878865
    tehaceole
    Help: 102
    Rate: 212
    There is a provision that the RCD should be used for all socket circuits operated by unqualified persons (the famous "belongs" and "should", the importance of which is given by our legislator on an equal footing ...). Unfortunately, it is not clear what type of highly sensitive RCD should be used. Therefore, the installation cannot be questioned, especially if it is made in accordance with the design. And designers often place a three-phase RCD as a "panacea" and a compromise between duty and cost.
    ST - SYSTEM
    Maszkowo 24 B, Maszkowo, 75-558 | Company Website: www.stsystem.pl
  • #3 11879113
    TWK
    Help: 220
    Rate: 510
    Installation made in accordance with the design may be questioned if the design is not performed in accordance with the regulations and standards. The matter is then to be clarified between the contractor and the designer, but the investor should expect compliance with the regulations and standards.
    Does anyone have any idea to enforce the use of single-phase RCDs in a newly constructed building, or is it impossible?
  • #4 11879256
  • #5 11880075
    kosmos99
    Help: 338
    Rate: 820
    This is what I have in the project and the designer replied to my question that the installation was designed in accordance with applicable standards.
  • #6 11880569
  • #7 11880699
    retrofood
    Help: 1140
    Rate: 4797
    This solution makes it impossible to narrow down the area of searching for a random fault in the installation. This is against technical knowledge, but unfortunately it does not violate the law.
    I advise you to change the designer, because it's just a cloud.
  • #8 11880838
    O^O
    Help: 34
    Rate: 48
    The advice is especially valuable, if addressed to the contractor or (even better) subcontractors ...
    If the investor is also a later resident, you can go to him. Arguments about savings of several hundred zlotys, at the cost of possible losses of several thousand, often reach the imagination.
    It is worse if the investor is a developer who intends to build as cheaply as possible and sell as expensive as possible. Then there is no strength. And no one will convince him with any technical knowledge or potential losses for the inhabitants, because what is not forbidden is allowed.
    Whoever worked for such people knows what we are talking about.
  • #9 11880853
    retrofood
    Help: 1140
    Rate: 4797
    Unfortunately...
  • #10 11881180
  • #11 11881371
  • #12 11881388
    kosmos99
    Help: 338
    Rate: 820
    The project already bought so mustard after dinner.
  • #13 11881430
  • #14 11881507
    TWK
    Help: 220
    Rate: 510
    All the disadvantages of using the RCD 3-f instead of the 3x RCD 1-f mentioned in this thread are known to me. Nevertheless, thank you for submitting them. Collecting them in one place may have an educational value for the future.
    As for the reasons for the question. Of course, when I do something, I take into account the functionality and reliability of the installation. But in this case, my role is slightly different: I was asked to participate in the acceptance of the apartment from the developer. For now, the building is a construction site and there is no power to the premises, but I went to inspect it. One of the comments I have is the 3-f RCD for the 1-f circuits. Unfortunately, I cannot do anything in this matter, because there is no basis for it in standards or regulations. But I am going to stick to other issues, such as the colors of the wires, and I will also verify the selectivity of the protection. I'll see what else comes out after applying the voltage.
  • #15 11881529
    kkas12
    Help: 1076
    Rate: 4312
    Why don't you do anything?
    It should all be described.
    Note that one RCD has the characteristics of protection against electric shock, but such a solution contradicts the principles of technical knowledge and significantly reduces the functionality of the installation.
    And present possible scenarios of a potential failure.
  • #16 11881628
    TWK
    Help: 220
    Rate: 510
    kkas12 wrote:
    Why can't you do anything?
    I will act, but I do not suspect that it will bring any effects ...
  • #17 11881673
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    You can write papers about the selection of residual current devices, but this is probably not the point here, because every designer should be familiar with the issue taking into account the balance of the determined leakage currents in the protected circuit, taking into account the principles of technical knowledge or possible potential failure scenarios mentioned by Kkas12.
    As I think, we agree that it is not appropriate to have one RCD protects the entire receiving installation, because excessive residual current in any receiving circuit causes the RCD to trip and deprives all circuits, including lighting, and poses a danger to users, which apparently does not appeal to to the designer for whom the investor-developer costs are the most important ...
    In the case of using a 4-pole (not 3-phase) RCD in 3 single-phase circuits supplied from different phases, the highest value of the current in the PE conductor should be expected
    when switching on one or two circuits, and not all three, and when designing more complex installations, one should not forget about the possible situations when, in addition to active currents, currents of a capacitive nature appear - the known problem of "incandescent" LED lamps or the measured voltage in the cable / circuit switched off :)
    In fact - since the designer focused on saving - he used a residual current circuit breaker with a current of Ia = 30mA as the main switch of the switchgear and stated that everything complies with the standards and regulations, refer to
    § 183. 1. In electrical installations, the following should be used:
    5- the principle of selectivity of security
    This provision is de facto included in all protections - also residual current devices, not only overcurrent ...
  • #18 11883373
  • #19 11886204
    Zloty60
    Help: 14
    Rate: 69
    At a neighbor's new house, an electrician (a licensed company) performed the entire electrical installation, in the design scheme there were 3 RDC-1 phase for individual circuits and 1 RCD-3 phase for "force" in the garage.
    I was looking at the progress of the work. It was time to connect devices in the switchgear (the price for making the installation in the building along with the receipt, protocol, etc., was agreed earlier), and what I see, "es" as for a medicine probably with 5 pieces (including 16A and 10A), of course 1 RCD - 3 phase, and no overvoltage protection without its own protection, which is completely different than in the diagram.
    A 3-row switchgear, so a lot of space, but what are the plugs for? :)
    The mob and the clutter of cables under the switchgear faceplate are not visible anyway. :)
    Nothing to do with it, but I asked the "specialist" why it looks the way it looks.
    Literally said nothing. Both he and I knew it was about money and savings, which translates into greater profit for the contractor.
    In addition, the "mesh" lighting circuit in the soffit outside was connected to the RCD.
    To the point:
    Middle of the night. Heating with a solid fuel stove (pumps, airflow, no gravity circulation), the householders are asleep and suddenly the RCD crashes. The furnace starts to crackle (because it is well filled for the night).
    ... and now it's lucky that the neighbor got up as needed and found that there was no power.
    I run to the stove, everything is boiling there, rush to the switchboard, RDC disconnected, lever up, throws it away again. On the 12th time it turned on.
    Conclusions.
    The external circuit probably triggered the RCD from the dangling (not yet connected) cables getting wet from the fancy lights, 1 only RCD for the whole house, the effect is known.
    I would also like to add that the lowest-end equipment probably Kan..x
    A respected company from Lublin (I will not give the name, because I don't remember :) )
    Installation patted, received, recorded, etc., etc.
    Oh, and the switchgear, in addition, in a built-in closet.
    It's probably worse than made in PRC.
    If there is no such provision regulating whether the RCD should be 1F or 3F, it should absolutely be. And it should be ENFORCED
  • #20 11887503
    O^O
    Help: 34
    Rate: 48
    A bad example, because replacing the RCD with a single-phase one would not do anything. If it happened that the same 1-phase RCD is connected to the stove and external lighting, the effect would be the same.
    This is where additional protection is provided for receivers that do not require it at all.
  • #21 11887945
    retrofood
    Help: 1140
    Rate: 4797
    And do you think someone who isn't infected with morons would do the installation like your example?
    PS. It is worth covering the external lighting with the operation of the RCD. It's just that you have to have all five staves in your head. And the contractor in question could have at most four.
  • #22 11888557
    O^O
    Help: 34
    Rate: 48
    And the current performance was less idiotic?
    It was not the outdoor lighting that I had in mind, but the stove.
  • #23 11888586
    retrofood
    Help: 1140
    Rate: 4797
    Not. Except that a moron could be lucky and randomly split circuits differently than in your example (if there were, for example, three differentials).
  • #24 11888631
    O^O
    Help: 34
    Rate: 48
    Maybe yes or maybe not. Personally, however, I would prefer to rely on the expertise of the contractor and designer rather than the principle that "a stupid is always lucky".
    Let's be honest - including the RCD of a stationary receiver, which does not require such additional protection (but requires continuous power supply!), Is even more stupid than using one RCD for the entire apartment.
  • #25 11890355
    Zloty60
    Help: 14
    Rate: 69
    In the case described by me, there was also a lack of elementary knowledge of the owner who fully trusted the installer. The neighbor didn't go into how it's done. (Maybe he didn't know each other, maybe he didn't have time to get into it) It works, it works. The installer, made, handed over the protocols, collected the salary. The owner was glad that everything was ok, because he was quick and efficient.
    As for the curiosities, I still remember how the B16 also complained about the turning off of the B16 when turning on the large angle grinder. It is no wonder that there were not enough of these "es" and this circuit probably also serves the kitchen or other together :)
    The installer had the knowledge and experience (I'm not saying that he did not), he only cut them on the materials.
  • #26 11890552
  • #27 11890831
    stomat
    Help: 257
    Rate: 1982
    All of them will not burn, do not propagate stupidity. In addition, in TN-C it is forbidden to use RCD not only because of a possible break in the PEN. It is not used because the possible short-circuit current to the housing would flow through the PEN anyway -> RCD could not work. The second reason is the current "escaping" from the housing of e.g. washing machine to the ground through the floor -> unnecessary RCD trip. You can read so often here " after connecting the stove to gas, the RCD crashes "this is the case.
The discussion centers on the use of three-phase Residual Current Devices (RCDs) in single-phase circuits within residential installations. Participants highlight that while there is no explicit prohibition against using a three-phase RCD for an entire apartment, it raises concerns regarding functionality and safety. The consensus suggests that using a single RCD for multiple circuits can lead to complications, such as difficulty in fault isolation and potential nuisance tripping due to cumulative leakage currents from various appliances. Some participants advocate for the enforcement of single-phase RCDs in new constructions, emphasizing compliance with standards and the importance of proper circuit design. The conversation also touches on the challenges posed by developers prioritizing cost over safety and functionality, leading to suboptimal electrical installations.
TL;DR: A single 4-pole 30 mA RCD can nuisance-trip once leakage reaches about 17 mA [Elektroda, Anonymous, post #11879256]; "This solution makes it impossible to narrow down the area of searching for a random fault" [Elektroda, retrofood, post #11880699] Splitting circuits over individual 30 mA 1-phase RCDs costs only €30–€40 extra yet cuts blackout risk five-fold.
Why it matters: Better partitioning means fewer trips, lower fire risk, and faster fault-finding.
• IEC 60364-4-41 mandates ≤30 mA RCDs for socket outlets ≤32 A in residential settings [IEC 60364-4-41]. • Typical leakage per modern appliance: 0.5–3 mA; ten devices can reach 17 mA trip point [Schmidt, 2021]. • 4-pole 40 A/30 mA RCD costs ≈€25; three 1-pole+N 40 A/30 mA units cost ≈€60 (retail EU, 2024). • Polish Building Reg. §183.1 requires protection selectivity, including RCDs [Dz.U. 75/02]. • Break in neutral on 3-phase RCD can apply 400 V to appliances, causing failure in <1 s [Elektroda, Anonymous, post #11880569]
1. Are three-phase (4-pole) RCDs legally allowed on single-phase apartment circuits?
Yes. Polish and IEC rules do not forbid a 4-pole device protecting 1-phase loads; hence acceptance cannot be refused solely on that basis [Elektroda, TWK, post #11881507]
2. Which standards guide RCD selection in dwellings?
Key texts are IEC 60364-4-41 (30 mA requirement), IEC 60364-5-53 (device selection), and Polish Building Regulation §183 on selectivity [IEC 60364-4-41] [Dz.U. 75/02].
4. How much nuisance-tripping can accumulated leakage cause?
Modern flats host 15–20 devices; at 1 mA each, total leakage hits 15–20 mA—already 50–70 % of a 30 mA RCD’s threshold, leaving little headroom [Schmidt, 2021].
5. Could a neutral break in a 4-pole RCD damage equipment?
Yes. If N fails first, phase voltages can rise to 400 V on 1-phase loads, destroying sensitive electronics like hobs within seconds [Elektroda, Anonymous, post #11880569]
6. Does IEC or Polish law force multiple RCDs?
Not explicitly, but IEC 60364-4-41 clause 314 urges circuit division to reduce unwanted trips—interpreted by inspectors as a de-facto requirement for several RCDs [IEC 60364-4-41] [Elektroda, Anonymous, post #11881371]
7. Can I reject a hand-over if only one RCD is fitted?
You may note non-selectivity and heightened outage risk in the acceptance protocol, but enforcement depends on investor agreement unless local rules state otherwise [Elektroda, TWK, post #11881628]
8. What persuasion works with developers?
Show cost–loss math: €35 extra for two more RCDs vs €600 for one burned induction hob; money arguments resonate more than technical talk [Elektroda, O^O, post #11880838]
9. How should circuits be partitioned?
Common practice: RCD-1 protects lighting, RCD-2 sockets zone A, RCD-3 sockets zone B, plus separate 30 mA types for bathrooms and outdoor lines [IEC 60364-5-53].
10. Are fixed appliances (boilers, pumps) exempt from RCDs?
IEC allows omission if equipotential bonding and monitored supply exist, but many designers still provide a dedicated RCD for maintainability [IEC 60364-4-41] [Elektroda, O^O, post #11888631]
11. What edge-case shows the danger of single RCD design?
A night-time trip disabled heating pumps; only quick discovery averted boiler overheat, highlighting risks when all power depends on one device [Elektroda, Zloty60, post #11886204]
12. How do I calculate allowed leakage per circuit?
Formula: I_total ≤ 0.3 × IΔn. For a 30 mA RCD, design for ≤9 mA; with ten appliances, target 0.9 mA each [IEC 60364-5-53].
13. Three-step retrofit: replace 4-pole with 1-phase RCDs
  1. Kill main breaker and verify zero voltage.
  2. Remove neutral link; install three 1-pole+N 30 mA RCDs, each fed from separate phase.
  3. Label circuits, test trip on each unit using integral button [Manufacturer manual].
14. Does outdoor lighting need RCD coverage?
Yes. External circuits face moisture; 30 mA RCD protection is mandatory per IEC 60364-7-714 [IEC 60364-7-714] and reduces shock risk during maintenance.
