Radiator Valve Orientation: How to Set This Type for Water Filling and Air Release?
Fifek9012 134013 3
  • #1 11347069
    Fifek9012
    Rate: 13
    Hello!
    I have a problem (although I do not know if he asks a question in a good topic) with the radiator valve in the apartment, and I will have to fill them with water this week.
    Well, I have such valves
    And I do not know how they should be set so that they are unscrewed. I will describe it like this: when they were in the position as shown in the pictures (apart from the second one, the other one is in another [roommate] room, so I did not hear if the air was coming out) it was because of these tips at the top the air was coming out recently (when the cooperative got married). Are they to be "unscrewed" in this position and water could get to them, or should the valve be turned? she doesn't know how it is supposed to be :| Sory, I know it's a stupid question, but I've never had a thing like this before :D thanks for the help
    MACIEK_M
    Help: 111
    Rate: 461
    Generally - handle along the valve - open, handle perpendicular to the valve - closed.
  • #3 11347388
    Fifek9012
    Rate: 13
    Thank you for your quick reply :)
    meaning correctly?: first photo: unscrewed; second (I made a mistake and added the same photo twice instead of another, third valve): closed? And leave it in the "unscrewed" position when they will pour water? or how? And in the first and the second, this "cap" at the top is unscrewed. Screw it? (I do not know why it was unscrewed ...) recently air was blowing through them with quite high pressure and then it stopped (and how did I turn the first valve to perpendicular it stopped)
    Forgive the stupid questions, but I don't know anything about this ...
  • #4 19008157
    piracik
    Help: 557
    Rate: 1975
    Open
    Closed
