How to Turn Off Lower Angle Radiator Valve: Step-by-Step Guide (Picture in Attachment)
morswio 33825 9
  • #1 16953860
    morswio
    I warmly welcome,
    I have a question how to turn off such a radiator valve:
    picture in attachment.
    Thank you in advance
    Luke
  • #2 16953918
    Parowy
    Help: 55
    Rate: 227
    Welcome.
    With these heads for a flat screwdriver, turning 90 degrees, probably to the level (you have to check because I'm not sure).
    If in doubt, ask.
    Regards
  • #3 16954215
    ls_77
    Help: 500
    Rate: 946
    Valves like the one in the picture have built-in ball valves - closing with a flat screwdriver after turning 90 °.
    Other types of similar valves have hidden closures under the plugs - first you need to remove them and then we can close them with an Allen key. Only here there are poppet valves, which means you have to turn it for quite a long time until it stops.
  • #4 18535220
    Mlody8892
    Hello. I wanted to ask something about such a valve as in the picture. They only have the option of turning left once and right once to open and close. Because I have at home that I can, for example, turn the flat screwdriver clockwise all the time and it opens and closes. And I wanted to ask if something is happening?
  • #5 18535828
    ls_77
    Help: 500
    Rate: 946
    You can spin them around and nothing should happen. Unless even the smallest moves move the seals on the spindle to turn these valves.
  • #6 18536651
    Mlody8892
    Thank you for your answer. But if he let go of some act, it could start to drip from the valve or something ??
  • #7 18536702
    ls_77
    Help: 500
    Rate: 946
    Yes - it could drip - then the whole valve should be replaced.
  • #8 18538300
    Mlody8892
    OK thank you. But it's been the third day since I've been spinning around so much and not a drop has fallen, so it's probably all right and nothing has come off
  • #9 18538366
    ls_77
    Help: 500
    Rate: 946
    It seems that it is and will be ok
  • #10 18538605
    Mlody8892
    Thanks for the answer
✨ The discussion revolves around how to turn off a lower angle radiator valve, as depicted in the attached image. Users provide insights on the operation of such valves, indicating that they typically feature a flat screwdriver slot for closure, requiring a 90-degree turn. Some valves may have ball valves or hidden closures that necessitate the removal of plugs and the use of an Allen key. Concerns about potential leaks from excessive turning are addressed, with reassurance that spinning the valve should not cause issues unless it affects the seals. Overall, the consensus is that if no leaks occur after extensive turning, the valve is likely functioning correctly.
