Vaillant Stove Error F20 After Draining Water and Pressure – What Causes This?
cczc 45615 7
  • #1 11369982
    cczc
    Rate: 8
    after turning off the stove, draining the water completely, later pumping out the water, draining the pressure, error f20 appeared. what could be the cause and what can be done about it?
  • #2 11370032
    lexium
    Rate: 14
    Take a picture and add it to your post. I'm interested in the symbol next to this alarm. Maybe I can help.
    Added after 8 [minutes]:
    Once a year it belongs
    clean the heat exchanger (coil made of carbon deposits) and the thermocouple.
    And here is the link to the discussion
    https://www.elektroda.pl/rtvforum/topic1583810.html
  • #3 11370355
    cczc
    Rate: 8
    Vaillant Stove Error F20 After Draining Water and Pressure – What Causes This? [/ img]
    Added after 41 [minutes]:
    in the manual I found the 'fault reset' button (the flame crossed out symbol). After pressing the stove, the stove started to work, but after unscrewing the water had large temperature fluctuations, sometimes it was warm and sometimes cold. after a longer operation for about 15 minutes, the max temperature appeared 110 and the error f20 appeared again
  • #4 11370675
    lexium
    Rate: 14
    First, check that the installation is deaerated.
  • #5 11370691
    cczc
    Rate: 8
    is deaerated
  • #6 11370884
    lexium
    Rate: 14
    Please provide the boiler number :) Works with or without a hot water tank? :)
  • #7 11371098
    cczc
    Rate: 8
    serial number: 2109410010003322000100518ON5
    the only number that is written :P
    and the stove works without a hot water tank
  • #8 11371812
    dziubek102
    Heating systems specialist
    Help: 69
    Rate: 244
    Check that all valves are open and the pump turns and does not stuck like it was without water. F20 no water or no circulation the limit temperature is reached. Bleed again.
The discussion revolves around a Vaillant stove displaying error F20 after the user drained and pumped out the water. The error indicates issues related to water circulation or temperature limits. Suggestions include checking the installation for air pockets, ensuring all valves are open, and verifying that the pump is operational. The user noted that after pressing the fault reset button, the stove operated briefly but exhibited temperature fluctuations before the error reappeared. The stove operates without a hot water tank, and the serial number provided is 2109410010003322000100518ON5.
