Vailland 200 3-5 Boiler: Error F26 Persists Even After Motherboard Replacement
bronek2103 12798 7
  • #1 16697809
    bronek2103
    Hello to all forum users. I have a problem with the gas stove, after switching on, the code f26 is displayed and all functions are blocked. After the initial analysis, the service technician suggested replacing the motherboard. I installed a new board, the problem remained.
  • #2 16698393
    ls_77
    Help: 500
    Rate: 948
    Error F.26 according to the instruction is:
    Rather, it indicates a fault with the gas valve or wiring harness.
    The motherboard could also be damaged, but why did the service technician start with the most expensive component?
  • #3 16698730
    501toyota
    Help: 16
    Rate: 73
    bronek2103 wrote:
    Hello all...
    Buddy, this error is related to the gas valve and that's where you should look. Firstly, a stepper motor, secondly, the wiring of this apparatus (i.e. the entire harness, including the printed circuit and plugs on the motherboard), thirdly, the ntc sensors (this is additionally because there may be a wrong sensor indication and the signal for the gas apparatus and it "stands" and crashes error f.26).
    In the end, I would insist on the motherboard.
    And by the way - not Vailland but Vaillant, not just a boiler :sm31:
  • #4 16698894
    bronek2103
    The motherboard has a new one. When I turn on the boiler, you can hear as if an engine stabilizes something after a few seconds, the display shows f26 and everything is blocked. .
  • #5 16699353
    BUCKS
    Help: 536
    Rate: 1088
    what you hear after turning it on is probably the characteristic buzzing of the motor from the three-way valve.
    If the service technician started, let him finish.
    I advise against "fumbling" at the gas valve on your own.
  • #6 16700228
    bronek2103
    I made an appointment with a service technician today, we'll see what the final will be.
  • #7 16700308
    ls_77
    Help: 500
    Rate: 948
    bronek2103 wrote:
    When I turn on the boiler, you can hear something like a motor stabilizing something
    Each time the boiler is turned on, the gas valve, CH - DHW switching valve and pump are activated to check their correct operation.
  • #8 16708771
    bronek2103
    Hello. I installed a new gas valve today. The stove is running like new. Thanks everyone for the advice. I am closing the post.
The discussion revolves around a persistent F26 error code on a Vaillant 200 3-5 boiler, which remains unresolved even after a motherboard replacement. Forum users suggest that the error is likely related to the gas valve, wiring harness, or NTC sensors rather than the motherboard itself. The original poster confirms the installation of a new gas valve, which ultimately resolves the issue, restoring the boiler to normal operation.
