Cutting plastic (PVC pipes in half)
borix1234 30111 11
  • #1 11386376
    borix1234
    I have a question, what would be the best to cut a 6 m PVC plastic pipe from the water (pipeline). I plan to mark it in half and cut it on 2 sides to make 2 gutters. The point is to make the gutters quite evenly cut. Then I would like to set up these 2 gutters on the cowshed, which is 11 meters long.
  • #2 11386425
    brofran
    Help: 650
    Rate: 1408
    If you want it nice and smooth, use a heated resistance wire (electric cutter). And if quickly and in any way, then with a grinder, the so-called with a square.
  • #3 11386433
    vodiczka
    Help: 1185
    Rate: 4311
    borix1234 wrote:
    I have a question, what would be the best way to cut a 6 m PVC plastic pipe from the water (pipeline).
    Will this gutter be too heavy?
  • #4 11386774
    Artur k.
    Help: 1279
    Rate: 1701
    Panties over the head. There are ready-made gutter profiles and they should be used. I wonder how you intend to accurately mark the cut lines on the 6m pipe. First try to do this, then ask how to cut.
    An angle grinder is probably the worst that can be. Preferably with a jigsaw, but I can't imagine how to evenly cut a 6m long pipe along the length.
    I myself would rather think about the use of a circular saw - the so-called country.
    The author of the thread writes about the gutter to the cowshed, so I conclude that he lives in the countryside, and there should be no problem in villages with access to the country.
  • #5 11386792
    k4be
    Help: 102
    Rate: 333
    With the band saw you can cut both sides at once, but the problem remains of guiding it to be cut straight.
    A better solution is probably to sell the pipe and buy a normal gutter.
  • #6 11386897
    Artur k.
    Help: 1279
    Rate: 1701
    k4be wrote:
    a better solution is probably to sell the pipe and buy a normal gutter.
    Exactly.
  • #7 11387142
    borix1234
    The point is that he has 20 of these pipes, the cowshed is old, he does not plan to buy new gutters, and I have pipes and I came up with the idea that I would use them. As for the selection, I think a thin string of powder and they saw them evenly, as the lines on the floor at the construction site are marked. And my hooks are large, made of a thick flat bar, so it won't bend. Also 2 pipes and I would have gutters on 2 sides and it would be connected, only in one place.
    As for the resistance wire, I also thought about it, or about flattening the copper tip from the soldering iron to a flat and trying to cut it.
  • #8 11387598
    Artur k.
    Help: 1279
    Rate: 1701
    Only the floor is not round ... Here you have to mark two lines on something that is round. I bet what you want you don't do it equally.
    The stench of poop and you might end up in the spring and no one knows what will come of it.
    Give it up, because you will do something wrong and you will not have a gutter ...
  • #9 11387840
    borix1234
    I will try to cut tomorrow, see what comes out, if it comes out well, I will post a photo. As for the selection, I have already tried and it turned out well, and a few millimeters of difference does not matter, as I have already written, it should be for the cowshed.
  • #10 11388001
    Gizmoń
    Help: 21
    Rate: 1518
    You need to make a guide for the pipe (a tray made of boards) and attach it to the table top of a circular saw or other (or attach a "rubber band" to the guide, if there is nothing else ...)
    At the end of the pipe, attach a handle, also made of boards, to prevent it from turning. You will need an assistant who will hold the handle in your hands and push it while you handle the saw.
    There is one more possibility, but it depends on the pipe and exactly how it is made. It might not work, especially since it's a long pipe. Well, some of them can be broken evenly in half along the seam. I discovered it by accident when, while carrying something heavy, I stepped violently on one lying on a hard surface :D In this way, I obtained over a meter of gutter in two pieces.
    PS
    Me + something heavy is probably about 80 kg, so that it would not be that 450 kg :)
  • #11 11388732
  • #12 11389351
    zimny8
    Help: 26
    Rate: 504
    After cutting the pipe, you will get two profiles, something like gutters, but they will be much "shallower" than the produced ones, they are fuller and more closed, and their wounds are strengthened and wrapped.
    The friend's gutter will be very slack, weak shallow, water flowing from the roof will be thrown from it, snow, icicles will easily damage it, they will break it.
    You will get better and the effects will be mediocre and for a short time, even none.
    You want cheap, buy an ordinary galvanized sheet gutter, solder it, paint it after two years.
The discussion revolves around the best methods for cutting a 6-meter PVC pipe in half to create gutters for a cowshed. Various cutting techniques are suggested, including using a heated resistance wire for a smooth cut, a jigsaw for precision, and a circular saw with a guide for stability. Concerns are raised about the weight and structural integrity of the resulting gutters, with some participants recommending purchasing pre-made gutter profiles instead. The author clarifies that they have multiple pipes and aims for a practical solution rather than perfection. Suggestions include marking cut lines accurately and using a guide to ensure straight cuts. The potential for the gutters to be less durable than commercial options is also discussed.
