Best Water Pipe Type for Allotment Garden Gazebo: PEX/AL/PEX vs PE, 25cm Depth, 15m Distance
kazik111267 58593 12
What type of water pipe should I use for a 15 m garden connection buried about 25 cm deep if the water will be drained for winter?
Use a blue PE pipe rather than PEX; the replies recommend PE 20–25 mm (or 32 mm) and say PEX is too thin for garden use [#12072178][#12072893][#12080331] Bury it much deeper than 25 cm, ideally around 80 cm or below the frost line, because 25 cm is considered too shallow [#12072893][#12072539] If you cannot bury it that deep, provide drain valves and empty the line for winter [#12072893][#12073267] Several replies also recommend blowing out the remaining water with compressed air to be sure nothing freezes [#12074298] PE piping is reported to work well in allotment gardens when installed properly [#12072539]
  • #1 12072135
    kazik111267
    Rate: 50
    What kind of pipe to use for water connection on the plot. (Gazebo in the allotment garden) Whether to use a pex / al / pex or pe pipe. He plans to bury the pipe at a depth of approx. 25 cm and for a distance of approx. 15 m. The water will be drained for the winter.
    I am asking for advice.
  • #2 12072178
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    PE, pex for the garden is not suitable, it is just too thin.
  • #3 12072296
    saskia
    Help: 174
    Rate: 1086
    Blue for connection.
  • #4 12072539
    WoŹnY
    Help: 76
    Rate: 149
    At my parents' allotment gardens, a water installation was made with the use of PE pipes. Everything, both reception and power supply. These are numerous allotment gardens, so the main pipe is probably 4 "connections with fi25 pipes. Everything with twisted joints (I would prefer welded). Everything is powered from the municipal network (0.6MPa) works all year round. Most importantly, everything is buried below freezing of the ground, about 1.2m. Shut-off valves and meters also in the ground, in insulated manholes. Everything works as it should. So I would not disqualify PE pipes. He would rather think about burying them at least 0.8 m, because you will forget once, or you will be late to empty the pipe and the whole thing to be replaced.
  • #5 12072836
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    And who disqualifies them?
  • #6 12072893
    Bogdanbenek
    Help: 21
    Rate: 78
    PE pipe 25 mm or 32 mm blue + pipe insulation and appropriate depth, not 25cm from 80 cm as you suggest, as my friend above suggests + valves for draining the water, I have it done and buried myself [PE 25mm] and for the winter I drain the water from this pipe that supplies the plot.
  • #7 12073267
    kazik111267
    Rate: 50
    The meter comes with 1/2 '' steel pipes, so I will use PE 20. As for the depth of burying the pipes, it does not deny that it is so deep that it is bad, BUT to dig 15 m by hand to a depth of 25 cm, and 80 cm workload it is very big.
    In the fall, the water is turned off to the depth of valves, and allotment counters unscrew.
    He also plans to blow compressed air from the compressor to blow out the remaining water from the pipes.
  • #8 12073274
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    kazik111267 wrote:
    BUT dig 15 m by hand to a depth of 25 cm, and the workload of 80 cm is very large.
    Now you're kidding, it's 3 hours of honest work.
  • #9 12073819
    WoŹnY
    Help: 76
    Rate: 149
    andrefff I thought you would disqualify both Pe and PEX. That's just how I interpreted your opinion. So I misinterpreted what I am sorry for.
  • #10 12074298
    Bogdanbenek
    Help: 21
    Rate: 78
    You have a few hours of digging 15m at a depth of 80cm, that's a laugh in the hall :D He always goes to hire a digger to do the job. However, as for removing the residual water for the winter, I recommend doing it with compressed air from the compressor, then it is certain that it will not defrost something.
  • #11 12076306
    kazik111267
    Rate: 50
    As for the excavator, as I wrote above, it is an allotment garden. Take a small cart or a helicopter to the site.
    I can see that everyone but me is suitable for digging with a shovel.
    I was already digging there a bit (CLAY, ANY OLD ROUGH) pure pleasure.
    I invite you to the weekend, let someone dig two meters (MIND A FEW HOURS), I will dig the rest with two left hands.
  • #12 12079854
    Bogdanbenek
    Help: 21
    Rate: 78
    Nobody is a prophet and knows what soil you have on your ranch with clay, rubble, etc. :| But slowly it always goes to scratch only not nervously and it will do itself one day slowly. Dig wider and then narrow slightly 25cm then you have the so-called shovel punch :D
  • #13 12080331
    kazik111267
    Rate: 50
    Will use a PE pipe fi 20, price approx. PLN 1.50 per meter.
    Thank you for your help.
    Subject to be closed.
The discussion centers around the selection of pipes for a water connection to a gazebo in an allotment garden, specifically debating the use of PEX/AL/PEX versus PE pipes. Users recommend PE pipes, particularly 20mm or 25mm, for their suitability in garden applications, emphasizing the importance of burying the pipes at a depth greater than 25cm to prevent freezing. Some participants share experiences of using PE pipes successfully in similar setups, while others suggest using pipe insulation and valves for winter drainage. The consensus leans towards PE pipes, with considerations for installation depth and the practicality of digging in various soil conditions.
