Audi A6 C6 2007 3.0 TDI: Coding Varta Super Dynamic 110Ah 9120A Battery (610402092) with VCDSA
chubert001 129000 8
  • #1 11547112
    chubert001
    Rate: 36
    Could someone provide the coding of the Varta super dynamic 110Ah 9120A battery No. 610402092 for the audi a6 c6 2007 3.0 tdi. If someone has VCDSA, I can't find varty on the website.
  • #2 11547168
    MC CHIPTUNING
    Rate: 35
    You definitely don't have such a sticker on the battery :) ?
    • Audi A6 C6 2007 3.0 TDI: Coding Varta Super Dynamic 110Ah 9120A Battery (610402092) with VCDSA 450px-Battery_serial_number.jpg (46.07 KB) You must be logged in to download this attachment.
  • #3 11547276
    piotrekwoj1
    Help: 947
    Rate: 3433
    Hello, from what I know, you have to connect the car to the computer and then do the coding, but no numbers are needed, only what is the battery capacity, otherwise you will not do it.
  • #4 11548762
    chubert001
    Rate: 36
    The point is that there is no such sticker on the battery. and you need to code with a computer because the battery is different than the original one.
    I have Vcds but unfortunately Chinese and I lost it some time ago. I ordered a new one, but the shipment goes and the battery can be replaced 15 minutes and that's it, and I know that there is a coding for this battery in the vcdsie, which is a pity because the battery has already been ordered and it can be. And the client will not be sent to the competition. because I have not heard of any module coding because they have either a launcher, a barefoot car, or a vag interface.
    So if anyone can, I am waiting for help.
    Cheers with the soup.
  • #5 11549654
    piotrekwoj1
    Help: 947
    Rate: 3433
    Hello again, I know that you need to code the battery and I have this option in the autocom, but as I wrote earlier, I do not have to have a serial number, but only its capacity, but I can be wrong, for sure, as I wrote, it is in BMW and I have nothing to connect the computer to to check how it is in Audi greetings
  • #6 11559967
    MC CHIPTUNING
    Rate: 35
    Do the encoding on: 000915105DL
    • Audi A6 kodowania akumulatorów.txt (694 Bytes) You must be logged in to download this attachment.
  • OEM battery capacities and part number cross-reference
    #7 11560013
    Arutim
    Help: 18
    Rate: 37
    Zdeczka you know about these points - especially for the information that is free on the A6klub website.
    51Ah - 8K0915105J / 000915105BB / 000915105DC
    60Ah - 4F0915105 / 8K0915105G / 000915105DD
    61Ah - 8K0915105H / 000915105AD / 000915105DE
    70Ah - 4F0915105A / 8K0915105C / 000915105DF
    72Ah - 8K0915105B / 000915105AF / 000915105DG
    80Ah - 4F0915105B / 8K0915105D / 000915105AG / 4FD915105 / 8KD915105 / 000915105DH
    95Ah - 4F0915105C / 8K0915105E / 000915105AH / 000915105DK
    110Ah - 4F0915105D / 8K0915105F / 000915105AK / 8KD915105A / 000915105DL
    68Ah - (AGM with woven fabric) 7L0915105 / 000915105CC
    75Ah - (AGM with woven fabric) 3D0915105H / 000915105CD
    92Ah - (AGM woven) 4F0915105E / 000915105CE
    105Ah - (AGM with woven fabric) 4L0915105 / 000915105CF
    115Ah - (high current) 4H0915105 / 000915105DM
    No points
  • #8 11560041
    MC CHIPTUNING
    Rate: 35
    Laziness has to cost ;) And so you teach others not to use the search engine, but to duplicate the topics, and then cry that they will not look before they ask
  • #9 11563600
    chubert001
    Rate: 36
    Hello everyone
    It is thanks to the search and my colleagues from DK that I have already found the answer, so despite the strange comments Ł = yamzkam the topic
The discussion revolves around coding a Varta Super Dynamic 110Ah 9120A battery (No. 610402092) for an Audi A6 C6 2007 3.0 TDI using VCDS. The original poster seeks assistance due to the absence of a sticker on the battery that typically provides coding information. Responses indicate that coding requires connecting the vehicle to a computer, with emphasis on the battery's capacity rather than a serial number. A specific coding suggestion of "000915105DL" is provided, along with a list of codes for various battery capacities. The conversation highlights the importance of proper coding for non-original batteries and the challenges faced when lacking the necessary tools or information.
