Audi A6 C6 2.7tdi 2008: Engine Controller Recoding for Manual Transmission, ABS, & Multitronik
bolekf2 13404 6
  • #1 16737244
    bolekf2
    Rate: 258
    Hello, I have to re-code the engine control unit from a car with an automatic transmission multitronik to manual.
    Now the encoding is: 0011382
    There is no coding helper in vcds so maybe someone can help with modifying them.
    However, is there no recoding option and you have to replace the engine controller from a car with a manual?
    In general, the car is after the automatic transmission to the manual gearbox, maybe someone would tell you how to handle it. They have been re-coded to manual, can gateway, hanbrake, ignition switch. I will add that it is impossible to remove the key.
    ABS and engine control unit coding remained. Is it possible to recode ABS for manual in C6?
    best regards
  • #2 16737976
    adam7009
    Help: 656
    Rate: 1635
    Engine There is no recoding option, ABS can only be done after the engine.
    org engine ecu numbers? then maybe I will determine what will be in return.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #3 16739221
    bolekf2
    Rate: 258
    Engine
    ABS
    adam7009
    Help: 656
    Rate: 1635
    Engine 4F5 910 401 M
    adam7009
    Help: 656
    Rate: 1635
    Did you? Smoke already?
  • #6 16906122
    bolekf2
    Rate: 258
    Thanks to the help of adam7009, the car is ready and operational. Thanks and regards
  • #7 16907687
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    My mistake. I brought the subject back.
The discussion revolves around the recoding of the engine control unit (ECU) for an Audi A6 C6 2.7 TDI 2008, which has been converted from an automatic Multitronic transmission to a manual gearbox. The original coding is 0011382, and the user seeks assistance in modifying this code, as there is no coding helper available in VCDS. Responses indicate that recoding the ABS is contingent upon successfully recoding the engine ECU. The user shares engine ECU numbers and confirms that, with help, the car is now operational.
