excel - returning the value of the first and last non-empty cells in a column
mxilopez 38637 12
How can I get Excel to return the first and last non-empty values from a column into separate cells?
Use array formulas: for the first non-empty value in a column range `z`, enter `=INDEX(z,MATCH(FALSE,ISBLANK(z),0))`, and for the last non-empty value use `=INDEX(z,MAX(IF(ISBLANK(z),0,ROW(z)))-ROW(z)+1)` [#11768434] Approve both with Ctrl+Shift+Enter because they are array formulas [#11768434] If the range starts on the first row, the last-value formula can be shortened to `=INDEX(z,MAX(IF(ISBLANK(z),0,ROW(z))))` [#11768434]
  • #1 11738814
    mxilopez
    Hello, I would like excel to return to me the value of the first and last (in separate cells) non-empty cells in a given column. For example, I have a column with the days of a given month and numerical values assigned to them next to them. However, not every day has an assigned value, so I would like it to find the last value from a given month and the first. I hope that I wrote quite clearly :)
  • #3 11754003
    mxilopez
    Thank you very much. I did not think that someone would do something so quickly :)
  • #4 11768434
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    The problem can also be solved in Excel itself without Visual Basic.
    Let us denote by with column or row range that we are analyzing. You can actually give this name to a range or in the following formulas in place of with enter the addresses of the range.
    All the following formulas are array formulas , so you must approve them with Ctrl + Shift + Enter .
    To read first value in a column or row range, you can use the formula:
    = INDEX (z, MATCH (FALSE, ISBLANK (z), 0))
    As an alternative to a column range, you can use one of the formulas:
    = OFFSET (z, MATCH (FALSE, ISBLANK (z), 0) - 1,0)
    = INDEX (z, MIN (IF (ISBLANK (z), "", ROW (z))) - ROW (z) +1)
    The last formula can be simplified if the range starts with the first line:
    = INDEX (z, MIN (IF (ISBLANK (z), "", ROW (z))))
    Similarly, in the case of a row range, you can use the following formulas:
    = OFFSET (z; 0, MATCH (FALSE, ISBLANK (z), 0) - 1)
    = INDEX (z; MIN (IF (ISBLANK (z); "", COLUMN (z))) - COLUMN (z) +1)
    The last formula can be simplified if the range starts with the first column:
    = INDEX (z, MIN (IF (ISBLANK (z), "", COLUMN (z))))
    To read last value in a column range, you can use the formula:
    = INDEX (z, MAX (IF (ISBLANK (z), 0, ROW (z))) - ROW (z) +1)
    As before, the formula can be simplified if the range starts with the first line:
    = INDEX (z, MAX (IF (ISBLANK (z), 0, ROW (z))))
    In the case of a row range, the analogous formula is:
    = INDEX (z, MAX (IF (ISBLANK (z), 0, COLUMN (z))) - COLUMN (z) +1)
    If the range starts with the first column, the formula might be shorter:
    = INDEX (z, MAX (IF (ISBLANK (z), 0, COLUMN (z))))
  • #5 11772043
    okonda
    Rate: 13
    Hello. I do not fully understand what you are writing but I have such a problem. Let me put it in simple words.
    I have a 2012 price list with 1,200 articles, where in column A I have catalog numbers, in B I have names and C prices. I received a new 2013 price list which has 1226 items and also consists of three columns that I pasted in D; E; F and so:
    The 2012 price list has several items that are not in the 2013 price list, while the price list has 26 more items, of which about 40 are new (somewhere in the middle).
    The numbers are arranged from smallest to largest from top to bottom.
    01E1007 01E1007
    01E3007 01E3007
    01E4007 01E4007
    01E8007 01E8007
    01EA125 01EA125
    01M4051 01EA126
    01M4061 01M4111
    01M4071 01M8111
    01M4081 01N4013
    01M4091 01N4015
    01M4101 01N4017
    01M4111 01N408A
    01M8051 01N4093
    01M8061 01N4097
    01M8071 01N8013
    01M8081 01N8015
    01M8091 01N8015D30
    01M8101 01N8017
    I need column A and D to have the same values.
    When there is no number in column A in a given row that is identical to that in column D, then the row in column A should move down (with columns B and C), and if there is no value in D such as in A, the same applies to rows in column D: E and F have moved down so that there are blank lines.
    01E1007 01E1007
    01E3007 01E3007
    01E4007 01E4007
    01E8007 01E8007
    01EA125 01EA125
    01EA126
    01EA128
    01M4111
    01M8111
    01N4013
    01N4015 01N4015
    01N4017 01N4017
    01N408A 01N408A
    01N4093
    01N4097 01N4097
    01N8013 01N8013
    I have only given columns A and D here, but there are also descriptions here, as I described earlier.
    Can it be done easily?
    Please help.
    • przykład.xls (15.5 KB) You must be logged in to download this attachment.
  • #6 11772387
    marek003
    Level 40  
    Help: 801
    Rate: 488
    mxilopez = okonda ????
    If not, then :arrow: okonda create your own topic because your question has nothing to do with the main topic of the thread.
    No wonder that:
    okonda wrote:
    "I don't quite understand what you are writing ..."
  • #7 11772819
    okonda
    Rate: 13
    I really don't know anything about it and I need some help. it is better to comment and mock someone than help him. give a hint what the topic should be, and I will create a new one
  • #8 11773473
    marek003
    Level 40  
    Help: 801
    Rate: 488
    After the dictionary of the Polish language:
    Sneer - make fun of someone, mock someone, treat someone with contempt
    At what point do you think I've mocked / laughed at / referred to you with contempt?
    Read with understanding.
    I just found out that your problem is completely other than the author's problem and you should start your own topic.
    In addition, I also found that it is not strange the second fact that if you have another problem then you do not understand the answer, because unfortunately they are not the solution to your problem.
    However, if you feel offended, I apologize.
    As for the name of your problem (subject of the post): who and who, but you should know best what you have a problem with. But if you don't write, no one will be offended. Maybe: data synchronization in tables according to the index column or specific setting of two tables with indexes .
    But I will say right away that it will probably not be an easy solution.
    Write in this new thread (if possible) ultimately what you want to use it because maybe you can use other methods than "shifting" lines.
  • #9 11773525
    okonda
    Rate: 13
    Thank you, but it seemed similar to me, and I had the impression that you "went" right away.
    I need it why.
    I receive a different price list every year. Each time they are, the so-called exchanged articles. Some are disappearing and some are new.
    The price list comes in German or English and it is still poor (without detailed article descriptions). I have translated this price list, article by article (partially) and now I have to enter prices manually, and unfortunately there is a lot of it.
    Having such a table:
    once - I give copy-paste prices later, and fill in the empty ones;
    two - I can do a percentage comparison as long as EVERY item changed the price
    three - I have the impression that it will be useful in many other matters.
    I set up a new topic and I'm waiting.
  • #10 12757372
    gulonus
    Your formula doesn't give the last value in the column, but the largest one.
  • #11 12757965
    Maciej Gonet
    Help: 824
    Rate: 481
    Good morning,
    Errare humanum est, but the formula seems to work fine to me. See example in the appendix. Please give your example and we'll check what's wrong.
    Regards.
    • Ost_wart.xls (17.5 KB) You must be logged in to download this attachment.
  • #13 12772719
    okonda
    Rate: 13
    thanks. Topic finished. I have already received some great responses.
✨ The discussion revolves around how to retrieve the first and last non-empty cell values in a specified Excel column. A user seeks a solution for a column containing days of a month with associated numerical values, where not every day has a value. A helpful response provides a Visual Basic for Applications (VBA) script to achieve this, detailing the necessary subroutines and parameters. Additionally, alternative solutions using Excel formulas are suggested, emphasizing the use of array formulas to find the first and last non-empty values without VBA. The conversation also includes unrelated queries and clarifications about different problems, but the main focus remains on the Excel functionality.
