Selecting Last Column Range in VBA: Using .Cells, Columns.Count & .End(xlToLeft) Methods
Forte12 5784 6
  • #1 16426741
    Forte12
    how to select the range to the last column in one row
    ost_column = .Cells (2, Columns.Count) .End (xlToLeft) .Column
  • #2 16426862
    JRV
    VBA, Excel specialist
    Help: 805
    Rate: 455
    Code: text
    Added after 6 [minutes]:
    d2 will be a value, necessarily a formula?
  • #3 16426974
    Forte12
    does not work, unfortunately
    Cells (2, 4) = Application.WorksheetFunction.Average (Range (Cells (2, 5), Cells (2, ost_column))) I have entered without dots and it works. Only this is a value and I had it done so that it copied functions to the last line and now it doesn't work anymore
  • #4 16426999
    JRV
    Help: 805
    Rate: 455
    Forte12 wrote:
    ost_column = .Cells (2, Columns.Count) .End (xlToLeft). Column
    it was full stop because you used With Sheets ("Medium")
    You must use R1C1 notation for the formula
  • #5 16427002
    Forte12
    I combine with for loop
    Code: VBScript
    I did something like that
    JRV
    Help: 805
    Rate: 455
    Forte12 wrote:
    For k = 5 This is last_data
    it makes sense? to change columns from 5 is how many rows
    .Cells (w, 4) .Value = Application.WorksheetFunction.Average (Range (.Cells (w, 5), .Cells (w, ost_column)))
    For k = 5 To ost_dane and Next delete
  • #7 16427037
    Forte12
    so I did :)
    Code: VBScript
    Thank you for your help :) I only have the export of the file left but I don't know if it will work :( I need to export a file in ASCII format.
✨ The discussion revolves around selecting the range to the last column in a specific row using VBA in Excel. The main question involves using the .Cells, Columns.Count, and .End(xlToLeft) methods to achieve this. Various users provide insights and solutions, including the use of Application.WorksheetFunction.Average to calculate averages across specified ranges. A key point noted is the importance of using the correct syntax, particularly when using the With statement for referencing sheets. The author successfully implements a loop to average values from the fifth column to the last column, expressing gratitude for the assistance received. Additionally, there is a mention of exporting the file in ASCII format.
