Viessmann radiator cold at bottom, warm at top—using Vitopend 100, 2.5 bar pressure
krecikno1 31647 8
  • #1 11809898
    krecikno1
    I have Viessman heaters in my apartment. In the bathroom and in 2 rooms, the radiator warms very well, while in the third room, the radiator is cool downstairs and warm upstairs. All this is handled by the Vitopend 100 2-function stove (pressure currently set to 2.5 bar). What may be the cause of incomplete heating of one radiator? I will add that they are all vented.
    Thanks in advance for your answer
  • #2 11809961
  • #3 11810024
    krecikno1
    generally, the room is very large and is connected to the kitchen (area approx. 40 m2) and taking into account that there is only 1 radiator, which is 140 cm, it is always cooler in this room (approx. 19.75-20.5 degrees, the rest of the rooms approx. 22.5 -24 degrees)
  • #4 11810030
  • #5 11810043
    1tropek
    Help: 30
    Rate: 152
    First, drain the water from the system because you have too much pressure.
    If the radiator is not equally warm vertically (left, right side), there is air in it, if horizontally (up, down) there is too little flow of the heating medium.
  • Diagnosing cold radiator bottoms and pipe connection orientation
    #6 15061303
    tommy-4
    I will stick to the topic.
    Network pressure 1.8 - 1.9
    On one side of the apartment 2 heaters (boiling)
    On the other side, there are 3 radiators - the first bathroom is hot, the next two are warm at the top, summer or cold at the bottom. Temp. on the stove set to 70 ° C.
    Boiling water comes to the two faulty ones, because the tube is hot and it splits into two radiators. Cold return tube. Radiator bottoms barely lukewarm. Where is the cause of underheating of the pits? All radiators are bled, of course.
    Second question. Can the supply and exhaust pipes be connected to the radiators on the same side or should they be connected diagonally to the radiator?
  • #7 15061912
    Serwis Kotłów
    Help: 25
    Rate: 123
    maybe the radiators are just too small?
    Maybe the flow in the installation is too weak, e.g. a collapsed filter, traps in the installation ...
    If you have thermostatic valves, check what are the settings - if possible, set them to higher values.
    The method of connecting the heater affects its power, but most manufacturers allow different configurations.
    Regards
  • #8 15063267
    tommy-4
    Thanks for the hint.
    They are certainly not too small. They were warming normally last season. I will check the settings and I think I will also bet on the muck in the installation on this side of the apartment because I know that it has not been flushed for a long time.
    I will fight again ...
  • Adjust radiator presetting to increase bottom flow
    #9 15063893
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    It is especially unpleasant when the radiator is cold from the bottom and warm from the top (it does not heat the legs and the back is hot). If this is the case, it means that there is a small flow of the heating medium in relation to the size of the radiator. First of all - as it was written in the previous post - check the initial settings (orifice) and increase the flow in those radiators that heat badly (they are cold at the bottom). In those that are very hot, slightly reduce the presetting. The presetting is not what is set with the thermostatic head, but what replaces the cladding. To do it, you need to disassemble the thermostatic head (under the head there is usually a setting ring - if Danfoss - or a special nut - if other valves - with numbers corresponding to the setting value and there is a dot on the valve body - a reference point. One more thing. is the bottom cold also when the temperature is set to the maximum by the thermostatic head? Maybe the head is damaged (defective / worn).
The discussion revolves around a radiator issue in an apartment with Viessmann heaters, where one radiator is cold at the bottom despite being vented. The user notes that the affected room is large (approximately 40 m²) and has only one radiator, leading to lower temperatures compared to other rooms. Responses suggest several potential causes, including inadequate flow of the heating medium, air trapped in the radiator, or incorrect settings on thermostatic valves. Recommendations include adjusting the shut-off valves on hotter radiators, checking for blockages in the system, and ensuring proper connection configurations for the radiators. The importance of flushing the system to remove debris is also highlighted.
