Radiators Warm Only at the Top: Examining Uneven Heating, Regulator Settings, and Gas Boiler
boskiori 17610 14
Why are some radiators only warm at the top and cold below, even when the valve is turned up, while another radiator gets very hot and one stops heating when turned from 3 to 5?
The most likely cause is a flow problem at the radiator valve: the pin may be stuck, or the valve/orifice may be dirty or incorrectly preset, so the radiator gets only a small amount of hot water [#7640803][#10188430] Remove the valve head and press the small pin a few times to make sure it moves freely [#7640803] If the valves are old, the flow is adjusted inside the valve with a preset/orifice, and changing or cleaning it may require draining the system or replacing the valve with a modern thermostatic one [#10188430][#10209190] One reply also suggests that the flow settings/orifices may have been changed by someone else in the building, which would explain why only some radiators are affected [#7446708]
  • #1 7421996
    boskiori
    The radiators are vented and when the regulator is set to 5 (maximum), the summer ones are only at the top of the radiator and so about 5 cm lower, and they are cold below. This includes two radiators in two rooms. It is very cold in the rooms. In the bathroom, when the regulator is set to 5, the radiator is warm to the point of burning. And the fourth radiator in the bedroom behaves like the two previous ones, but when set to 3, if I turn the regulator to 5, it does not heat and is cold the same as on 0. What is this about? maybe someone knows...? I would like to add that the apartment is in a multi-family block (150 apartments) with its own gas boiler room. No such problems with the neighbors. The previous two heating seasons were fine for me too. Please help and thank you in advance
  • #2 7422040
    Samuraj
    Help: 286
    Rate: 619
    And it wasn't that this radiator was not used for longer, or the installation was not recently flushed. Maybe some syphilis from the installation got into the thermostatic valve.
  • #3 7446708
    hydroplas
    I think that someone from the neighbors removed orifices from the valves, or changed the pre-settings. In that case, you can't help yourself.
    Regards, Grzegorz
  • #4 7640317
    mcryb
    Hello, I have a problem as in the title.
    More details, I live (rent) in a two-family house, on the ground floor, basement, unheated basement, area, approx. 100m2. The house is about 40 years old, old-date installation, cast iron radiators, thermostatic valves that have not been touched for years. The problem occurs in the two largest rooms (separate circulation) each over 20 m2. There are 25 cast iron ribs in one guest room (length 2 m) entrance up, exit down the same side, the top heats along the entire length and the lower the radiator, the colder, I will add that the neighbors upstairs have a hot house when I smoke and want to have a normal temperature . In a room. What to do, where to start so that the radiator gives more heat over its entire surface. I will add that on the second circuit, where in smaller rooms, kitchens, bathrooms there are smaller radiators, they are hot from top to bottom. Help;
  • #5 7640757
    12gucio
    Help: 23
    Rate: 178
    Hello!
    You have to go talk to your neighbors and choke their radiators. The heat takes the easier way and goes up, these are the laws of physics.
  • #6 7640803
    mirrzo
    Help: 441
    Rate: 2609
    Remove the head from the valves and press a few times on the little wire that sticks out of the valve. It should move slightly. Often this pin can "stuck"
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #7 7640981
    mcryb
    12 gucio what does "throttle their radiators" mean, because I don't really understand what this action is supposed to mean?
    mirrzo, I suspect that there is no small wire in the thermo valve, as I wrote above, the installation is of an old date and the thermo valve looks like an ordinary valve, either one or the other, although I am not sure
    12 gucio typo of course "choke"
    Added after 1 [hours] 48 [minutes]:
    12gucio Choke or screw on the thermostatic valve (neighbors) so that the radiator that is higher will consume less and then more hot water will go to the radiator that is on the lower level? does it make good sense?
    And below is a picture of my thermostatic valve, if you can call it that :)
  • #8 7642847
    12gucio
    Help: 23
    Rate: 178
    Hello!
    You think right, you need to screw it to the maximum at the beginning, when they start to heat you can gently unscrew it. You have a regular old-type valve. They had a throttle setting, maybe they are dirty. You will have some fun but there is light at the end of the tunnel. Good luck and be patient with the adjustment.
  • #9 7645313
    mirrzo
    Help: 441
    Rate: 2609
    You can call it what you want, but the thermostatic wheel did not even lie.
    EURO-DOM
  • #10 10188430
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    This valve is a HISTORIC. During the heating season, it is better not to rotate it, as it may start to leak, especially if it has not been moved for several years and the seal may have aged. However, if you try to turn it and it starts to leak from under the spindle, it means that you need to seal the gland. Then you need to unscrew the visible hood nut, remove the gland (with pliers), wind the tow (linen or hemp) well saturated with thread paste on the spindle axis, push it in, push the gland and tighten it with the hood nut. Orifice for these valves is traditional - changing the flow requires replacing the orifice, which involves the need to drain the water!!! Maybe the orifice is silted and therefore the radiator does not heat, but this also requires draining the water, because you have to at least unscrew the valve head and manipulate the wire to push the orifice. Since the water needs to be drained to change the orifice (or clog the orifice), it is better to simply drain the water and replace the valve with a modern thermostatic one (having a pre-setting, replacing orifice, which can be corrected at any time without draining the system).
  • #11 10209190
    mirrzo
    Help: 441
    Rate: 2609
    Zbigniew Rusek wrote:
    Orifice for these valves is traditional - changing the flow requires replacing the orifice, which involves the need to drain the water!!! Maybe the orifice is silted up and therefore the radiator does not heat, but this also requires draining the water, because you have to at least unscrew the valve head and manipulate the wire to push the orifice.
    Well, that's not entirely true.
    Here are pics of the valve "from the inside".
    You loosen the nut with a 30 wrench and a smaller one, probably 22, turn the head left-right to change the setting of the diaphragm to the hole inside the valve.
    EURO-DOM
  • #12 10209244
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    What mirrzo wrote is also like an additional "crinkling" (normally, a drilled metal disc is given as a ruff - often in the People's Republic of Poland they gave coins, just with the use of such valves). This shutter, when positioned on the side of the radiator, can effectively block the flow of water. So you have to set it from the opposite side. One correction. The nut is unscrewed with a size 27 wrench (preferably ring spanner) if it is a 1/2 inch valve.
  • #13 10209260
    mateos21
    bleed these radiators there should be a small valve put a container to it turn this valve when you hear air then wait for water to flow into the container just don't burn yourself
    Please correct spelling errors
    mod - mirzo
  • #14 10209262
    mirrzo
    Help: 441
    Rate: 2609
    Yes, drilled orifices were inserted, but on the return.
    As for the size of the key, it depends on its size - this one was 3/4, so it was size 30, but the sense of adjustment is the same. Often, after adjustment, these valves tended to leak if not tapered. He wasn't, he went to the steelworks.
    EURO-DOM
  • #15 10209788
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    I have encountered such drilled orifices just on the power supply, even in the block where I live (before thermostatic valves were installed by a certain company), but not only there.
The discussion revolves around the issue of radiators only heating at the top, with the lower sections remaining cold. The user reports uneven heating in multiple radiators within a multi-family apartment block, despite the regulator being set to maximum. Responses suggest potential causes such as blockages in the thermostatic valves, improper settings by neighbors, or issues with the installation. Recommendations include checking and adjusting the thermostatic valves, bleeding the radiators to remove air, and possibly addressing the orifices in the system. The conversation highlights the importance of proper valve maintenance and neighbor coordination in shared heating systems.
