Buddy, you're confusing the concept of UTP or FTP is a type of cable that can be used to make a patchcord. At home, a patchcord made of UTP cable will be ok. You only choose the right length.
That's right UTP and FTP are a kind of cable. A patch cord is a cable with terminals, for example RJ45, although it does not necessarily have to be twisted-pair cable - it can be a fiber optic patch cord.
The discussion clarifies the differences between UTP (Unshielded Twisted Pair) and patch cords in the context of Ethernet cables for connecting a router to a computer. UTP and FTP (Foiled Twisted Pair) are types of cables, while a patch cord is a pre-terminated cable, typically with RJ45 connectors. It is noted that a patch cord can be made from UTP cable, which is suitable for home use, and the choice of length is important for the application. AI summary based on the discussion. May contain errors.
