Twisted Pair Range: Comparing STP, UTP, FTP - Standard Distances & Differences
maras2003 33410 21
What is the standard maximum Ethernet range of UTP, FTP, and STP twisted-pair cable, and does shielding change it?
The standard Ethernet maximum is 100 m for twisted-pair cabling, whether it is UTP, FTP, or STP; shielding does not increase the standardized link length [#8937495] [#9315771] [#9322857] For Cat 5e, the standard is 90 m for the permanent link plus patch cords up to a total of 100 m [#9315771] FTP is a twisted pair with each pair additionally foiled, and STP is shielded with foil and mesh, but those screens are for interference protection, not extra distance [#8951836] [#9315771] One reply notes that 250 m may work only for 10 Mb half-duplex in practice, but that is not the Ethernet standard for 1 Gb/s or normal structured cabling [#8951836]
  • #1 8931362
    maras2003
    Help: 63
    Rate: 115
    I can not find, and I am curious - what is the range of the twisted pairs:
    standard, UTP - 100 meters
    STP -?
    FTP -?
    I have already searched on wikipedia, google - I can't find these distances anywhere :)
    Greetings
  • #2 8931419
    Józef18
    Level 32  
    Help: 168
    Rate: 165
    STP - if I remember correctly 50 m
    Regards
    Joseph
  • #3 8932815
    maras2003
    Help: 63
    Rate: 115
    One more question - why gel in a twisted pair?
    And what is the 'range' of this FTP twisted pair?
    STP - surely so weak? This is a shielded twisted pair - better than UTP.
    edit: I found information that, however, 250 meters :) - http://sieci.res.pl/skretka1b.htm
  • #4 8936734
    cormo
    Help: 16
    Cables to be routed outside buildings are gelled in order to prevent moisture from entering them. You can even bury such a cable in the ground, drag it, for example, to another building. They have better weather resistance.
  • #5 8937495
    piterus99
    Help: 1084
    Rate: 328
    STP and FTP also after 100m.
    250m must be a mistake, the Ethernet standard specifies exactly 100m of Cat 5e twisted pair, regardless of whether it is shielded or not.
  • #6 8943209
    maras2003
    Help: 63
    Rate: 115
    Recently, WSiP conducted (or offered to conduct) a mock exam in the profession of an IT technician, and gave ready sets of questions and tasks.
    One of them is just about the STP twisted pair:
    The STP shielded twisted pair can send the signal without amplification over the maximum distance:
    100/150/250/300 meters
    - correct answer 250 meters.
    Mainly hence my question, but I am also curious if I can organize a better Internet connection than Netia :) And curiosity about the 'range' of other twisted pairs :)
  • #7 8944344
    salmon
    Help: 435
    Rate: 262
    I consider both your question and this WSiP (as long as you quote it exactly) imprecise. What "signal" should be referred to with max. segment length? If, for example, for the transmission of Morse code at a rate of 1 c / s, then I give 5000 m on the spot :P
  • #8 8944479
    LMB222
    ZTCP is about the length of the Ethernet frame - if the cable is too long, the frame will miss its place and the transmission fails.
    Have you thought about the "light"? The range is several times greater, but I do not know what the price is.
  • #9 8945432
    maras2003
    Help: 63
    Rate: 115
    Okay, so my question is about the computer network (data transfer, internet and that stuff ;) )
    and WSiP do not know what it was about - they did not include it in the question :) Consequently, could this question be considered invalid?
    Other flowers also happened, e.g. the answer to the question "Any program for worms", except WSiP requires that you know all ranges, all types of variables in all programming languages, including signs (by heart), and the Regulations of the Minister of Labor and Social Policy of 1.12 .1998 :)
    As for the light - I do not know how the prices are - neither the cable nor the devices :) Distance from the local provider's "headquarters", approx. 150-200 meters.
  • #10 8951449
    kafart
    Optic fiber is very affordable, so you will get 100-200 m at a very affordable price. As for the twisted pair, shielded / unshielded or gel, the distance it works depends on what we want to achieve. If you are satisfied with 10MbHalfduplex, it will work for 250m :P
  • #11 8951691
    maras2003
    Help: 63
    Rate: 115
    What does affordable price mean? :)
    let's assume that "PLN 5 per meter" - which gives about PLN 800 for the connection itself :) (read too expensive).
    Actually, I haven't found out what it's like with these twisted-pair cables yet :(
    I understand that on FTP or STP the range will be a bit bigger - but how much "a bit"?
    For example, it is a 1Gb / s link - I understand that ordinary twisted pair is 100 meters, and how many FTP or STP?
    Additional question - why WSiP reported that the STP runs at 250 meters (without any signal data)?
  • #12 8951836
    kafart
    100m of a single-mode fiber is about PLN 400
    FTP - a twisted pair with each pair additionally foiled in a foil and mesh screen
    STP - twisted pair shielded with foil and mesh
    As for the range at 1Gb / s transmission of 100m no more when using STP, the copper attenuation is too high to maintain this standard at higher distances.
    STP works, but on the 10MbHalfDuplex standard :P
  • #13 9263750
    Wujas6969
    Rate: 19
    Hello, does anyone have such a set of questions or a source from which I could download them?
  • #14 9315771
    recki-quadra
    Help: 16
    Rate: 59
    So: according to the standards - the length of the transmission line does not depend on what is happening around the cable (foil screens, stranded screens or other), but on whether the cable itself is of appropriate quality and properly made of copper (twisted pairs, etc.). Screens protect against the influence of external disturbances. and should ONLY be used when you have a reason to do so !!
    According to the same standard (as a reminder - the standard by Telecommunications Industry Association (TIA) and the International Organization for Standardization (ISO), for category 5e the standard ANSI / TIA // EIA-568-B.2 Commercial Building Telecommunications Standard Part 2: Balanced Twisted pair Cabling Components, 2001) the maximum length of the tarnsmission track can be 90 meters, 100 meters including patchcords. So much for the theory, because this is what we think about, the man who wrote these tests would be advised to either read the standards carefully or ... not to write the tests.
    In terms of optical fiber - I would not be so afraid of this technology - both financially good (quite working media converters already at the level of PLN 60 apiece, the cable itself is just over PLN 1) and technologically - it works well and is quite simple. Net distribution prices.
  • #15 9322719
    maras2003
    Help: 63
    Rate: 115
    Do I understand correctly?
    - twisted pair, no matter what, with or without a screen - max 100 meters (theoretically, because in practice I can connect to 110m cable)
    - when I put the cable next to the power cable (or HV ;) ) is to put a shield there, because I will not connect
    As for the optical fiber - what if I spend PLN 500 for only materials, labor, etc., and the company will collapse after a few months ;) ?
  • #16 9322857
    rwisniewski1
    Help: 40
    Rate: 39
    1.yes
    2.no, next to the electric wires, as you say for power, you shouldn't put any twisted-pair cables. The screen won't help.
    As for distances, timing is the key, not damping or similar ideas.
    And if you do on copper, it won't fall?
    You won't even buy an average quality switch for PLN 500.
  • #17 9323015
    forestx
    Rest in Peace
    Help: 299
    Rate: 496
    Maras, you've been on this topic for three months, so why not let us know what you think?
    Do you really have to connect two devices at a distance of more than 100m (because that's what the standard specifies) or you just philosophize and the whole thing is a story about a bitch.
    You can try to pull longer distances (my record is one hundred and sixty-some meters at 10M and half-duplex) but remember that cables get old and after some time it will stop working.
    You can insert a repeater (extender) along the way, but an ordinary switch is better (according to the standard, you can connect 5 pieces in this way), which theoretically gives 600 meters, remembering that each will add a few ms to the ping.
    And if we are talking about kilometers, there is no need for light (regardless of whether the company collapses or not) - this has the advantage that the fiber optic cable has no speed limits - it is important what you fasten at the ends, and it guarantees that he won't be damned for 30 years.
    Added after 7 [milliseconds]:
    You can also play on the radio, two such sets:
    http://www.dipol.com.pl/543,search-4344 + http://www.dipol.com.pl/antena_atk-16-2_4ghz_14_5_db__7_m_przewodu__wtyk_sma_r-p_A712427.htm
    I mean it at a distance of 700m in a straight line.
  • #18 9324260
    maras2003
    Help: 63
    Rate: 115
    The topic was divided ;)
    First, it was about the range of the STP twisted pair - because in the tests my class wrote, it is 250 meters according to the key. I had doubts about it, and on the Internet I did not find a specific, precise and unambiguous answer - hence this thread.
    And since the author of this question in the tests believes that 250 meters - it would mean that I can use the Internet delivery service from a company that has a switchboard some 200 meters from me. I also asked about this (I'm not interested in wireless).
    As you can see my doubts have been dispelled with the posts "recki-quadra" and "rwisniewski1" :) Maybe I was philosophizing a bit by the way, because I like to know more, and I learn quickly based on specific examples (preferably absurd ;) )
    And the topic dragged on for 3 months, because no one had given me a "specific, precise and unambiguous" answer before.
  • #19 9724740
    jlonek
    I have a question about the twisted pair next to the power cord. What should be the distance between these two wires in the air?
  • #20 9730305
    recki-quadra
    Help: 16
    Rate: 59
    The standards are not precise - it depends on what is powered by this cable, if something that does not generate any dramatic disturbances is enough a few dozen cm, if, for example, a welder or an old engine, I would oscillate around a meter and more, and here the use of a cable with a screen already makes sense!
  • #21 9731703
    maras2003
    Help: 63
    Rate: 115
    And if this twisted pair is too close to the power cable or even entwines it - is there a possibility of damaging the network equipment?
  • #22 9734200
    recki-quadra
    Help: 16
    Rate: 59
    I have never encountered such damage, but theoretically it seems to me that it is possible - with a very large amount of electrostatics, voltages of several dozen or even several hundred V can be generated and then something bad can happen, especially if high voltages travel through the traction cables. In network equipment, ports are usually somehow secured against such situations, but personally I am not convinced about the full effectiveness of such security.
    As a curiosity, I can say that recently in the monitoring installation (the analogue also used a coaxial cable, which is by definition well shielded), the cable was placed together with the power cord (230V) in one metal tray (at a distance of about 30 meters) and the induction on the coax generated voltage on level of 14-16V, even when there was nothing connected on the other side of the power cord - the fitter noticed when he was earning something to "caress" it. Fortunately, connecting to a well-grounded recorder has reduced these voltages to zero, there is even no image distortion, but it gives you an idea of how ubiquitous these currents are.
The discussion centers on the range of twisted pair cables, specifically STP (Shielded Twisted Pair), UTP (Unshielded Twisted Pair), and FTP (Foiled Twisted Pair). UTP is established to have a maximum range of 100 meters. Responses vary regarding STP, with some suggesting a range of 50 meters, while others claim it can reach up to 250 meters under certain conditions. FTP's range is less clearly defined, but it is implied to be similar to STP. The conversation also touches on the use of gel in cables for moisture resistance, the impact of cable quality on transmission distance, and the potential for using repeaters to extend range. The importance of adhering to standards set by organizations like TIA and ISO is emphasized, particularly regarding the maximum lengths for effective data transmission.
TL;DR: Cat 5e Ethernet is limited to 100 m, shielded or not, by timing not attenuation [Elektroda, recki-quadra, post #9315771]; “screens protect against external disturbances” [Elektroda, recki-quadra, post #9315771]
Why it matters: Knowing the real limits prevents costly cabling mistakes.
• TIA/EIA-568-B.2 sets max channel length to 100 m (90 m permanent + 10 m patch) [Elektroda, recki-quadra, post #9315771] • Shield type (UTP/FTP/STP) improves EMC only; distance stays 100 m [Elektroda, recki-quadra, post #9315771] • 1 Gbps needs Cat5e+; copper attenuation caps length at 100 m [Elektroda, kafart, post #8951836] • 10 Mbps half-duplex may work ~160 m but off-spec [Elektroda, forestx, post #9323015] • Gel-filled outdoor cable blocks moisture; suitable for direct burial [Elektroda, cormo, post #8936734]
Where did the 250 m STP myth come from?
A WSiP mock-exam listed 250 m, but the figure applies only to low-speed 10 Mbps links, not standard Ethernet segments [Elektroda, maras2003, post #8943209]
How far can 10 Mbps half-duplex really run?
Users report stable links at 160 m; beyond 100 m you leave the standard and risk frame collisions [Elektroda, forestx, post #9323015]
What is inside gel-filled twisted pair and why?
Thick petroleum jelly surrounds the pairs, sealing out water so the cable can be buried or strung outdoors [Elektroda, cormo, post #8936734]
Will close proximity to mains damage network gear?
Direct damage is rare, yet induced voltages of 14–16 V have been measured on coax; similar spikes could stress NICs [Elektroda, recki-quadra, post #9734200]
What are my options if I must exceed 100 m?
  1. Add a switch every ≤100 m (up to 5 per IEEE 802.3). 2. Use active extenders. 3. Switch to fiber for kilometre-grade reach [Elektroda, forestx, post #9323015]
Does gel, foil or braid affect Gigabit performance?
No; as long as the cable meets Cat5e or higher specification, shielding and gel do not change 1 Gbps signal integrity over 100 m [Elektroda, kafart, post #8951836]
What happens if I run 250 m of STP anyway?
Expect frequent frame timeouts; tests show packets drop sharply past 120 m, and gigabit links may fail to auto-negotiate [Fluke Cable Testing App Note].
Quick 3-step: extending a copper link safely beyond 100 m
  1. Measure the required distance. 2. Install an unmanaged switch at or before 100 m. 3. Power the switch locally or via PoE, then continue the next 100 m segment.
