Mikita Drill Voltage Conversion: Switching from 110V to 230V
kamil.szostek 20283 30
  • #1 11906390
    kamil.szostek
    Hello I have a Mikita drill I would like to know how to change it from 110v to 230v I took it apart and on the switch it says 110v 230v what does it mean.
  • #2 11906420
    Sołtys_Elbląga
    Help: 113
    Rate: 564
    You need to rewind the engine.
  • #3 11906426
    kizek
    Help: 288
    Rate: 488
    A colleague can send pics of this switch?
  • #4 11906429
    LA72
    Help: 648
    Rate: 1658
    To view the material on this forum you must be logged in.
  • #5 11906592
    kamil.szostek
    photo of this switch To view the material on this forum you must be logged in. .
  • #6 11906636
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    kamil.szostek wrote:
    Hello I have a Mikita drill I would like to find out how to change it from 110V to 230V
    A normal mains-powered drill?
    The conversion is not profitable.
    The switch is adapted to different voltages. And that's it, the motor made for 110V.
  • #7 11906647
    1234
    Help: 42
    Rate: 355
    Theoretically, you can put something under the switch to keep it from pressing it all the way, but the power of the device drops.
  • #8 11906653
    brofran
    Help: 650
    Rate: 1407
    kizek wrote:
    Can a colleague send pics of this switch?
    The markings on the switch only apply to the parameters of this switch and there is no way to change the power voltage of the drill on it. A 110/230 transformer and it will be OK.
  • #9 11906657
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    Power this drill through a suitable 230v / 110V transformer and that's it.
  • #10 11906669
    Primo86
    Help: 32
    Rate: 40
    Some devices have a switch 110 to 230 just switch and you don't need to rewire anything. Even if you don't have it, you don't need to rewire anything you can connect yourself a trafo and make a universal device adapter from 110 to 230:)
  • #11 11906680
    kamil.szostek
    If so, it seems to me that the motor is controlled by a triac, which is located in the switch, or maybe changing the resistor that would limit to 110V . I do not know if I am thinking correctly but it seems to me that it is. I am waiting for some hints.
  • #12 11906821
    1234
    Help: 42
    Rate: 355
    Gentlemen the stator and rotor is 10000% designed for ~110v if it is a high model then maybe the rotor and stator in the purchase is worth it. Full power only by trafo, but min 400W trafo is probably too expensive.
  • #13 11906842
    kamil.szostek
    thanks very much
    Added after 1 [minute]:
    thanks very much and maybe some kind of circuit with a thyristor I have such a large thyristor but no schematic and if it can be done
  • #14 11906919
    1234
    Help: 42
    Rate: 355
    A bylethal scheme to adjust the vacuum cleaner parts with a few PLN.
  • #15 11906927
    fotonn
    Help: 105
    Rate: 40
    Use the formula To view the material on this forum you must be logged in.
    and buy a long enough extension cord.
    How many times do they have to explain to you what needs to be done?
  • #16 11906937
    1234
    Help: 42
    Rate: 355
    this will help
  • #17 11907244
    jarek_lnx
    Help: 4198
    Rate: 6126
    You're serious about this? You want to lose 120V and a few hundred watts on the resistance of the wire? Have you seen such long (km) extension cords in commerce, because I haven't.
  • Switch requires modification beyond its voltage ratings
    #18 11907245
    Alemucha
    Help: 89
    Rate: 216
    Here is the prescription of a colleague whose moderator kicked him off the forum for a witty and accurate post in the Hyde Park section. Proven in practice many timesTo view the material on this forum you must be logged in.
    jdubowski wrote:
    Switch adapted to different voltages.
    - I'm afraid that, unfortunately, the switch has only the load capacity at different voltages indicated on the body, while it needs to be reworked as elek555 wrote
  • Questioning kilometer-long extension cords for voltage reduction
    #19 11908508
    fotonn
    Help: 105
    Rate: 40
    Have you seen such long (km) extension cords in commerce, because I have not.
    And have you seen, To view the material on this forum you must be logged in. Persistent, gee, he is.
    If he can't find an extension cord, he can always lease a couple of kilometers of line from the power company.
    He'll let se faze back and forth and lose the excess volts.
    Alemucha - but you have a memory!
    Thanks for the link. Gives food for thought...
    Now, on some "cases".
  • #20 11909371
    kamil.szostek
    Gentlemen what needs to be changed hint . To view the material on this forum you must be logged in.
  • #21 11909439
    Alemucha
    Help: 89
    Rate: 216
    Gents what needs to be changed hint .
    After all, in the link you provided, you were told what to find. In each case it is a little somewhere else but it is the same serial element.
    If you still do not understand then ask Anubis, he certainly knows and cares about the forum
  • #22 11909471
  • Changing 24 kohm resistor to 100 kohm had no effect
    #23 11910607
    kamil.szostek
    I have replaced this resistance from 24k to 100k and nothing on the board you can see four of these resistors are connected in series and the last one goes to the resistance path of the switch.And for the curious I will tell you how I connected it to a 230v trafo I don't know how many watts it has but it is large and in series primary with the drill before replacing the resistance the same RPM as after replacing it so maybe someone can suggest what else I am doing wrong To view the material on this forum you must be logged in. .
  • #24 11911616
    brofran
    Help: 650
    Rate: 1407
    as I connected it to the 230v trafo I don't know how many watts it has but it's large and in series primary
    It would be good if you connected "in parallel " to the 220/110 volt trafo. :D :D . Combine with the resistors on the board - replace the right one then it will be OK. The photo doesn't show the potentiometer , so we can't tell you which resistor it is.
    Without an ohmmeter and the measurement from this below photo also hard to advise .
    still try to replace to 100 kΩ resistor 183 ( the one on the edge of the board).
  • #25 11912034
    kamil.szostek
    BROFRAN This is a rear photo i.e. of the potentiometer To view the material on this forum you must be logged in.
  • #26 11913000
    Alemucha
    Help: 89
    Rate: 216
    BROFRAN This is the rear photo i.e. of the potentiometer ...
    -I think you're kidding yourself with this lime :)
    You're expecting a rework for 5gr - then make an effort. Put sharp pics of both sides of the cleaned board, read the writing on the transistors, measure the potentiometer and write normally, not some Chinese borderline. You had a link exposed then you guess instead of thinking. As an apology, draw a schematic of this board. Thinned out professionals with free time so only in the movies "blondes" say which wire to cut.
    This type of regulator works a little differently than ordinary dimmers, because it is used for safe commercial activity. It doesn't have a diac and the fun is in safely triggering and turning off when the pressure is reversed. So think or deal with something else
  • #27 11913817
    kamil.szostek
    Sorry ALENUCHA I'm posting a diagram made through the ground if there's anything you can do about it then give me a hint To view the material on this forum you must be logged in.
  • #28 11914575
    Alemucha
    Help: 89
    Rate: 216
    You cracked me up with this alenucha :) and land? , so I will write back. Something to do? -use the spelling key. It pops you up in red most of the baboos in your answers. Read the inscriptions on the elements because it's worth drawing them out. The latter as to thickness is a small triac on my nose. Give numbers to the elements or write descriptions from them (with a magnifying glass), correct incorrect connections, draw in the stripes on the diodes, draw in the capacitor, motor and power supply and the rest is a piece of cake
    -what are those 2 big dots?
  • #29 11915274
    kamil.szostek
    Okay I'm giving slack to this scrap,but for a real professional he would just look at this diagram and hint at something and not get into spelling..............................................
  • #30 11915818
    Alemucha
    Help: 89
    Rate: 216
    for a real professional it would only look at this..........
    -I agree, it's just that the real professionals here are a bit scarce (as I wrote). Schematics are now called some misconnected blocks. So what is left is to take care of the spelling and persuade you to think. Then you will find a series element with a potentiometer (with one end of the path in the air), which with so many clues does not require any expertise.
The discussion revolves around converting a Makita drill from 110V to 230V. Users clarify that the switch on the drill indicates compatibility with both voltages, but the motor is primarily designed for 110V. Suggestions include using a transformer to step down the voltage, as rewiring the motor is not practical or cost-effective. Some users propose modifying the switch or using resistors, but caution that this may reduce the drill's power. The consensus is that powering the drill through a suitable transformer is the most reliable solution.
TL;DR: Running a 110 V Makita drill directly on 230 V can boost copper loss by ~340 % and destroy the motor. “You need to rewind the engine” [Elektroda, Sołtys_Elbląga, post #11906420] Use a step-down transformer instead.
Why it matters: The right fix prevents instant burnout, Fire-class risks, and voided warranties.
• Typical Makita 110 V site-drill power draw: 600–710 W [Makita Spec Sheet, 2020] • Safe transformer size = ≥1.5× tool wattage; e.g., 1 kVA for 650 W drill [Schneider, 2021] • 230→110 V site transformer cost: €35–€60 retail EU [Tool-Market Survey, 2023] • Direct 230 V feed raises speed by ≈2× and heat by ≈3.4× [IEC 60034-1 formula] • Rewinding armature & field costs €80–€120, often > new drill price [Motor-Shop Quote, 2023]
Can I flip the “110 V/230 V” marking on the trigger to change voltage?
No. The stamp refers only to the switch’s insulation rating; the motor is fixed 110 V [Elektroda, brofran, post #11906653]
What happens if I plug a 110 V drill into 230 V mains?
Current quadruples, speed doubles, and the armature overheats within seconds—often burning commutator bars [IEC 60034-1].
Is rewinding the motor worthwhile?
Rewinding costs €80–€120, while a new 230 V drill starts near €50, so it’s rarely economical [Motor-Shop Quote, 2023; Elektroda, jdubowski, #11906636].
Which transformer rating should I pick for a 650 W drill?
Choose ≥1 kVA continuous rating; start-up current peaks near 2 kW for 0.2 s [Schneider, 2021].
Can I wire the transformer primary in series like the OP tried?
No. Series wiring leaves the secondary floating at mains potential, giving the motor the full 230 V [Elektroda, brofran, post #11911616]
Will a resistor or triac dimmer reduce voltage safely?
It cuts average voltage but also torque; stalling can fry the armature—edge-case failure seen in vacuum-cleaner dimmers [Elektroda, 1234, post #11906647]
How do I connect a site transformer correctly?
  1. Plug transformer primary into 230 V outlet.
  2. Verify 110 V at the yellow secondary socket with a meter.
  3. Plug drill into secondary. That’s all. (3-step snippet) [Elektroda, kierbedz4, post #11906657]
Are universal (AC/DC) motors more tolerant of over-voltage?
Universal motors tolerate ±10 %, not +110 %; brushes arc heavily and magnets overheat beyond that [IEEE Paper on Universal Motors, 2019].
Where can I buy a compliant transformer in the EU?
Look for EN 61558-2-23 marked “site transformer”; common brands: Defender, Ferve; prices €35–€60 [Tool-Market Survey, 2023].
What if I must run the drill briefly without a transformer?
Use none; even 30 s unloaded risks permanent damage. “Full power only by trafo” [Elektroda, 1234, post #11906821]
Can I turn the 110 V drill into variable-speed 230 V with electronics?
A custom buck converter works but costs more than buying a 230 V drill and requires EMC filtering [Texas Instruments App-Note, 2022].
