Converting DeWALT DCB101 Charger from 120V to 230V: Capacitor and Mosfet Limitations
zzeus 31992 14
How can I convert a DeWALT DCB101 120V charger to 230V, and which components need to be changed?
To convert it, the thread suggests changing the primary-side parts to 230V-rated versions: one modified charger used R4 and R5 as 5W 0.33Ω resistors, Q1 as an 11N80C3, and the main electrolytic as 120µF/400V; another similar DCB105 sample used 0.36Ω 5W primary resistors and a 150µF/400V capacitor [#13801869][#13479386] One user also reported that using the wrong transistor damaged Q1 and IC31, and IC31 was identified as 3845B, so the switch/control parts need to be rated correctly [#14011289][#14043142] However, another reply warned that a transformer designed for the 120V rectified bus may not survive the ~320V bus on 230V mains, so replacing only the capacitor and MOSFET may not be enough and a fully working 230V conversion was not confirmed [#13757297]
  • #1 12982330
    zzeus
    Hello, I have a DeWALT DCD985M2 20V max drill with an original 120V charger. I would like to convert it to 230V, I sent a question to the manufacturer, what is the limitation. In response, I found out that the capacitor and the mosfet are the main limitation. I wonder if something else should be replaced and if I don't have to do anything with the transformer (rewind).
    I found a similar topic topic2645725 except that this charger is not a toy that needs 30W, but about 200W, besides, I would rather connect the power supply directly to the socket than carry an additional transformer with me.
    To the point, the capacitor marked in the photo is 220 uF 200V and the mosfet is 6R299P.
    Converting DeWALT DCB101 Charger from 120V to 230V: Capacitor and Mosfet Limitations Converting DeWALT DCB101 Charger from 120V to 230V: Capacitor and Mosfet Limitations Converting DeWALT DCB101 Charger from 120V to 230V: Capacitor and Mosfet Limitations
    Unfortunately, all the integrated circuits have been polished by the manufacturer, so it will be difficult for me to read more markings.
  • #2 12982822
    ciasteczkowypotwor
    Help: 590
    Rate: 575
    There is a topic on the electrode with a description of what to change to make it work. Look for.
    From what I remember, it was about the 18V model
  • #3 12984165
    zzeus
    Thanks for the info, I suspect it's about the topic topic7751539 unfortunately this is a completely different NiCd charger made by Delta, mine is for Li-ion made by Phihong.
  • #4 12984451
    ciasteczkowypotwor
    Help: 590
    Rate: 575
    An inverter, like an inverter, you are basically interested in the primary side. Look what changed there, then compare it to yours.
  • #5 12989392
    zzeus
    Unfortunately, the original side does not even differ, but it is completely. However, I am wondering about the place on R4 and R5 which is compact on this PCB. There is a similar looking DCB105 charger model that works under 230V, maybe the difference is only in the presence of these two resistors?
    So I quickly drew a piece of the original page and a diagram from that thread for comparison.
    Edit
  • #6 13479386
    Jingiel
    Help: 30
    Rate: 110
    At the moment I have a DCB105 charger on the table and the construction is similar to yours. The primary resistors are 0.36? 5W. If you need anything, speak up. The transistor in mine was damaged, but the charger still does not work properly. After connecting the battery, the LED blinks to show the charger failure. The capacitor for me has a value of 150 uF / 400V. However, this kind of mosfet is actually a STPS 20150CT diode, a schottky diode 150V 2x10A TO220. You probably need to replace it with a diode with a higher voltage.
  • #7 13685594
    airbob
    Help: 29
    Rate: 14
    As my friend brought me such a DCB101 charger and I am tired of converting it to 220V, I have a question, has anyone already done it?
    At the moment, I do not have a hole with a hole at hand to unscrew it and look at it. I wonder if the whole thing will not be a hit, or should it not have a different transmission?
    You have a diagram of one of the DCB101 or DCB105 chargers.
  • #8 13756549
    profesorek_96
    Rate: 11
    I am struggling with a similar problem as the conversion of this charger.
    What the correct conversion should look like. What needs to be replaced to work on 230v?
  • #9 13757297
    airbob
    Help: 29
    Rate: 14
    I gave up.
    I am not a specialist in converters, but I have some idea and, for my common sense, a transformer that has the primary winding adapted to voltage keying (160V after straightening) will not withstand 320V (after straightening).
    Somehow, no one boasted a working remake. Maybe they didn't last very long.
  • #10 13757897
    profesorek_96
    Rate: 11
    So what is the replacement for the DCB101 to be able to charge the 20v batteries? Will DCB105 work?
  • #11 13801869
    erykeryk
    Knowing that I have a converted 120 / 230V charger, I unscrewed it and the only differences I notice are:
    1. R4 and R5 5W 0.33ohm resistors
    2. Q1 is 11N80C3 ... about 8 zlotys
    3. C3? (large electrolyte) 120u / 400V
    4. Network cable as standard ...
    GOOD LUCK
  • #12 13828072
    ronwald
    Help: 85
    Rate: 68
    It is easier to buy a 230/120 transformer for a few pennies :)
  • #13 13830019
    erykeryk
    even easier to go to the states - nothing needs to be changed ... :)
    However, the Trafo 200W is an additional device, it will not enter the company's suitcase - and there is also weight.
  • #14 14011289
    szczurekbuc
    during the modification, I used a weak transistor and after what 10 minutes of charging the charger was damaged. The Q1 transistor and the IC31 chip went. I have a question if any of you could read me the symbol of IC31. Thank you in advance for your answer.
    Best wishes
  • #15 14043142
    JANUSZ 1
    Help: 9
    Rate: 11
    ic31 3845b
The discussion revolves around converting a DeWALT DCB101 charger from 120V to 230V, focusing on the limitations posed by the capacitor and mosfet. Users share insights on necessary modifications, including potential replacements for components like resistors (R4 and R5), the mosfet (6R299P), and the capacitor (220 uF 200V). Comparisons are made with the DCB105 model, which operates at 230V, suggesting that differences may lie in specific components. Some participants express skepticism about the feasibility of the conversion, citing concerns over the transformer’s ability to handle increased voltage. Others recommend using a transformer instead of modifying the charger directly. The conversation highlights the technical challenges and considerations involved in such modifications.
