Connecting Makita HP 2040 Drill Switch: Wiring & Switch Input Guide with Images
maly939 25557 3
  • #1 16465920
    maly939
    As in the subject, I need help how to connect the drill switch Makita HP 2040 (described wires and switch inputs in the pictures).
    Connecting Makita HP 2040 Drill Switch: Wiring & Switch Input Guide with Images Connecting Makita HP 2040 Drill Switch: Wiring & Switch Input Guide with Images
  • #2 16466182
    qadam12
    Help: 62
    Rate: 254
    My friend draws numbers.
  • #3 16468010
    maly939
    Thank you for the diagram but unfortunately the drill does not work (I checked this connection but I was surprised by the power supply connection - usually 1.3 where the contacts are with screws).
    Anyone have any other idea?
  • #4 19691105
    czarnykrzysiek1
    A colleague's drawing numbers.
