Acer Aspire 5732ZG Windows 7: Writing Polish Characters (ó, ś, ż, ą, ź, ń, ł, ę) with Left Alt
zardes 63186 16
How can I type Polish characters in Windows 7 when Alt-based shortcuts are being intercepted by another program?
Polish letters should normally be entered with the Polish programmer keyboard using the right Alt, or with left Ctrl+Alt as an equivalent if nothing is intercepting the shortcut [#10902605][#10902740][#10905328] In this case the problem was not Windows itself, but a tray program that was grabbing the key combinations: the Broadcom wireless tray app, WLTRAY.EXE [#10910631] The practical fix is to find and disable the program that is catching the shortcut by closing tray icons one by one and testing the Alt combinations again [#10909580][#10910631] If ATI CCC is installed, it can also steal some Alt shortcuts, so open CCC in Advanced mode and turn off Hotkeys by unchecking “Enable hotkeys” [#10909580][#10905328]
  • #1 10902490
    zardes
    I have a problem with writing Polish characters such as "ó, ś, ż, ą, ż, ź, ń, ł, ę, ń"
    but I have the option of writing these characters with the right Alta (except ae, ę)
    I read something about the problem with ATI CCC but I can't find hotkey options here. I still read about the Polish.reg file, but I can't find it on the Intel website either, the links have expired. When I have nothing turned on on the 1st plan, i.e. I have the desktop turned on and I press the Alt + character combination, the system will either make a sound or do nothing, otherwise it looks different in other programs, e.g. in chrome, the Alt + e combination I open Settings.
    Please help, I don't know what to do, can I return to the factory settings? just if it doesn't delete my programs and files.
    jkbgajda
    Help: 36
    Rate: 26
    What is the operating system?
    Since when has this been happening?
  • #3 10902511
    zardes
    I added what operating system it is, a
    more specifically Windows 7 Home Premium
    I've been struggling with this for a month now, I don't remember what was the reason
    otapi
    Help: 86
    Rate: 103
    Since I remember, in Windows, Polish characters were always under the right ALT, not the left one.
    jeryw
    Level 19  
    Help: 23
    Rate: 26
    In Windows, the Polish characters for the selected keyboard are selected by the programmer's Polish using the right Alt + letter key combination, any shortcomings may be caused by the operation of programs using the same shortcut, you need to run various programs to check which shortcut is used and in the program settings or disable it in general keyboard shortcuts using the right Alt-a or change it so that the letter with the Polish diacritical mark is not used, e.g. m, b, k, j, h.
    jkbgajda
    Help: 36
    Rate: 26
    Right.
    Polish signs are always under the right alto.
    Do you want to rearrange them to be under the left?
  • #7 10902714
    zardes
    I'm sorry, I made a mistake because, so that I could write with Polish characters, I installed a hotkey program and only on the left one I could assign Polish characters (not all) and hence this mistake is about the right one (I can't write it)
    otapi
    Help: 86
    Rate: 103
    If you don't find a solution, you can use left Alt + Ctrl + letter, it works exactly like right Alt + letter.
  • #9 10905244
    zardes
    otapi wrote:
    you can use left Alt + Ctrl + letter combination, it works exactly like right Alt + letter.
    This combination does not work :(
    I still don't know what to do
    delic
    Help: 11
    What's your keyboard set? Should be a polish developer - switch between default keyboards left ctrl + left shift. Press ctrl + shift and try Polish fonts. CCC from ATI caused only the lack of the letter ć because the right alt + c opened the card management.
  • #12 10908966
    zardes
    delic wrote:
    What's your keyboard set? Should be a Polish programmer
    Yes, I have the Polish language of a programmer
    Matuzalem wrote:
    I wrote a few posts above that I want to have the missing diacritics set as it should be in win 7, i.e. the right Alt, but I will try to work something with this program
    Matuzalem
    Help: 1653
    Rate: 1101
    zardes wrote:
    A few posts above ...
    zardes wrote:
    ... I have the option of writing these characters with the right ...
    On the other hand, without the knowledge of the hardware (in terms of drivers) and the dedicated software you use (although not only it has to come into play) it is impossible - i.e. probably "google" would do something, but it can be tedious due to the lack of data - write directly what and where to modify, in order to get a pair of "bits" by default.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #14 10909518
    zardes
    I'm sorry, I am not so circulated in Computers, but if you write what and where it is, I will try to write everything that is needed :)
    otapi
    Help: 86
    Rate: 103
    If it is really the Ati controls, fire CCC and if you are in Basic mode, switch to Advanced and at the top you have the Hotkeys button, turn it off and see if anything changes (uncheck the bird next to enable hotkeys).
    BTW. see what icons you have next to the watch ... close everything you can and see if something changes ... maybe you will find out what program causes it, then it will be easier to say something specific.
  • #16 10910631
    zardes
    It was the easiest way, and it worked :) now I know what causes these signs to be missing.
    The pest is:
    WLTRAY.EXE Broadcom 802.11 Network Adapter Wireless Network Tray Applet
    Now I have to figure out how to fix it
  • #17 14851684
    mirkol
    That's what it works and it pisses me off a lot how to change to the right alt. In 8.1
The discussion revolves around the difficulty of typing Polish characters (ó, ś, ż, ą, ź, ń, ł, ę) on an Acer Aspire 5732ZG running Windows 7 Home Premium. The user reports that while they can type these characters using the right Alt key, they are unable to do so with the left Alt key. Responses indicate that Polish characters are typically accessed via the right Alt key, and suggest potential conflicts with other software using similar shortcuts. A hotkey program was installed to enable left Alt character input, but it did not resolve the issue. Users recommend checking keyboard settings, disabling conflicting hotkeys in the ATI CCC software, and using alternative key combinations. Ultimately, the user identifies that the WLTRAY.EXE process from the Broadcom wireless adapter was causing the issue, and seeks further assistance in resolving it.
