Autodata 3.39 Runtime Error 217 at 004bb10D on Windows 7: Solutions for Running & Compatibility
gsekulski 59538 7
  • #1 12078417
    gsekulski
    Rate: 213
    Hello. I purchased Autodate 3.39. I spent a lot on her and I have a problem. When I try to run, I have a "runtime error 217 at 004bb10D" error. Windows 7. It does not help either to run as an administrator or in compatibility mode with xp wines. Does anyone know how to run it?
  • #2 12093641
    diseasekowalski
    Help: 180
    Rate: 189
    If the colleague bought legally, please contact the autodata support.
  • #3 12278563
    doomek1
    Rate: 19
    1. Uninstall the old Microsoft Visual C ++ 2008 Redistributable packages so that there are no 2 (x86 and x64) and install a new version from 2010. Here is the link to the source with the correction to the problem:
    http://www.microsoft.com/en-us/download/details.aspx?id=11895
    And as for the support of this company, you know, you paid and have deep respect - old media should withdraw from sales - now the big problem is with windows 8. Well, but this is another tale for another :)
  • #4 12279143
    gsekulski
    Rate: 213
    thanks for help :) have already :) problem :) some cracks, patches or something pulled from the :) and it comes :) In total, I have somewhere or legally did it, I paid and I did my work. With this support they are like with the Windows help system, no whip will help you.
  • #5 13193797
    pawlus_st
    Hello, I'm refreshing, I'm also trying to install autodata 3.38 and I get the same error .. Can a colleague gsekulski help?
  • #6 13194980
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Did you do what doomek1 wrote?
  • #7 13196582
    gsekulski
    Rate: 213
    Hello, Kolegów. Damn, I did this autodata, but it has been a long time and it's hard for me to remember what I was doing right now. I combined something with Microsoft Visual C + + because I did not want to run on any version and downloaded the crack and some three entries to the registry which in the right order added and moved to Windows 7. In total, you can find fault with me but how to buy legally and it's not the way it works so it works because I will not spend money on windows xp again. If you contact me at PW, I will try to help.
  • #8 13197122
    diseasekowalski
    Help: 180
    Rate: 189
    gsekulski wrote:
    Hello, Colleagues. Damn, I did this autodata, but it has been a long time and it's hard for me to remember what I was doing right now. I combined something with Microsoft Visual C + + because I did not want to run on any version and downloaded the crack and some three entries to the registry which in the right order was added and moved to me on Windows 7 . In total, you can find fault with me, but if you buy legally and it is not a combination, so that it works because I will not now spend again on the windows xp. If you contact me at PW, I will try to help.
    With a friend who bought the autodata recently, the problem with walking on win7 64bit with all MSUpdate solved the inclusion of the "run as administrator" option for the shortcut that the autodata created on the desktop at the installation. Nothing else needed to be done.
    Without this program threw different errors, including runtime and others.
The discussion revolves around resolving a "runtime error 217 at 004bb10D" encountered when running Autodata 3.39 on Windows 7. Users suggest several solutions, including uninstalling old Microsoft Visual C++ 2008 Redistributable packages and installing the 2010 version. Some users report success by running the application as an administrator or using registry modifications. There are mentions of using cracks or patches to bypass issues, indicating a mix of legal and illegal methods to resolve the problem. The conversation highlights the challenges of compatibility with newer Windows versions and the perceived inadequacy of official support.
