[Solved] Delphi Autocom 2015 R3: Resolving Unknown Error During Init on DS 150e - Windows 10 x64
surian 144204 8
  • #1 17010967
    surian
    Rate: 14
    I warmly welcome
    For several days I have been verifying the internet in search of a solution to my DS 150e problem.
    Namely, one day I wanted to run the Delphi Autocom program and it failed, I thought that you need to reinstall syf updates etc.
    I dropped what I had.
    I install, activate and suddenly "Unknown error during init", before everything worked as it should.
    I was looking for a solution to the problem in google and followed what I saw.
    I deleted everything, cleared the app data, Program Data, host in system32 and registry and did it every time, but the message with the problem returns and I cannot start the program.
    Anyone had a similar problem?
    I will add that I tried Windows 10 x64 and two computers, and before that everything worked on this system.
    Please help.
    I attach a screen with the problem (version 2015 r3)
    Regards
    Michał Bogacz
  • #2 17011059
    DriverMSG
    Help: 3984
    Rate: 4883
    The program does not generate a LOG file somewhere with a saved installation error? Look for. There may be information about the cause of the error.
    Alternatively, check the preview of system events.
  • #3 17011382
    surian
    Rate: 14
    Nothing new jumps in the program folder except file activation.
    Each other file has a modification date of 2016.
    In addition, each of the files from the data app or date program also has a date from 2016.
    In the program directory, the number of files before and after installation is 82 + activation file.
    I installed now to check it out and the error occurred around 9: 24-28.
    I attach some system log entries.
    • dzienniki04022018.rar (336.36 KB) You must be logged in to download this attachment.
  • #5 17011653
    surian
    Rate: 14
    DriverMSG wrote:
    Give it another SMART disk check
    Do you mean disk status?
  • #7 17011692
    surian
    Rate: 14
    Here we have a problem :P
    The equipment I work on is CHUWI HI10 Pro, this program has a problem finding the disk.
    I anticipate the question, earlier Delphi worked nice on this computer as well.
    DriverMSG
    Help: 3984
    Rate: 4883
    surian wrote:
    The hardware it works on is CHUWI HI10 Pro, this program has a problem finding the disk.
    I understand.
    So go back to the link I gave and clean the system again.
    Install SSCERuntime_x86-ENU.msi from the program folder.
  • #9 17011767
    surian
    Rate: 14
    I am currently installing a new Windows user account, we will see if it will work. (I write from the phone) :) offline computer.
    I read this guide but missed the info about a new Windows user :P
    Added after 27 [minutes]:
    DriverMSG wrote:
    Boss, on a new Windows user it went :)
    Summarizing.
    If someone gets this error "Delphi autocom 2015 r3 - Unknown error during init"
    Solution:
    1. Delete all Delphi files including installation folders
    2. Delete the Delhi folders from:
    C: \ users \ All Users \ Application Data \
    C: \ users \ Your Account \ Application Data \
    3. Delete the folder:
    C: \ users \ ** USER ** \ AppData \ Roaming \ Microsoft \ System Certificates \ My
    4. Editing the "hosts" file in C: \ windows \ system32 \ drivers \ etc \ hosts using a notebook:
    127.0.0.1 activation.autocom.se
    127.0.0.1 activation2.autocom.se
    127.0.0.1 updates.autocom.se
    5. Registry cleaning using CCCleaner
    6. Add a new Windows user and reboot
    7. Extract the Delphi files and generator on the new user's account
    8. Rename the file WyUpdate.exe
    9. Run Main as administrator and continue on
    10. Save the activation file
    11. Activate file with generator (do not disable Delphi installation)
    12. Upload the file for installation using the start button
    13. Wait for the end and enjoy the program
    :spoko: :spoko: :spoko: DriverMSG thank you for your patience and redirecting me to the guide in which I lost information about the new user.
    Without you, I wouldn't look at him again.
The discussion revolves around resolving an "Unknown error during init" issue encountered while using the Delphi Autocom 2015 R3 software on a DS 150e device running Windows 10 x64. The user attempted various troubleshooting steps, including reinstalling the software, clearing application data, and modifying the hosts file, but the error persisted. Responses from other users suggested checking for installation logs, ensuring no remnants of the program remained in the registry, and verifying disk health using SMART diagnostics. Ultimately, the user found success by creating a new Windows user account and following a detailed cleaning procedure, which included deleting all Delphi-related files and adjusting system settings.
