Role of Neutral Conductor N in Electricity: Current Flow & Function with Working Receiver
41847 15
What is the role of the neutral conductor N in a mains circuit, and why does it seem that no current flows through it when a receiver is connected and working?
The neutral conductor is the return path of the circuit, and current does flow through it when the receiver is operating; in AC the current alternates, so there is no one-way “in and out” flow [#12146137] The circuit must be closed for current to flow, so the phase conductor provides 230 V relative to earth while the neutral conductor is at about 0 V relative to earth [#12149166] You are not actually measuring current with a test pen (“test tube”); it indicates voltage presence, not current [#12149045] To measure current in the neutral, you need an ammeter, not a test pen [#12149080][#12149045] Because the neutral is at 0 V relative to ground, touching it normally does not give a shock-like sensation [#12149127]
  • Questioning why a working receiver shows no neutral current
    #1 12146111
  • #3 12148853
  • #4 12148926
    Miniax
    Electrician specialist
    Help: 173
    Rate: 290
    elektryk_10 wrote:
    Exactly not. After connecting the receiver to the socket, when I check the current, there is no current at the neutral wire terminal.
    How do you check?
    Draw a diagram.
    Because I understand that the connected device is working during the measurement.
  • #5 12148927
    KJaniczak
    Help: 71
    Rate: 179
    Just out of curiosity, how do you check this current? Ammeter or "sampler"?
  • #6 12149011
  • #7 12149045
    Miniax
    Help: 173
    Rate: 290
    elektryk_10 wrote:
    I check with "test tube" while the receiver is turned on.
    The test tube does not check the current, but the presence of voltage. There is still a lot of learning ahead of my friend.
    I suggest starting with some elementary basics, including definitions.
  • #8 12149065
  • #9 12149080
    tadziol
    Level 19  
    Help: 29
    Rate: 19
    Ammeter (but read the instruction manual and safety precautions first).
  • Basic distinction between current and voltage measurements
    #10 12149087
    Miniax
    Help: 173
    Rate: 290
    elektryk_10 wrote:
    But despite this, when I touch this neutral wire, the current does not kick. Then how can you check it, buddy?
    To safely start practicing, you need to know the theory.
    You can't check something without knowing what works.
    A colleague has no idea what voltage is, what is current.
    What causes the current to flow. There are no elementary foundations here.
    The current is measured with an ammeter.
    The voltage is measured with a voltmeter.
  • #11 12149099
  • #12 12149127
    Miniax
    Help: 173
    Rate: 290
    elektryk_10 wrote:
    Okay with an ammeter, but if there is voltage on the neutral, why can't it be seen and why doesn't it kick when touched?
    Eh. A colleague continues his ...
    Please give a definition of the voltage and explain it in your own words.
    There must be no voltage on the cable.
    The voltage between the neutral conductor and the ground is 0 V, therefore it is called the neutral conductor.
  • #13 12149140
  • Clarifying voltage, current, and closed-circuit requirements
    #14 12149166
    Miniax
    Help: 173
    Rate: 290
    Current is not voltage ...
    The voltage is the DIFFERENCE of potentials between two points.
    If there is no voltage, no current will flow.
    The circuit must be closed for the current to flow.
    The voltage between the phase conductor and earth is 230 V (in Poland), while the voltage between the neutral conductor and earth is 0 V.
    elektryk_10 wrote:
    And so, in the will of accuracy, we measure the current with the ammeter, not the friend's current.
    And with this in mind, we end up giving advice and learning.
  • #15 12149188
  • Ammeter measures circuit current, not a person's current
    #16 12149223
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Miniax wrote:
    elektryk_10 wrote:
    And so, in the will of accuracy, the ammeter measures the current, not the friend's current.
    I think the same. I close the topic as worthless.
    Statute:
    3.1.17. It is forbidden to publish entries lowering the general level of discussion, resulting from laziness or containing the demanding nature of statements.
    3.1.9. It is forbidden to disseminate ironic, mocking or malicious content that shows disrespect for other Users or third parties.
    I advise the author to ask the school teacher in the lesson and not bother in the technical forum in addition to the claims.
    The forum is not for learning the basics, even here in the beginners section we require a minimum of knowledge, which the author unfortunately does not have.
The discussion revolves around the role of the neutral conductor (N) in electrical systems, particularly in alternating current (AC) circuits. The main question raised is why no current flows through the neutral conductor when a receiver is connected. Participants clarify that the neutral conductor is designed to maintain a voltage of 0 V relative to ground, which means that under normal operating conditions, there should be no current flowing through it if the circuit is balanced. The conversation highlights the importance of understanding the difference between voltage and current, emphasizing that current requires a closed circuit and a potential difference to flow. Misunderstandings about measuring current and voltage using devices like ammeters and test tubes are also addressed, with suggestions for proper measurement techniques and safety precautions.
