Does AC require return path, wont ground be enough for potential difference
513 10
Does AC need a return path, and why doesn’t touching the neutral wire always shock you?
Yes—AC needs a return path to complete the circuit, and in a house that return path is normally the neutral wire, while the earth/ground wire is mainly there for safety if the live wire touches exposed metal parts [#21683823] A wire can still have AC voltage present even when no current is flowing, but current will not flow without a complete circuit [#21683823] Touching neutral in a completed circuit can still give you a shock because you may create a parallel path to earth, so some current can flow through your body; the amount depends on how well you are grounded, such as barefoot in water versus wearing rubber-soled shoes [#21683826] Neutral and earth are often connected back to the same point, which is why neutral can be effectively similar to earth in practice [#21683823]
  • #1 21683821
    Ashvin Srinivasan
  • Neutral as the AC return path, ground for safety
    #2 21683822
    Giovanni Di Maria
  • AC needs a neutral or earth return path
    #3 21683823
    Alan Gallagher
  • #4 21683824
    Alan Gallagher
  • #5 21683825
    Ashvin Srinivasan
  • Neutral wire can shock via parallel earth path
    #6 21683826
    Alan Gallagher
  • #7 21683827
    Ashvin Srinivasan
  • #8 21683828
    Ashvin Srinivasan
  • Neutral fault raised house taps above ground
    #9 21683829
    Richard Gabric
  • #10 21683830
    leah melda
  • #11 21683831
    James Mark
Alternating current (AC) systems require a return path to complete the circuit, typically provided by the neutral conductor. The phase (live/hot) wire supplies the voltage, while the neutral serves as the return path for current flow. The earth (ground) wire is primarily a safety feature to protect users from electric shock if the live conductor contacts exposed metal parts. Ground alone cannot substitute for the neutral return path because current requires a closed loop to flow. Touching the neutral wire can cause an electric shock if the person provides an alternate path to ground, depending on factors such as insulation and contact with earth. Some remote power distribution systems use Single Wire Earth Return (SWER) to reduce infrastructure costs by using the earth as a return path, but this approach has limitations due to ground resistance. Electrical wiring practices and safety standards vary by country, with examples including New Zealand’s bonding of neutrals and grounds and India’s 240 V, 50 Hz supply system. Proper grounding and neutral connections are critical for safe and effective AC power delivery.
