What does negative voltage mean in electronics and how is it used in circuits?
kuzum 28624 8
  • #1 1259715
    kuzum
    Can anyone explain to me the term negative voltage ??
    I'm looking online and can't find a definition.
    Thanks in advance for your answer and best regards.
  • #2 1259811
    YR1
    Help: 49
    Rate: 52
    It is a voltage that is polarized inversely with respect to zero. If you have an alternating voltage, then there is a positive and negative part to zero throughout the period. When you "straighten" it in the right way, you will have 2 halves with different polarities. This is so for peasant reason.
    If you don't understand it somewhere on the electrode I think I saw the link to the page where it is described in more detail.
    YR1
  • #3 1259833
    BolzZ
    Help: 56
    Rate: 67
    it's best to take a look at the diagram of the most ordinary symmetrical power supply and you will understand ...
  • #4 1259843
    lordac
    Help: 9
    Rate: 32
    I see that no one answers, so you will condemn you to my, perhaps somewhat erroneous explanation :) .
    By definition, voltage is a potential difference, that is, we do not have a voltage at a point but between two points. If we now take any of these points (A) as the reference level (ground, 0V etc.), then if the potential in another point (B) is lower than that, then the voltage between these points is negative (Uba = Vb-Va). Of course, if we take point B as our reference level, then we will have the opposite.
    But as Paweł Sujko noticed this once, I have a twisted translation, so it would be good if someone would control it :)
  • #5 1259890
    bestler
    Help: 254
    Rate: 893
    The voltage is just like a colleague mentioned the potential difference between the two points. If you don't have any reference point, there is no negative voltage, we just measure the value of this voltage. Now yes - we usually take the "-" point, that is, the "minus" of the voltage source as the reference point. This is also how the meters work - the zero level equals the negative pole. Now, if you add a "plus" of a battery or other source to such a mass tip of the meter, and to the positive terminal, minus the battery, the meter will show a minus in front of the measurement value (I'm talking about digital meters).
    Write or understand, because if not, we will continue to translate :)
    By the way ... when I started my adventure with electronics, I was haunted by the definition of negative resistance :) ))
    greetings :)
    Pawel J.
    greetings :)
  • #6 1259957
    kuzum
    Thanks - I more or less understood :D
    It is true that I am interested in programming in assembly language and just because I needed the concept of negative voltage - because I read in the book that logical zero is -12 v and logical 1 is +12 v (e.g. in rs232)
    and I was just curious ...
    If you would recommend a good book (maybe an e-book) for learning electronics, I would be grateful /
  • #7 2477925
    Gucio1000
    It was probably about the term "NEGATIVE LOGIC", that is:
    -3V to -15V is a logical "1"
    + 3V to + 15V is a logical "0"
  • #8 17663949
    JodaPP
    I read the above also looking for the answer to the "definition" of the negative voltage in the computer power supply that I am going to use to power the systems at home (...) and I have a question if I would measure the voltage between the + 12v terminal and the -12v terminal, then I would have it at the output 24 v? assuming that zero DC (minus) is the reference for +12 DC and -12 DC voltages in the power supply, I think right? ...
    I know, I could measure up and not ask myself what I will definitely do, but for now I have no possibility (the power supply fell into my hands by accident and now I have no physical possibility to check my thesis.)
  • #9 17664236
    398216 Usunięty
    Help: 3925
    Rate: 9285
    JodaPP wrote:
    if I measured the voltage between the + 12v terminal and the -12v terminal, then I would have 24v on the output? assuming that zero DC (minus) is the reference for +12 DC and -12 DC voltages in the power supply, I think right? ...
    Yes. You think right, you will have 24V.
✨ Negative voltage refers to a potential difference where one point has a lower electrical potential than a reference point, typically ground (0V). In alternating current (AC) systems, voltage oscillates between positive and negative values. When measuring voltage, if the reference point is set at a negative terminal, the resulting measurement can show negative values. This concept is crucial in digital electronics, where negative logic may be used, such as in RS-232 communication, where -12V represents a logical zero and +12V represents a logical one. Additionally, in power supplies, measuring the voltage between +12V and -12V terminals yields a total of 24V, assuming the negative terminal is the reference point.
