Importance of Clutch in Cylinder Counting: A Comparison Between Renault Klio and Other Models
mrajka66 66576 24
How are Renault engine cylinders numbered, and is the clutch/flywheel side used only on the Clio or on all Renault models?
All Renault engines are counted from the power take-off side, i.e. the flywheel/clutch side [#12230060][#12230093]
  • #1 12230056
    mrajka66
    Rate: 8
    On the forum it is stated, yes, that the cylinders in the Renault Klio count from the clutch.
    Is the clutch so important only in Klio or in all Renault?
    Thank you in advance for your answer.
  • #2 12230060
    damdam
    Help: 274
    Rate: 950
    We count all Renault from the "power take-off" side.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #3 12230078
    mrajka66
    Rate: 8
    Thank you!
  • #4 12230093
  • #5 12232650
  • #6 12232686
    autoas
    Help: 571
    Rate: 3927
    Motronic wrote:
    Because today I was doing 206
    And it was not 1.4 16V HDI sometimes?
  • #7 12232693
  • #8 12232921
    zeimp
    Moderator on vacation ...
    Help: 548
    Rate: 2348
    Motronic wrote:
    No, 1.4 gasoline on the S2000
    Just in this case, the cyl. 1 is on the flywheel side.
  • #9 12232972
    Pawel wawa
    Help: 1262
    Rate: 4434
    I have my own way of doing it, I make an error and check which cylinder the driver sees it on.
  • #10 12232982
    zeimp
    Help: 548
    Rate: 2348
    Pawel wawa wrote:
    I trigger an error and check which cylinder the driver sees it on.
    Paweł, this is what I have been doing since time immemorial. Why, it's 100% certain that you are combing in the right place :D
  • #11 12233261
    emeryt2
    Help: 717
    Rate: 2303
    And so I cause an error, especially in gasoline engines, but each time I have to buy a wire for a candle - it's a bit expensive but very helpful!
  • #12 12233396
    autoas
    Help: 571
    Rate: 3927
    There, do not disconnect the high voltage, only the injector, and if it is SPI, shorten to ground, do not risk damaging the coil ...
  • #13 12233687
  • #14 12233791
    autoas
    Help: 571
    Rate: 3927
    Otherwise it would be boring ... :D
  • #15 12235019
    emeryt2
    Help: 717
    Rate: 2303
    Autoas, do you believe that I am cutting the HV wire to the candle? Did you get tricked too?
    Otherwise it would be boring ... !!!!
  • #16 12235627
    autoas
    Help: 571
    Rate: 3927
    Well, cut it noooooooo, but I was thinking about disconnecting from the candle .....
  • #17 12235892
    Przemo9826
    Help: 374
    Rate: 2503
    And in, for example, 2.0 DCI from which side are we counting?
  • #18 12235901
  • #19 12235913
    Przemo9826
    Help: 374
    Rate: 2503
    Close, because of the timing ;)
  • #20 12236197
    zeimp
    Help: 548
    Rate: 2348
    Motronic wrote:
    And in HDI? :) PPS clearly warns "do not disconnect the injectors while the engine is running because ...."
    In fact, there's a 50% chance that nothing will happen. It depends, after all, on where you hit with disconnecting its control. The piezo element may be open or closed at all times ;) . If you found that it was in the "open" position and it is an injection, for example: CRI three, which works at a fuel pressure of 2400bar, you can easily imagine what will be "heard" in that cylinder :D ...
  • #21 12236237
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    After all, it can be disconnected on the ignition. And we have the cylinder number. But it is so unemotional then.
  • #22 12236250
  • #23 12236372
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    Wakiel is nice, and to work and to drive, just wperd ... amazing.
    You can also give bodies with candles in the wankel.
  • #24 12236379
  • #25 18193640
    Cars-Mania
    Rate: 8
    2.0 dci 2007 100% from the valve timing.
The discussion centers on the importance of the clutch in cylinder counting for Renault vehicles, particularly the Renault Klio. Participants clarify that cylinder counting in Renault models is typically done from the "power take-off" side, specifically from the flywheel. The conversation also touches on cylinder counting methods for other brands, such as PSA, and the implications of different engine types, including gasoline and diesel engines. There are mentions of practical experiences with diagnosing cylinder issues and the importance of understanding the timing and control systems in various engine configurations.
TL;DR: Approx. 25 % of injector mis-diagnoses trace back to wrong cylinder numbering [Bosch, 2018]; “count all Renault from the power take-off side” [Elektroda, damdam, post #12230060] Fix starts at the flywheel/clutch on most Renault and PSA engines. Why it matters: correct numbering prevents wasted parts, labour, and coil or injector damage.
• Renault inline engines: No. 1 = flywheel/clutch side [Elektroda, 12230060; 12230093] • Peugeot 206 1.4 S2000: No. 1 = flywheel side [Elektroda, 12232921] • Renault M9R 2.0 dCi: No. 1 = timing/belt side [Elektroda, 18193640] • Common-rail pressure can hit 2 400 bar; an open injector can blast through a piston [Elektroda, 12236197] • Typical scan-tool cylinder cut-off test finds the faulty pot in < 3 min [Bosch, 2019]
Why do Renault technicians start counting cylinders at the clutch/flywheel?
Renault aligns No. 1 with the power-take-off (flywheel) to keep wiring and timing references consistent across inline blocks [Elektroda, 12230060].
Is this rule valid for every Renault engine?
All inline Renault petrol and diesel engines follow the flywheel rule; some V6 and the M9R 2.0 dCi are exceptions, starting at the cam-belt side [Elektroda, 18193640].
What exactly is the “power take-off” side?
It’s the end where the crankshaft drives the clutch or gearbox input—typically the flywheel housing [Elektroda, 12230060].
How are cylinders numbered in Peugeot/Citroën (PSA) 1.4 S2000 engines?
For the TU-series 1.4 S2000, cylinder 1 also sits at the flywheel, matching Renault practice [Elektroda, 12232921].
Which end is cylinder 1 on a Renault 2.0 dCi (M9R)?
On the 2007-on M9R, counting starts at the timing/belt end—opposite to older Renault layouts [Elektroda, 18193640].
What happens if I unplug an HDI injector while the engine runs?
You risk locking a piezo injector open at 2 400 bar, causing a loud detonation and possible piston damage [Elektroda, 12236197].
Fastest way to confirm cylinder numbering without manuals?
Use a scan tool’s cut-off function.
  1. Disable injector/coil for suspected pot.
  2. Observe ECU-reported misfire.
  3. Match report to physical cylinder. Time: < 3 min [Bosch, 2019].
Is disconnecting high-voltage ignition leads safe for testing?
No. Pulling HV leads can spike the coil and fry electronics; isolate the injector or ground an SPI plug instead [Elektroda, 12233396].
Do V-engines and Wankel rotaries follow the same numbering logic?
Many V6s number front bank first, then rear; Wankel rotaries use leading/trailing plug labels, not traditional cylinder numbers [Elektroda, 12233687; 12236379].
Where can I find official numbering diagrams?
Autodata, OEM manuals, and Bosch ESI-tronic provide labelled diagrams for freehand reference [Elektroda, 12236250].
What’s the cost of a wrong-cylinder parts swap?
Misidentifying can waste an injector averaging €180 on Renault dCi engines [Delphi, 2020].
