Water level indicator circuit diagram for water tank using float sensor or probes
aissa09 7080 9
How can I build a simple remote LED water-level indicator for a tank?
Use a non-contact liquid level sensor such as WS-02A mounted on the tank wall so it can sense the water level through a non-conductive wall without probes or wires [#12307048] This fits your remote setup, since the indicator is about 10 m away and the tank is 2 m high with 10 bar internal pressure [#12283619] [#12285887] If you only need a low-level alarm, a float switch is the simplest option [#12275146] [#12285427] For a remote LED display showing water consumed, the signal still has to be carried by analog current, digital wire, or wireless transmission [#12285225]
  • #1 12274731
    aissa09
    hi
    I need a diagram for a water level indicator for tank
    thank you in advance
  • #2 12275146
    leszek-56
    Help: 22
    Rate: 127
    They are a few kind of level switches
    -for high or low indication –float switch
    -for continue indication –pressure or other type.
    Just give as more information what you need .
  • #3 12281516
    aissa09
    thank
    a simple diagram that shows me the water level remaining in the reservoir with LED indicator
  • #4 12281871
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    Indicator will be mounted directly on the tank or will be mounted remote? If remote - what is the distance from the tank to the indicator? How high the tank will be? What is required precision of measurement?
  • #5 12283619
    aissa09
    I prefer a distance, height 2m : pressure 10 bar
  • #6 12285225
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    Allow me small resume:
    - water level in the tank will vary from 0 to 2 m, eg water pressure at the tank bottom will be approximately 0.2 bar;
    - level sensor (or differential presure sensor) will be inside the tank;
    - tank is pressurized, pressure inside the tank is 10 bar;
    - level indication is remote to the tank. Please give the approximate distance. It is necessary to choose how to transfer information on the water level: analog standard current signal, digital wire or wireless transmission.
  • #7 12285427
    leszek-56
    Help: 22
    Rate: 127
    If I wrong pls correct me ,but I think you wont the simplest indication on LED diode that water level Is low .
  • #8 12285887
    aissa09
    the approximate distance is 10m
    No friend leszek-56
    the LED is to show the level of water consumed
  • #10 12307995
    aissa09
    thank is good.
A user requested a diagram for a water level indicator for a tank, specifying a need for an LED indicator to show the remaining water level. The discussion covered various types of level sensors, including float switches and pressure sensors, and clarified that the tank is pressurized at 10 bar with a height of 2 meters. The user indicated a preference for a remote indicator located 10 meters from the tank. Suggestions included using a non-contact liquid level sensor, specifically the WS-02A model, which can sense water through the tank wall without requiring probes or wires.
