Identifying Correct Screw Size for Mounting Samsung UE40F6800 TV on Hubertus Mistral Table
szeszelka 51093 5
  • #1 12308036
    szeszelka
    I urgently need advice. I bought a Samsung UE40F6800 TV. I want to hang it on the Hubertus Mistral table. The table has a hanger for hanging the TV. Please tell me what screws should I buy to fix the TV to the cupboard hanger. Identifying Correct Screw Size for Mounting Samsung UE40F6800 TV on Hubertus Mistral Table
  • #3 12308562
    KOCUREK1970
    Help: 3862
    Rate: 5490
    The same ones that are included in the set to be attached to hang it on a special wall bracket, should even be included with the TV you purchased (please look for a bag with screws in the carton or polystyrene around the TV).
  • #4 12308999
    1 PAWEL
    Help: 674
    Rate: 1364
    Included with the handle are screws with lengths that are not designed for specific models. You can damage the electronics by inserting longer screws.
    You will probably be able to use the screws holding the TV stand down after unscrewing the TV stand.
    Tv owns
    Mounting under the hanger in the Mini standard
    Mounting under the hanger in the VESA standard
  • #5 12309119
    struś pędziwiatr
    Rate: 16
    The TV set should include screws for mounting the TV on the VESA bracket. If there are none, use the screws after unscrewing the feet holders.
  • #6 12319300
    szeszelka
    M8 bolts, length 20. I have bolts dl. 15, but they are a bit too short, so I screwed it without the covers that come with the TV.
