Identifying Correct Screw Thread for Upper Mounting Holes on Samsung UE65KS8000 TV
koalakm 24459 10
What adapter or screw type is needed for the upper mounting holes on a Samsung UE65KS8000 TV when M6 screws do not fit?
The upper holes use the supplied Samsung mounting adapters/spacers, not a plain M6 screw thread. According to the manual, the wall-mount hardware goes in with longer pieces at the top of the TV and shorter ones at the bottom [#16821903][#16822340] The needed parts were in the accessories bag: four black adapters, two longer and two shorter, which you screw gently into the TV first and then attach the wall bracket to them [#16822588] Without these adapters, the screws will not match the TV holes, so the TV cannot be hung properly [#16836389]
  • Upper mounting holes appear to need adapters, not M6 screws
    #1 16821854
    koalakm
    Rate: 15
    Well, I have a problem with hanging the Samsung UE65KS8000 TV on the wall - and more accurately screwing the screws.
    In this model, the bottom two screws are M8 - and they screw in nicely. However, the upper 2 do not know what thread they have ... the M6 screw does not screw in (max 1 scroll and lock - and I do not want to force the abuy not to screw the thread on the tv). The M5 screw falls in (it is too small). A screw with an inch (1/4 inch) thread is not it.
    The set with tv was a set of screws and some adapters, but unfortunately I do not have it.
    Can someone have a similar problem? It looks like it should either be in the set (adapter?) Or there is some strange thread? Only what? The M6 bolt is the most suitable size ...
  • #3 16821912
    koalakm
    Rate: 15
    I sought so much for my wounds and I did not get it.
    Thank you very much!!
  • Longer top spacers needed for Samsung wall mount
    #4 16822340
    Will Nottellyou
    Rate: 20
    Also it took me a while to find in the instructions that you need to get those longer snippets at the top of TV and shorter at the bottom. I have hung up my 65ks9000 on such something; https://www.invisiontvbrackets.com/invisionr-...plasma-curved-screens-double-arm-tilt-swivel- feature-includes-1080p-HDMI-cable-spirit-level-please-confirm-your-tv-VESA-mounting-holes-before-buy-hdtv-dxl
    I was dependent on the option of adjusting the distance from the wall / seat and account. the first few days I was wondering if tv still hangs on the wall or lies smashed on the floor, but somehow this phobia passed me.
    pozdrowki
  • #5 16822343
    koalakm
    Rate: 15
    I understand and thank you for the comment.
    However, you had these adapters in the set ... and unfortunately I do not have them and I have to buy somewhere.
    KM
  • #6 16822353
    Will Nottellyou
    Rate: 20
    So it looks before and after. I was brave and hung it myself, but in three people it would be much more convenient and more reasonably and safer, above all :)
    Identifying Correct Screw Thread for Upper Mounting Holes on Samsung UE65KS8000 TV Identifying Correct Screw Thread for Upper Mounting Holes on Samsung UE65KS8000 TV
  • #7 16822374
    koalakm
    Rate: 15
    about lol. You hanged yourself? Congratulations for your courage ;)
  • #8 16822490
    Will Nottellyou
    Rate: 20
    Sam, and I do not recommend - it's a bit more complicated than replacing the bulb :)
    Prophylactically, I recorded a video of this hanging, because if it has something to break up, let it earn some money on YT. I did not look too much, but I do not think there is any video currently breaking the samsung headboards ...
  • #9 16822504
    koalakm
    Rate: 15
    but the tv is really great.
    Did you have those adapters in the set that I do not have?
  • #10 16822588
    Will Nottellyou
    Rate: 20
    Yes, these pins were in the accessories bag, four pieces, black, two longer, two shorter ones. First, they screw them in to TV (gently), and then like in the instructions for the handle. Look in this purse in which there were remotes and waste paper ...
  • #11 16836389
    koalakm
    Rate: 15
    Ok thank you for the info.
    I think important to others: In these tv models it is necessary to have these adapters - otherwise you will not hang the TV on the wall - no screw threads will fit.
The discussion revolves around the difficulty of identifying the correct screw thread for the upper mounting holes on the Samsung UE65KS8000 TV. The user successfully used M8 screws for the lower holes but faced challenges with the upper holes, where M6 screws did not fit properly, and M5 screws were too small. The user lacked the original screw set and adapters that typically come with the TV. Other participants confirmed that the TV requires specific adapters for proper wall mounting, which were included in the accessory bag. It was emphasized that without these adapters, the TV cannot be securely mounted.
