What wall mount for PHILIPS 24PFT4022 LED TV (fatal VESA holes)?
teriero 5196 3
  • #1 16696311
    teriero
    Rate: 24
    I would like to ask you what to buy a TV holder for 24PFT4022 TV LED PHILIPS.
    I tried a dozen of the smallest handles.
    Either a design error or the saving of the TV manufacturer resulted in a terrible location of the holes for the VESA 7.5 standard bracket, which - the lower ones are located just above the connector panel (HDMI) (attachment photo1)
    The use of rail holders with vertical elements is completely impossible (the right rail enters the connector panel).
    In the case of those with a rectangular head and "whiskers" mounted on the back wall of the TV with VESA 10 / 7.5 holes, it is not possible due to the fact that the handle and its "whiskers" cover the HDMI connectors (photo2 attachment).
    Only a handle with 7.5 cm standard holes may be used, with a square plate mounted on the back of the TV, the bottom edge of which will not be large enough to protrude over the connector panel and not cover the upper sockets (HDMI).
    Hence the problem with the selection of the handle.
    Can anyone recommend me such a handle?
    Maybe there would be a good holder for LCD monitors?
    Greetings,
  • #2 16696406
    mrx2000
    Help: 21
    Rate: 47
    In the above case, it is enough to sand the bracket a little so that you can insert the plugs into the sockets and that's it.
  • #3 16696447
    teriero
    Rate: 24
    @ mrx2000
    Thanks for the answer.
    But unfortunately I have neither the possibility nor the time to play in grinding the bracket.
    The more so because I have 2 such TVs to mount.
    Hence, I mean a ready one I saw somewhere, mounted for a PC monitor
    in which the plate is mounted on screws to the back surface of the TV
    she had greatness max 10x10 cm only holes for VESA 7.5 cm , no "whiskers" at the edges
    (with 10 cm VESA holes) and up and down adjustments - as in the picture below.
    Have you seen someone somewhere to buy such a bracket?
  • #4 16736957
    teriero
    Rate: 24
    Problem fixed - thread closed:
    The holder with VESA 100 and 75 holes was cut on one side at the hole for VESA 100 to fit around TV connectors.
