Supplied Screws for LG OLED C9 TV Wall Mount: Are They Included & What Type?
djpablo1980 9756 3
  • #1 18623047
    djpablo1980
    Level 4  
    Rate: 10
    I have a question, because tomorrow I will receive an LG C9 tv.
    And I wanted to hang it on a wall mount.
    The question is, does the manufacturer provide mounting screws in the set? Do you have to supply yourself?
    Anyone know what screws go in there?
  • #2 18623094
    staś pytalski
    Help: 760
    Rate: 1436
    The manufacturer may or may not include the screws to the tv (wall mount is an option), they can be screwed into the tv case, either with the remote control/manual, at the foot or somewhere in the styrofoam, but 95% of the time they are just foot screws. Anyway, take a look at the instructions to see if they are included, or where to find them. But if you buy a good handle, they should be 100% in the box. Choosing other screws as recommended by the manufacturer may result in damage to the TV, and what screws to choose can be found in the manual.
  • #3 18623111
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    When I bought a wall bracket, the screws for mounting, screwing the TV to the bracket were included with the bracket, different sizes and lengths, probably 16 pieces. Spacer washers too, different thickness of washers depending on which will fit. I don't know what brand of the bracket it is because it doesn't say anything on it, just an ordinary hanging bracket for PLN 150, it is supposed to fit a TV from 38 to 75 inches, and it fits ...
    This is a handle of this type.
    Added after 4 [minutes]:
    staś pytalski wrote:
    The manufacturer attaches screws to the TV, they can be screwed into the TV housing, either with the remote control / manual, at the foot or somewhere in the styrofoam.
    There were no screws for mounting the Vesa holder with my Samsung, they were with the purchased holder.
  • #4 18623128
    staś pytalski
    Help: 760
    Rate: 1436
    I corrected the post... The wall mount is an option, so no need for screws.
