Samsung UE40ES5500W TV: VESA Screw Size, Thread Details, Maximum Length & Required Spacer Distance
tyle 23157 8
  • #1 14263042
    tyle
    Rate: 14
    Welcome,
    I have a UE40ES5500W TV set. I wanted to hang it on the wall on the bracket that I "inherited" from the former owners of the apartment.
    Unfortunately, it turns out that the holes for the mounting screws in the TV are not equal to the "back" of the TV, but as if in a hole (photo below). Hence my two questions:
    1 / what VESA screws are in this TV model - I mean the thread size and possibly the maximum length so as not to drill into the screen :-)
    2 / what distance should I buy to compensate for the "hole"?
  • #2 14263137
    intenso
    Help: 480
    Rate: 617
    The spacers are together with the tv accessories.
    As for the screws, their dimensions are in the instruction manual.
  • #3 14263177
    LeDy
    Help: 1992
    Rate: 2942
    VESA is spacing, not size. Probably M8 and the length is 20,25,30 mm (need to check). The spacing is probably 400x400.
  • #4 14263199
    tyle
    Rate: 14
    Forgive me ... My fault ... I did not write that I do not have spacers and there is no word about the size of the screws in the manual.
    If I had / I would not bother in this forum.
  • #5 14263203
    intenso
    Help: 480
    Rate: 617
    How did you get distances, until it is impossible. Three years ago I bought a tv and they were together with tv, a month ago I bought a second tv and they were also with tv accessories.
  • #7 14263304
    tyle
    Rate: 14
    I do not exclude that the set with the TV / wall bracket included appropriate screws - the passage of time meant that I do not have them.
    I will go to Castorama and choose something and then I will write what it was and if it fit.
  • #8 14626717
    tyle
    Rate: 14
    fixed: bolts are M8.
  • #9 16418186
    Anna77733
    I know if you solved the problem of the TV and the lack of distance, because I have the same problem, I have no way to attach the holder because there are holes in the TV and there is no distance
The discussion revolves around mounting a Samsung UE40ES5500W TV on a wall bracket, specifically addressing the VESA screw size and the need for spacers due to the unique hole configuration on the TV's back. Users suggest that the screws are likely M8 with lengths of 20, 25, or 30 mm, and that spacers are typically included with TV accessories. However, one user notes they do not have the spacers or screws, prompting a search for suitable replacements. The conversation highlights the importance of ensuring the correct screw length to avoid damaging the TV screen and the necessity of spacers for proper mounting.
