What Is the Standard Turn-Off Time for RCD Switches? Does 0.2/0.4/5 Sec Rule Apply?
voytalo 57768 11
What disconnection time does the standard require for an RCD, and do the 0.2/0.4/5 s limits also apply to RCD testing?
For a standard RCD, the thread gives these tripping times: 0.3 s at 1×IΔn, 0.15 s at 2×IΔn, and 0.04 s at 5×IΔn, with the reference point in PN-HD 60364-4-41, section 411.3.2.2, which contains the table of maximum switch-off times for final circuits up to 32 A [#12314185][#12314274][#12314473] The 0.2/0.4/5 s rule is not presented here as the RCD criterion; the RCD-specific values above are the ones cited in the discussion [#12314185] One reply also states that the latest Polish installation-testing standard does not require checking and documenting RCD operating time in the protocol, so that measurement may be omitted [#12314185]
  • #1 12314037
    voytalo
    Help: 61
    Rate: 130
    Hello. What is the required turn-off time for an RCD switch according to the standard? Does the 0.2/0.4/5 sec rule also apply in the case of RCDs? I know that the switch-off time depends on the fault current that will flow through the RCD, but I want to determine the efficiency of the switch using electrical measurements. Regards.
    .Jack
    Electrician specialist
    Help: 361
    Rate: 427
    The operating time depends mainly on the switch and not on any residual current - (what is this residual current?).
    And the activation time depends on the multiplicity of the residual current. For a multiple of one, for a standard RCD, it is 0.3 s, for a multiple of two, it is 0.15 s, for a multiple of five, it is 0.04 s.
    voytalo wrote:
    I`m talking about determining the efficiency of a circuit breaker during electrical measurements
    The latest standard for checking electrical installations in Poland does not provide for checking and documenting the operation time of the residual current circuit breaker, so it can be omitted in the protocol. A measuring electrician should know this.
  • #3 12314222
    elpapiotr
    Help: 1015
    Rate: 3532
    You have to add it though, my friend .Jack , when it is recommended to check the required shutdown times.
  • #4 12314224
    voytalo
    Help: 61
    Rate: 130
    Residual current is one of the terms for residual current - an electrician should know about it.
    I`m not a measuring electrician, but I deal with measurement protocols in which I encounter a record of the RCD activation time, that`s why I`m asking.
    I know that this time should be checked in the case of a second-hand RCD test. But what good is measuring time if I have no reference point? Hence my question about the requirements.
    elpapiotr
    Help: 1015
    Rate: 3532
    The reference point is in section 411.3.2.2 of the PN-HD 60364-4-41 standard of November 2009
  • #6 12314283
    voytalo
    Help: 61
    Rate: 130
    Unfortunately, I don`t have access to the PN, so if you could cite this entry, I would be grateful.
  • #7 12314473
    .Jack
    Help: 361
    Rate: 427
    It is not the fault current, but the standard specifies: residual fault current. Anyway, never mind. In my opinion, this is an incorrect spelling or poorly translated from English. But you know what I mean.
    This point contains a table: Maximum switch-off times for final circuits with a current not exceeding 32 A.
  • #8 12314489
    elpapiotr
    Help: 1015
    Rate: 3532
    Alright.
    You do not need to have access to the relevant PN to determine the effectiveness of protection by ensuring SWZ for protection devices, including RCDs, for specific (and permissible) activation times.
    This is the basis for environmental conditions, etc.
    You definitely have this data, and if not, calculate it.
  • #9 12314632
    voytalo
    Help: 61
    Rate: 130
    After all, in the first post I asked whether SWZ is used to ensure the required switch activation times of 0.2/0.4/5 s. It should have been written right away that the required shutdown time for RCDs is the same :) Anyway, thanks for clarifying the situation
  • #10 13308996
    elpapiotr
    Help: 1015
    Rate: 3532
    You have the required RCD switch-off time:
  • RCDs have the same required shutdown times as SWZ
    #11 13309783
  • #12 13309885
    elpapiotr
    Help: 1015
    Rate: 3532
    For terminology, blame Sonel, not the measuring person, bro Bronek:
The discussion centers on the standard turn-off times for Residual Current Devices (RCDs) and the applicability of the 0.2/0.4/5 second rule. It is established that the required switch-off time for standard RCDs is 0.3 seconds for a residual current multiple of one, 0.15 seconds for a multiple of two, and 0.04 seconds for a multiple of five. The PN-HD 60364-4-41 standard outlines these requirements, although some participants note that the latest Polish standards do not mandate the documentation of RCD activation times. The conversation also touches on the importance of measuring these times for second-hand RCDs and ensuring compliance with safety protocols.
