DeLonghi Magnifica - The grinder is spinning but they didn't have any coffee
Gerard121 52287 7
  • #1 12316372
    Gerard121
    Rate: 14
    I have a DeLonghi Magnifica coffee machine and there’s a problem with the grinder. Specifically, when I put coffee in and try to use the grinder, it’s as if it can’t draw the coffee in. I’ve tried turning the grind size knob, but it’s very stiff.
    When I try to grind the coffee, I can only see the grinder moving, but no grinding is taking place. Do you have any idea how I could fix this myself?
  • #2 12328566
    hurtovnik32
    Help: 35
    Rate: 219
    Hello buddy, check if the grinder outlet is blocked. The outlet will be visible in the upper part of the coffee machine after opening the front and removing the brewing module.
  • #3 12412730
    Gerard121
    Rate: 14
    Would any of the forum users want to try to fix this problem? How much would such a service cost? Preferably with access - Warsaw Ursynów - Natolin metro, please give the price
  • #4 12415853
    hurtovnik32
    Help: 35
    Rate: 219
    I provided information on PW.
  • #5 16230835
    pigafeta
    Rate: 46
    I have the same problem. Has it been solved somehow?
  • #6 16340368
    djjarhead
    Rate: 50
    And how? Managed to? I have the same problem .. The grinder turns but does not suck coffee: /
  • #7 16684718
    woytus
    Rate: 94
    It is similar with me, but when the grinder starts it is a sound as if the modes are skipping and they do not draw coffee and they do not have it.
  • #8 16688935
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3339
    The grinder is securely blocked, for example with a stone, and the cutters on the grinder drive belt are broken
    Kawa i Naprawa - Serwis AGD
The discussion revolves around a malfunction in the DeLonghi Magnifica coffee machine, where the grinder spins but fails to grind coffee. Users suggest checking for blockages in the grinder outlet and the brewing module. Some participants express similar issues, indicating that the grinder may be blocked or that there could be a mechanical failure, such as broken cutters on the grinder drive belt. The original poster also inquires about repair services in Warsaw, indicating a need for professional assistance.
