DeLonghi Magnifica S ECAM 22.110.SB - throws loose coffee to the bottom of the c
gosiak672 40026 9
Why does pre-ground coffee spill into the bottom tray on a DeLonghi Magnifica S ECAM 22.110.SB, and how should I use the ground-coffee function correctly?
The machine likely drops excess pre-ground coffee into the drip/grounds tray because too much coffee is being poured, and this model’s ground-coffee mode is finicky [#16620354] Try using less coffee first; one reply suggests testing with about 3/4 of a scoop [#16620317] A workable sequence is to turn the machine on, wait until it reports ready, set the selector to ground coffee, and start a brew without adding coffee yet so it shows a coffee-missing message [#18473309] Then add one scoop of ground coffee and start the same drink again; this was reported to work [#18473309] Other users confirmed that the issue happens mainly with ground coffee while bean coffee works normally, and that the machine does not always handle ground-coffee mode reliably [#18794964]
  • #1 16617939
    gosiak672
    Rate: 10
    the De'Longhi Magnifica S ECAM 22.110.SB espresso machine has the function of making coffee from ground coffee, unfortunately following the instructions when I put the coffee in the container, the coffee immediately lands on the bottom of the coffee machine. Why is this happening? How to turn it on so that the coffee does not spill out?
  • #2 16619594
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2658
    When do you pour this coffee and in what quantity?
  • #3 16619717
    gosiak672
    Rate: 10
    according to the instructions, I firstly turn the coffee machine on, then turn the dial to the left, then pour a cup of coffee into the hole for coffee, and start the coffee a little coffee at first, then the water itself or sometimes a basket with overflowing and triangle when I pull out the container with grounds at the very end of the tray is the rest of the loose coffee
  • #4 16620317
    MARCIN.SLASK
    Help: 1037
    Rate: 2658
    I understand that you are waiting until the coffee machine is ready.
    I do not have such or similar espresso, so it's a bit hard to tell. why coffee from coffee beans does not, and pre-ground (poured) no longer. If there was a separate hole it was still, but the one with ground in the mill goes to the same vertical channel and is to land in the brewing unit.
    For testing, let me try to pour in 3/4 scoops.
  • #5 16620354
    nioop
    Help: 503
    Rate: 3337
    It also seems to me after the description of this coffee is too much poured. At the time of the infuser movement, he drops the excess into the tray.
    However, one would have to observe the work of the block from the moment of pouring the coffee to see what is really happening there. Maybe the block does not position itself perfectly in its position.
    Kawa i Naprawa - Serwis AGD
  • Ground coffee mode now fails after initial success
    #6 16709281
    boruurob
    Rate: 97
    we have exactly the same problem. With coffee in the beans is all-around. The coffee maker is not freaking out. However, as we want to brew coffee from the zemilonej, after a while, the tray indicator is lit and the coffee is visible at the very end. I would like to add that at the very beginning I managed to make such a coffee several times, but for some time as we run out of grains and try to sip it, it fails.
  • #7 18396240
    Asmex2
    Rate: 15
    Has anyone solved this problem?
  • #8 18473309
    Świdek
    Rate: 20
    Half-way solution - I turn on the coffee machine, wait for it to report preparation, set the coffee selection knob to ground, choose coffee ("little americana"), but I don't add coffee yet - the coffee maker reports a lack of coffee, put in a scoop of coffee, choose little Americana again and voila! :D
  • #9 18786031
    boruurob
    Rate: 97
    And this is not a mistake in the automation of these machines?
  • #10 18794964
    Asmex2
    Rate: 15
    In history, colleague Świdek described how to do it. The espresso machine has a disability and it doesn't always come out but you can make both an espresso coffee and a normal single
The De'Longhi Magnifica S ECAM 22.110.SB espresso machine is experiencing an issue where ground coffee spills into the bottom of the machine instead of being brewed properly. Users suggest that the problem may stem from overfilling the coffee container or improper positioning of the brewing unit. Some recommend a workaround: turning on the machine, waiting for it to prepare, setting the coffee selection to ground, and then adding the coffee when prompted. Others speculate that the issue could be related to the machine's automation or design flaws, as similar problems have been reported by multiple users.
