Teka GKST 60Fi4 High FAC Induction: Non-Heating Right Burners, Power Modules & Key Aspects to Check
Malek 4497 2
  • #1 12322674
    Malek
    Help: 7
    Rate: 29
    Hello all.
    It does not repair the induction, but I will want to look at it in someone in the family. From the relationship I know that the induction does not heat up on the two right burners, i.e. sometimes it will turn on. After the reset, the main voltage switch is displayed on the numerical control with the software version. Please, provide as much information as possible about this type of kitchen.
    1. Are there two power modules in this induction - each serving two inductors, as in Mastercook inductors?
    2. What to pay special attention to?
    Thank you for your help.
  • #2 12854119
    ciepel92
    From what I remember, this record consists of 2 so-called work cards, power supply and selector. The work cards are responsible for controlling the fields. One controls two fields, the other one by analogy. For example - if 2 fields on the left are not heated, the left hand card is responsible for it. As soon as you get to her, first check the power transistors that are attached to the heat sink. If he has a varistor on the power supply also check it visually or not piercing. It also happens that the capacitors on the cards "swell" so keep that in mind. If the card is clean with no entanglement, the transistors are healthy, check if the voltage from the power supply to the card is coming out.
    In these boards there were also frequent problems with the power supply, there are 2 capacitors that also like to swell. After replacing them, the problems subsided.
  • #3 12907427
    Malek
    Help: 7
    Rate: 29
    The board has two power modules. In my case, one of them was damaged. The exchange has restored the efficiency of the record.
