Obtaining Lamp Homologation: LED Strip Addition, Costs, Multiple Models & Example Manufacturer
50eurocent 24945 9
How can I obtain homologation for a motorcycle lamp modified by adding an LED strip, and how much will it cost?
Homologation for a modified motorcycle lamp is an individual process and is not just an administrative stamp; it requires a full set of tests for light distribution, visibility, moisture resistance, vibration, temperature changes, and proof that production is repeatable, so home-made inserts are not acceptable [#12362916] [#12363950] One reply estimates the cost at around PLN 1,000, but another says the real cost is often much higher and may be several thousand zlotys for a complete laboratory test of the headlamp [#12362916] [#12363950] The approval must also cover the base lamp being modified, so consent for the original lamp is needed before starting the homologation process [#12364003] Because of the testing and repeatability requirements, this is generally only practical for larger manufacturers producing many units, not for small one-off conversions [#12363950]
  • #1 12324237
    50eurocent
    I have a nice idea for the treatment of available lamps (quinols, so without approval) by adding an LED strip inside. I would like to sell it because little needs to be changed and the price would be attractive and it would be possible to make a living from it ;)
    I know that the lamps must be homologated.
    How to obtain such approval?
    How much does the approval cost?
    I understand that another lamp (different car model) requires its approval, yes?
    I would like to calculate everything what and how :)
    EDIT:
    I found a lamp manufacturer that has hundreds of different lamps on offer. Did he have to get approval for each of them?
    http://www.was.eu/index/products/0/-1
    Regards
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    But exactly what kind of lamp do you mean, give a photo.
  • #5 12362685
    50eurocent
    What are the prices because I have not found out
    Can anyone help? :(
  • #6 12362916
    decybel91
    Help: 1024
    Rate: 4231
    This is an individual issue, if I remember correctly, getting it is around PLN 1,000.
  • #7 12363865
    50eurocent
    i.e. PLN 1,000 for obtaining approval for the production of one type of lamps (I know that a small change means a new approval is needed).
    Please confirm if I am thinking correctly :)
    Regards
  • #8 12363950
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    I've heard of the cost many times higher. Because it is not just a stamp issued by an official, but a whole cycle of tests - light distribution in various planes, visibility, resistance to moisture, vibrations, temperature changes. That's not all: the manufacturer must prove that the parameters of the products will be repeatable - that is, some inserts made in home-made conditions are out of the question. Once, somewhere, I "happened to the eye" the amount of several thousand zlotys for a complete laboratory test of the headlamp. Such a test can really be afforded by large factories that produce a given light source in tens of thousands of pieces. Otherwise, the profitability of this business is questionable.
  • #9 12364003
    Zico63
    Level 37  
    Help: 364
    Rate: 1036
    And back to the author's first post:
    50eurocent wrote:
    I have a nice idea for the treatment of available lamps (quinols, so without approval) by adding an LED strip inside. I would like to sell it because I don't need to change much and the price would be attractive and it would be possible to make a living from it
    And the consent of this "quinola" for processing is like? This consent must also be obtained when starting the homologation process.
    I thought that the approval requirements cooled down the author's colleague, but it is different ...
  • #10 12369049
    50eurocent
    Okay, I understand gentlemen :) you have tempered my ardor. I'll have to find a bigger manufacturer first and maybe suggest something to him
The discussion revolves around the process of obtaining homologation for motorcycle lamps, specifically regarding the addition of LED strips to existing non-approved lamps. The author seeks information on the costs associated with homologation and whether each lamp model requires separate approval. Responses indicate that the cost of homologation can vary significantly, with estimates ranging from PLN 1,000 to several thousand zlotys, depending on the extent of testing required, which includes assessments of light distribution, visibility, and durability. Additionally, consent from the original lamp manufacturer is necessary for modifications. The author contemplates collaborating with a larger manufacturer to navigate the complexities of the approval process.
