Epson SX230 shows error E01 at startup, no paper jam found, how to fix?
27981 6
  • #1 12344720
  • #3 12357702
  • #4 12358021
    konmaj
    Printers specialist
    Help: 370
    Rate: 496
    I understand, but most likely it is a problem with some sensor or other part of the mechanism (e.g. some gear) - many printers signal any mechanical problem as a paper jam.
  • #5 12358065
  • #6 12358700
    konmaj
    Printers specialist
    Help: 370
    Rate: 496
    I don't know - maybe the manufacturer came up with such a "trick"...
  • Hidden paper scrap blocking printhead movement caused E01
    #7 16420695
    pablo_mon
    Hello!
    Today I also had the same problem, I did not find anything interesting except this post was not there. It popped up after turning on "error E01"
    I solved the problem myself - it was caused by a paper jam and you wished there was nothing but the printer did not work.
    The same error popped up. Because there was nothing to see I pulled the head off forcefully (I figured there's nothing to lose)
    and it turned out that underneath it was a piece of paper some garbage - so the head did not move. The printer immediately went back to normal.
    It works and is fine. Good luck
The Epson SX230 printer displays error E01 immediately upon startup, indicating a paper jam, although no jam is present. Users suggest that the issue may stem from a malfunctioning sensor or mechanical component. One user resolved the error by forcibly removing the print head, discovering a piece of paper obstructing its movement, which restored normal function. Further troubleshooting may involve checking for hidden debris or resetting the printer.
