ASRock P67 Pro 3 B3 Motherboard with OCZ ModXStream 700W PSU & i5 2500k CPU: Sleep Mode Issue
kcpr11 32895 10
Why does my PC go to sleep for a few seconds and then wake/restart itself, and how can I stop it?
Your PC is likely waking itself from sleep because a device is allowed to wake it, and in this case the problem was finally traced to a bad network card [#12373490] Disable BIOS wake-up options such as “wake up on ring” and any similar remote-wake features [#12365642] Also check Windows power settings for devices that are allowed to wake the computer, as described in the linked instructions [#12368759] After identifying and disabling the offending wake source, the sleep problem should stop [#12373490]
  • #1 12349686
    kcpr11
    Rate: 24
    As the topic. I click "sleep" after about 20 seconds it goes to sleep and for about 5 seconds it is turned off and then it restarts itself.
    Motherboard - ASRock P67 Pro 3 B3
    Power supply - OCZ ModXStram 700W
    Processor - I5 2500k
  • #2 12363053
    kcpr11
    Rate: 24
    Nobody can help?
  • #3 12363581
    lapaska098
    In my opinion you have something with the system.
    I had the same with the phone and it was enough to give "factory settings" there.
    You probably need to upload a new system to your computer ..
  • #4 12363654
    niebieski55
    Help: 34
    Rate: 81
    I think you will find a solution in this topic :arrow: Link
  • #5 12363686
    kcpr11
    Rate: 24
    I will not even write how nonsensical this comment is ... If you have no idea what a computer is, let it go ...
  • #6 12365642
    marcin1301993
    Rate: 14
    In the BIOS settings there is something like "wake up on ring" or similar things, they are related to "waking up" the computer remotely, eg via the net. Try to disable all of these types of options.
  • #7 12365738
    trotyl84
    I assume there are some windows here
    In XP, you would click it in turn:
    Control Panel / Power Options Advanced tab there you have the power buttons :D
    and here you have options to choose from and you can swap.
    Still goes in the registry, but I do not recommend. Easy to sprinkle
  • #8 12365767
    PeteSh
    Level 30  
    Help: 95
    Rate: 71
    Let's wait for the thread's author to reply to the above post.
  • #9 12365933
    kcpr11
    Rate: 24
    Still goes in the registry but I do not recommend Easy to sprinkle
    There is nothing to do with it here. Only here you can set whether the device should operate in the mode of maximum efficiency or energy saving ...
  • #10 12368759
    marcin1301993
    Rate: 14
    Dear kcpr11, did you follow the advice in the link you got from the user blue55? There you have, from post 6, what to do to find devices or anything that can "wake up" the computer. Take it, do it, and it will work.
  • #11 12373490
    kcpr11
    Rate: 24
    I have already succeeded. It's a bad network card. Thanks for the help. Subject to be closed.
The discussion revolves around a sleep mode issue experienced with an ASRock P67 Pro 3 B3 motherboard, OCZ ModXStream 700W power supply, and Intel i5 2500k CPU. The user reports that the system goes to sleep but then restarts after a few seconds. Responses suggest checking BIOS settings for options like "wake on ring," adjusting power settings in the operating system, and investigating potential hardware issues. Ultimately, the user identifies a faulty network card as the cause of the problem, resolving the issue with assistance from the forum.
