VW Polo 2006 1.4 75 hp – 210 mA battery drain, what to check?
jurashks 66093 16
What is causing the battery drain in a 2006 VW Polo 1.4 75 hp, if the current draw drops when fuse 30 is removed and fuse 51 is the radio?
Fuse 30 powers the onboard electrical system control unit (bordnetz/central electronics), not the automatic transmission, so that module is the main suspect for the parasitic draw [#12356969] [#12356808] If the current drops after locking the car or interrupting power to that module, it suggests the bordnetz is not going to sleep correctly [#12357060] [#15854715] One reply notes that in similar Polo 9N cases the cabin power supply/bordnetz was responsible, and the current returned to normal after locking the car; a re-encoding or replacement of that module may be needed [#15854715] Another suggestion is to scan the comfort/central electronics/central locking modules (09, 46, 35) for faults related to central locking or door controllers [#17590892] The radio on fuse 51 is also a possible smaller contributor, but the bigger draw reported here points to the onboard supply module [#12356969] [#15854657]
  • #1 12356154
    jurashks
    Rate: 8
    Hello, I have a problem as I wrote above. I measured the current with the engine off and the meter showed me 210 mA. I found that it consumes too much electricity and I decided to disconnect the fuses one by one, the effect was that the most was on fuse no. 30 100mA and on b. No. 51 60mA. 51 fuse is a radio. On the other hand, the 30th fuse is supposed to be an automatic transmission, but I have no idea what it is. Here are the links to the list.
  • #2 12356808
    Siekier81
    Help: 9
    Rate: 175
    In polowki, the electric driver is often selected by the interior driver (bordtnez). I have already had two such cases and I have heard a few already. This is probably the problem of these cars.
  • #3 12356853
    bart.auto
    Help: 14
    Rate: 246
    Well, check out what is hanging on this circuit and you have the topic solved
  • #4 12356930
    jurashks
    Rate: 8
    Is it possible to somehow check that this driver is damaged?
    Today I disconnected the fuse no. 30 and while starting it, I noticed that the battery charging indicator did not come on, and it started to glow (a pillow error appeared), but the car was working normally at idle.
  • #5 12356948
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    The trunk lighting is not lit all the time by accident?
  • #6 12356969
    bart.auto
    Help: 14
    Rate: 246
    Fuse # 30 is the power supply control unit of the on-board system
    It does not crate the vending machine wrong description
  • #7 12357060
    Siekier81
    Help: 9
    Rate: 175
    I managed this way that I installed the relay on the bortnose power supply and the relay control from the central lock. When you close the car, you disconnect the bortnes for a moment. If the power supply is interrupted for a moment, it no longer consumes electricity. Unfortunately, I could not determine what is causing the current consumption through this module
  • #8 12360403
    jurashks
    Rate: 8
    The lamp in the trunk is definitely off. Rather, it has to be this interior driver (bordtnez). I will try to solve this problem somehow, if I manage, it will write what I did.
  • #9 15854517
    MM2X
    Rate: 618
    I have a similar problem [Polo 9N3], the battery idling current is approx. 130mA, after
    safety disconnection No. "30" drops to 70 mA. If I am not mistaken it should be within 30mA.
    Has anyone managed to solve this problem ?.
  • #10 15854657
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    In my Polo, the thief is a radio from China. Standby consumption 90 mA. Somehow "goes to live with it", I periodically recharge the battery.
  • #11 15854715
    ...KUBA...
    Help: 65
    Rate: 316
    I also had a similar problem after replacing the battery, due to the fact that it was old and in winter it was "hard to spin". After installing a new battery, the car started to draw electricity. I approached this topic several times .. I disconnected the "large" fuses next to the battery one by one, and it turned out that the current was pulling the power supply to the cabin. I changed the bordnetz from a neighbor, I ordered it on the Allegro with the same encoding, but with some measurements it turned out that after locking the car with the central lock, the current after a while drops to normal standby consumption .. from what I read, getaway polo 9n is to blame, you need it re-encode, but I stayed with the old solution ..
  • #12 15855080
    MM2X
    Rate: 618
    Massacre, the radio is only in the state of rest to maintain the memory and so much ...
    ...KUBA... wrote:
    After installing a new battery, the car began to draw electricity.
    I also have a new battery.
    ...KUBA... wrote:
    and it turned out that the current was pulling power to the cabin.
    Me too.
    ...KUBA... wrote:
    from what I read, getaway polo 9n is to blame, it has to be re-encoded
    I do not really understand :(
    I have 130mA and nothing less ....
  • #13 17578494
    Katani5
    Rate: 14
    I have the same problem. Anyone know what the reason is that it consumes electricity with fuse no. 30 inserted ???
  • #14 17590892
    ...KUBA...
    Help: 65
    Rate: 316
    Do you have access to do diagnostics and read errors? Scan all modules and check if there are no errors related to the central locking, they can be in modules:
    09 - Central electronics - central electric unit
    46 - Central convenience - comfort module
    35 - Central locks - central locking
    or individual door controllers.
  • #15 17590989
    Katani5
    Rate: 14
    The car does not have a central locking. And when it comes to errors, there are only 2 with which I have been driving for over a year: too rich fuel mixture and something related to the catalytic converter.
  • #16 17592978
    Hektar Zahler
    Help: 230
    Rate: 528
    And you still can't properly check the so-called sleep despite prompting - Link .
  • #17 17593032
    Katani5
    Rate: 14
    I did as you wrote earlier.
The discussion revolves around a battery discharge issue in a 2006 VW Polo 1.4 (75 hp). The user measured a current draw of 210 mA with the engine off, identifying fuse #30 (100 mA) and fuse #51 (60 mA, related to the radio) as significant contributors to the drain. Suggestions include checking the interior driver (bordnetz) for faults, as it is a common issue in these vehicles. Other users shared similar experiences, noting that the radio and central locking systems could also be culprits. Diagnostics and error checks on central electronics modules were recommended to identify potential faults. The user plans to investigate the interior driver further and will report back on any findings.
