[Solved] Skoda Octavia II - Power consumption 0.63A discharges my new battery
mateusz1065 40620 17
Why does my Skoda Octavia II keep drawing about 0.63 A after the car goes to sleep, and how can I find the source of the battery drain?
The drain was caused by the radio, because the car was not going to sleep properly; after fitting the module and uploading the program, everything returned to normal [#17355798] Before that, the key suspicion was the aftermarket/changed radio and possible CAN gateway coding mismatch, especially if the unit was swapped from a navigation radio to another version [#17347301][#17347327] The advice was to measure the current only after the car really sleeps, not just a couple of minutes after closing it, because modules and the radio need time to shut down [#16980221][#16981824] There was also concern that something non-original was connected to the battery/installation, such as the CB radio or added wiring, which could keep the current high [#16980192][#16980200] So the practical fix is to check the radio wiring/coding and any added devices, and if needed use the proper module/programming so the Octavia can enter sleep mode [#17347301][#17347327][#17355798]
  • #1 16979948
    mateusz1065
    Rate: 17
    Hi, I have a problem with octavia 2 for some time it takes me electricity and discharges the battery after checking the meter set to 20A showed 0.63A on all fuses:
    After pulling out everyone showed 0.37A and I put it in turn and it turned out that:
    Fuse 12 consumes 0.6A
    Fuse 15 takes 0.18A
    Fuse 23 draws 0.5A
    The fuse 24 takes 0.3 A
    it's strange because after pulling out all of them comes out 0.37 and after adding those that get 0.69A out and 0.63A on the meter
    where can it download these 0.37A (and maybe someone predicts where the faults are from these fuses (I will add that the lock closes and opens everything without a problem the glass works well also I can check the lights and the lighter have a radio CB
    And maybe here he gets those 0.37A (can these fuses also be checked?
    Skoda Octavia II - Power consumption 0.63A discharges my new battery Skoda Octavia II - Power consumption 0.63A discharges my new battery
    maybe someone has a diagram for these relays and fuses?
  • #2 16979967
    spinacz
    Help: 1204
    Rate: 2648
    Oh, my friend, a meter on the 20A range shows 63A, you better not touch the car before you blow something up.
    Do you have any idea what kind of current is your "63A"?
    There is no chance for such a current, if it is already 6.3A.
  • #3 16980005
    mateusz1065
    Rate: 17
    I think that this portal is from helping each other and not making fun of mistakes
  • #4 16980023
    spinacz
    Help: 1204
    Rate: 2648
    Well now tell me how much it takes as soon as the car is asleep.
  • #5 16980192
    lukasrsv
    Help: 41
    Rate: 164
    Do not have any devices / circuits connected to the "left" to the battery pole?
  • #6 16980200
    spinacz
    Help: 1204
    Rate: 2648
    After all, the photo already shows that it has something attached after the original installation.
    The first measurement of current on a dormant car.
  • #7 16980208
    lukasrsv
    Help: 41
    Rate: 164
    After this, after reconnecting the power supply, you need to wait until the current drops to a state where all capacitors in electronics etc. will be charged.
  • #8 16980221
    spinacz
    Help: 1204
    Rate: 2648
    lukasrsv wrote:
    wait until the current drops to the state where all the capacitors charge
    What ???
    Do you know how long it takes to charge the capacitor? What are you writing for nonsense.
    Wait for you after closing the car until sleep modules, for example, the door, radio only then you have the quiescent current of the car and all components know that the car is closed and they do not take electricity.
    Did you mention a radio or was something done that the battery started to discharge?
  • #9 16980306
    lukasrsv
    Help: 41
    Rate: 164
    With these capacitors it was so metaphorical so do not get out. :)
  • #10 16980476
    Ireneo
    Help: 746
    Rate: 2461
    This is not a portal for metaphors. The author can also check the errors. Once, as he suggested, under the hood. Let them write how much he waits.
  • #11 16981824
    mateusz1065
    Rate: 17
    so on sleep, or after a few minutes, it shows 0.63A on the 20A range
    rather, only an alarm when it comes to these two very thin cables connected to the strip
    Added after 4 [minutes]:
    spinacz wrote:
    What ???
    yes for every time I waited for the car to sleep for about 2 minutes and then it fell to 0.63A only CB radio was plugged in, but it's been a long time and no problem was not
    it's about those fuses under the hood?
    and after closing the door I wait about 2min until the current drops and then it shows 0.63A
  • #12 16981860
    yogi009
    Help: 848
    Rate: 2650
    Mateusz, come on better to some kumaty electrician, let him do it. Do not be offended, but as I read these substantive statements, I come to the conclusion that you will damage yourself by plucking up the installation. And you probably would not want a fire ...
  • #13 17347278
    pompon78
    Rate: 10
    I repeat the topic because I suggested what he wrote a paperclip ... after exchanging the radio in my skin unloads my aku to me and I have a problem with firing in the morning..is it possible? electrician said that it is the main computer. the magician said that it is everything is connected and puts on the radio .... let's see in the morning ... unless someone has some idea
  • #14 17347301
    spinacz
    Help: 1204
    Rate: 2648
    The radio you exchanged for? Not sometimes serial to newer serial np from navi? Maybe the car does not fall asleep, and here's the problem, maybe the CAN gate is too old for the new radio if it's serial.
  • #15 17347321
    pompon78
    Rate: 10
    The radio is inserted with a large display..which to the model is how to bring from the mechanic I will give it ... I change from before it was navi radio and the guest changed before selling for me for the same but without navigation..and from that began to problems with ac
    And if it's too old for a new radio, can you do something about it?
  • #16 17347327
    spinacz
    Help: 1204
    Rate: 2648
    And it is possible that the problem is only a badly coded gate.
  • #17 17347340
    pompon78
    Rate: 10
    inserting some module as mechanic stated will solve the problem ... and they said a nice car take it ...
  • #18 17355798
    pompon78
    Rate: 10
    Hello again..prąd escaped because the radio was taking .. after inserting the module and uploading the program everything returned to normal ..
✨ The discussion revolves around a power consumption issue in a Skoda Octavia II, where the user reports a battery discharge problem with a measured current draw of 0.63A when the vehicle is in sleep mode. Various fuses were tested, revealing significant current draws from specific fuses (Fuse 12: 0.6A, Fuse 15: 0.18A, Fuse 23: 0.5A, Fuse 24: 0.3A). Participants suggest checking for additional devices connected to the battery and emphasize the importance of allowing the car to enter sleep mode before measuring current. A follow-up reveals that the problem may be linked to a recently installed radio, which could be causing excessive power draw. Solutions discussed include consulting an electrician and ensuring proper coding of the vehicle's systems to accommodate the new radio.
TL;DR: A 6.3A draw can roast a battery fast; “a meter on the 20A range shows 63A” is a misread—measure correctly first. [Elektroda, spinacz, post #16979967]
Why it matters: This FAQ helps Skoda Octavia II owners diagnose and fix parasitic drain, especially after radio or alarm changes.
Why is my Octavia II battery draining with 0.63A draw?
A 0.63A quiescent draw is excessive. The thread cases point to awake modules, aftermarket alarm/CB wiring, or radio retrofit issues. Start by confirming the current once the car is fully asleep, then isolate using fuses. Focus on circuits showing measurable draw, like fuses 12, 15, 23, and 24 in the case data. [Elektroda, mateusz1065, post #16979948]
How do I measure parasitic draw correctly on a dormant car?
Close doors, lock the car, and wait for sleep. As one expert put it, “The first measurement of current on a dormant car.” Use a series ammeter at the battery negative, without waking modules. If you reconnect power, allow the current to settle before reading. [Elektroda, spinacz, post #16980200]
Which fuses should I check first for unexpected current?
Use data from the case: fuse 12 showed 0.6A, fuse 23 0.5A, fuse 24 0.3A, and fuse 15 0.18A. Pull and replace one at a time to see which circuit drops the draw. Log each change to identify the guilty circuit. [Elektroda, mateusz1065, post #16979948]
Could aftermarket alarms or a CB radio cause battery drain?
Yes. The OP’s car had thin alarm wires on the battery strip and a CB radio. Such add-ons can keep modules awake or add constant loads. Temporarily disconnect non‑OEM devices to test. If current drops, rewire through ignition-switched power or use proper CAN‑aware interfaces. [Elektroda, mateusz1065, post #16981824]
My car shows 0.63A after 2 minutes. Should I wait longer?
Yes. Two minutes may be too short for all modules to sleep. Wait until current stabilizes at its lowest value before diagnosing. Avoid opening doors or waking the network during tests, or the reading becomes invalid. [Elektroda, spinacz, post #16980221]
I changed the radio and now the battery dies. Is the radio the culprit?
Likely. A newer head unit can prevent sleep if the CAN gateway is incompatible or coding is wrong. One case improved after fitting a module and programming. A specialist can code the gateway or add the correct interface. [Elektroda, pompon78, post #17355798]
What is a CAN bus and CAN gateway on the Octavia II?
CAN bus is the car’s data network linking modules. The CAN gateway routes messages and controls sleep. If the gateway is older than a retrofitted radio, the radio can keep the network awake, causing drain. [Elektroda, spinacz, post #17347301]
Do I need coding after a radio retrofit?
Often, yes. A “badly coded gate” can keep the car awake. Proper coding aligns the gateway and radio so the network sleeps when locked. Ask a VAG specialist to scan, code, and verify sleep status. [Elektroda, spinacz, post #17347327]
What fixed a confirmed Octavia II parasitic draw in this thread?
A user resolved the drain by inserting a module and uploading the correct program for the retrofitted radio. After that, the battery stopped discharging overnight. [Elektroda, pompon78, post #17355798]
Is reading 63A on the 20A meter range possible here?
No. That’s a misinterpretation. As the expert warned, “a meter on the 20A range shows 63A” is wrong; expect values like 6.3A or lower. Confirm your meter range and decimal placement. [Elektroda, spinacz, post #16979967]
How long should I wait after reconnecting the battery before trusting the reading?
Wait until current falls to the steady, low “sleep” value. Immediate readings reflect wake‑up activity. Measure only after modules sleep, per expert guidance. [Elektroda, spinacz, post #16980200]
Can a mechanic code the gateway to fix drain after a radio change?
Yes. The advisor noted the problem can be a “badly coded gate.” Correct coding or an interface module can restore proper sleep behavior and stop the drain. [Elektroda, spinacz, post #17347327]
Any quick 3‑step method to isolate the parasitic circuit?
  1. Measure quiescent current after the car sleeps.
  2. Pull one fuse at a time; note current change.
  3. Identify the circuit with the largest drop and inspect devices on it. [Elektroda, mateusz1065, post #16979948]
Should I inspect under‑hood relays or only cabin fuses?
Check both. The OP asked about under‑hood fuses, and add‑ons often connect at the battery. Inspect any non‑OEM leads first, then proceed to fuse isolation. [Elektroda, mateusz1065, post #16981824]
When should I stop and call an auto electrician?
If readings are unclear, wiring looks modified, or you’re unsure how to measure safely, seek help. One member warned that incorrect testing risks damage or fire. Safety and correct diagnosis come first. [Elektroda, yogi009, post #16981860]
What’s an example of an edge case that keeps current high?
A newer OEM radio on an older CAN gateway can prevent network sleep. The fix may require adding a compatibility module and programming, not just pulling fuses. [Elektroda, pompon78, post #17355798]
