VW Passat B6 1.9TDI (2005) - Suitable Synthetic Oil Options & VW 507 00 Standard Compliance
seat88 85191 10
What engine oil should I use in a 2005 VW Passat B6 1.9 TDI with 230,000 km, and is VW 507 00 5W-30 oil like Castrol EDGE suitable even if I’m not sure whether it has a DPF?
Yes—according to the thread, a VW 507 00-compliant 5W-30 oil is the right choice for this car [#12367845] One reply says the B6 likely already uses VW 506.01/507.00 standards, and gives examples such as Motul Specific 504 00 507 00 5W-30 or Motul 8100 X-clean+ 5W-30 [#12367845] Another user says to check what oil was used at the last service and mentions that Mobil 5W-30 or Castrol are commonly used at the dealership [#12366415] A later reply says the car does not yet have a diesel particulate filter and adds that if semi-synthetic oil was used before, you should not simply switch to synthetic oil [#12367869]
  • #1 12366291
    seat88
    Rate: 11
    Hello. What oil to pour into VW Passat B6 from 2005 1.9TDI mileage 230 thousand.
    I called the VW service and they said that they were pouring synthetics, even for cars with a mileage of 400,000. The question remains, which synthetics to choose?
    A service visitor said that it must meet the VW 507 00 standard.
    Castrol EDGE 5W-30 FST meets this standard (I have already bought this oil but haven't poured it yet. A friend from the store called his friend from the VW showroom and recommended this oil as well). Will he be good, what do you think? Any of you running on this oil? I will say right away that I do not know if my "belt" has a diesel particulate filter, but I read in one forum that this oil is also suitable for cars without a DPF filter (and with PDF).
    Please tell me, did I choose the right oil?
    :idea:
  • #2 12366415
    Vissox
    Rate: 29
    He works at a VW Dealership so it's best to check what oil was poured into you last time. I usually use Mobila 5w-30 or Castrola at work, and this is your choice :P
  • #3 12366473
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    Hello, motul specific 505.01 5w40 is poured into the TDi - it is an oil specially designed for these engines.
  • #4 12367378
    manta
    Help: 463
    Rate: 1533
    psilos1 wrote:
    motul specific 505.01 5w40-it is an oil specially formulated for these engines
    Now present the vw standards approving this oil and justifying your statement.
    I am waiting.
  • #5 12367542
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    MOTUL SPECIFIC VW 505.01 5W-40
    Standards: ACEA A3 / B3 - API SJ / CF
    Approvals: VW 505.01 - VW 500.00 - VW 505.00
  • #6 12367845
    turpik5
    Help: 19
    Rate: 105
    5w40 is an oil for TDI PD but b6 probably already has the 506.01 standard, i.e. longlife or 507, i.e. with DPF and the oil that meets this standard is 5w30 in the Motul specification, for example Motul Specific 504 00 507 00 5W30 or Motul 8100 X-clean + 5W30
  • #7 12367869
    radkovski79
    you don't have a diesel particulate filter yet - thankfully ;) - as for the oil, if, for example, a semi-synthetic was poured in, you should not add a synthetic one. By the way, you've got the last good VW diesel :)
  • #8 12368365
    krocze
    Help: 24
    Rate: 149
    radkovski79 wrote:
    if, for example, a semi-synthetic was poured in, then you shouldn't pour in a synthetic one.
    You can go ahead and pour it, for example after making a rinse or without it.
  • #9 12368722
    seat88
    Rate: 11
    Thanks for the professional replies! So it's pouring this Castrol!
    I greet you :!:
  • #10 12368739
    manta
    Help: 463
    Rate: 1533
    And everyone else that meets this specification, not just a motorcycle.
  • #11 20655685
    kpsolowski
    Good morning. I have a question. Since 2015 I have been using 5w30 oil. A year ago, the mechanic changed the oil in the Passat b6 2.0 TDI to 10w40 oil. Can you go back to 5w30 oil?
The discussion centers around suitable synthetic oil options for a 2005 VW Passat B6 1.9TDI with 230,000 miles. The user inquires about the appropriate oil, noting that VW service recommends synthetic oils even for high-mileage vehicles. Castrol EDGE 5W-30 FST is mentioned as a compliant option with the VW 507 00 standard. Responses suggest various alternatives, including Motul Specific 505.01 5W-40 and Motul Specific 504 00 507 00 5W30, which are also compliant with VW standards. It is confirmed that the vehicle likely does not have a diesel particulate filter (DPF), allowing for flexibility in oil choice. The user expresses gratitude for the advice and decides to proceed with the Castrol oil.
