Passat B5 116KM 99: Oil Presence in Intercooler Lines - Impact on Turbine Efficiency & Renovation
benio82 125416 14
Is a small amount of oil in the intercooler hoses of a Passat B5 normal, or does it mean the turbo needs immediate repair?
A slight oily film in the intercooler/intake hoses is usually normal, but the system should still be airtight because leaks cause dust ingress and boost loss [#4964866] If the residue is only a light, sweaty trace that wipes off like dust, there is no reason to panic or overhaul the turbo yet [#4969199][#4986307] If oil actually collects in the intercooler or leaves drops on the floor after parking, that points to a turbo that is leaking oil, and it is better to repair or replace it than keep driving on a worn unit [#4972566][#4987759] A healthy turbo with a free crankcase breather should leave the intake system dry and clean, so checking the breather/valve-cover vent tube is also worthwhile [#4977998][#4987759]
  • #1 4964719
    benio82
    Rate: 26
    I have a passat b5 116KM 99. I have a question about the presence of oil in the intercooler. Should it be there? I heard that if it is not a clear amount, it is not a problem. does it also require immediate renovation and does it have any impact on the turbine's efficiency? I noticed that there was dust or sand, rather dust with oil, it worried me. I will add that I have no problems with the engine, I know that the turbine is on the "descent" but the engine still has power (5 people 190 km / h but it was not the end of it yet possibilities in addition is a station wagon) it does not smoke in black or gray blue-well, maybe slightly, but it's a negligible amount, please give feedback-advice!
  • #2 4964866
    marcys20
    Help: 21
    Rate: 49
    well, theoretically, the whole system should be without oil, but in practice it is impossible, for example due to odor or oil vapors getting through the turbine seals ...
    in any case the system must be tight! each insensitivity is dust in the inlet and pressure losses in recharging!
    ps. The fallen turbine pours oil in most cases, but it does not cause a drop in power - unless the blades are broken :-)
  • #3 4965839
    benio82
    Rate: 26
    ok! thanks for the opinion and advice. looks like I'll have to disarm the front again :(
  • #4 4969199
    p1212
    Rate: 38
    a small amount of oil is normal, I would not touch a small hole in the IC, you can try to patch up with poxipol or other strong glue I would not panic with turbawa and if I do not take the oil engine, I would not bury anything :D
  • #5 4969968
    gutman2005
    Rate: 27
    Turbine pouring is standard, if I do not "take" a dose of oil, I would recommend driving
  • #6 4970073
    benio82
    Rate: 26
    with this disarming, I meant the intercooler itself, otherwise it is impossible to get it out of there?
  • #7 4970153
    p1212
    Rate: 38
    you take off the bumper and you have access
  • #8 4972566
    Apsik
    The intercooler is made of aluminum and the small hole can be nicely soldered :)
    And if there is so much oil that after leaving the car for 8-10 hours, you have a few drops on the floor, such spills are not from pneumothorax, but the turbo is pouring.
    I do not recommend riding on a "incident" turbine, because it can do more harm than save some money ... the rotor is not balanced and has more and more vibrations.
    I had a similar action with the GT20 at home and I replaced it immediately - as it turned out, the rotor had 3mm of play already: /
    As for the intake system itself, if someone has a free pneumothorax and a healthy turbo, the system is 100% dry and clean - that's what I had at home until the first piece started to end :) now it is true that the 2nd GT20 is already sitting, but I did not clean the system.
  • #9 4972688
    benio82
    Rate: 26
    As for the amount of oil, so far I can not say anything because, first of all, I have the car for a short time, about 2 months, the oil level was checked the day after the purchase and it was below the minimum level, of course, immediately replaced with the filter. on the website it turned out that the lower engine salt is screwed to the metal intercooler pipe !!!!!!!!!!!!!!! when replacing the timing, I welded everything up. after the amount of oil on the cover, it's hard for me to say how much it has been and is decreasing, while when changing the oil, the guy poured me a little bit of oil too much, about 150-250 ml, so it's like you don't know the amount of oil (I didn't know then either) but myself the engine will deal with such quantity. now it is max and I will start to monitor the level with mileage
  • #10 4977998
    Mariusz Z.
    Level 19  
    Help: 16
    Rate: 79
    I think you have an AJM engine and in these engines there is often a problem with "releasing". Download the pneumothorax and check if there is oil there. It is the tube that extends from the left-front corner of the valve cover facing the engine. Give an answer and then I will tell you what to do next.
  • #11 4978531
    benio82
    Rate: 26
    ok, tomorrow I will look there and write it as it is. :-)
  • #12 4981668
    benio82
    Rate: 26
    hello! i took this wire off and there are traces of oil in there. any suggestions?
  • #13 4983560
    Mariusz Z.
    Level 19  
    Help: 16
    Rate: 79
    Was it a bit sweaty there or was the oil standing there, because it's a big difference?
  • #14 4986307
    benio82
    Rate: 26
    rather slightly sweaty, I wiped the inside with a rag and it was soiled as if I had wiped the dust! that was the amount of this oil, i.e. traces of it (on a cold engine). but write if you can answer the second option and if you can, I will know for the future.
  • #15 4987759
    Mariusz Z.
    Level 19  
    Help: 16
    Rate: 79
    Well, it's not the pneumothorax's fault. It turns out, however, that the turbine is letting go. I used to have a pouring edema. I dismantled the valve cover and there is something like a bulkhead with round holes through which the gases come out. This bulkhead did not fit tightly with its sides to the walls of the cover and along these walls the oil flowed into the emphysema. I sealed the contact areas with silicone and the oil is gone. :D
The discussion revolves around the presence of oil in the intercooler lines of a 1999 Passat B5 with a 116KM engine. Participants note that while a small amount of oil is normal due to turbine seal leakage, excessive oil could indicate a problem that may affect turbine efficiency. Recommendations include checking for leaks, particularly in the pneumothorax, and ensuring the intercooler is sealed properly. Some users suggest that minor oil presence does not necessitate immediate renovation, while others caution against driving with a failing turbine due to potential damage. The importance of monitoring oil levels and addressing any significant leaks is emphasized.
