Passat B6 2.0 TDI 170km 2007: Glow Plugs, Engine Lights On & Engine Fault Workshop Message
AnjaZab 14385 5
  • #1 17196588
    AnjaZab
    Hello. I have a problem with the passat b6 2.0 tdi 170km 2007 namely: glow plugs and engine lights are lit and the message Engine Fault Workshop is showing! The glow plug indicator goes out with the message when moving off but appears when driving for a moment and disappears again, accompanied by a sound signal and how would the car lose power. Engine indicator light stays on. Pump injection exchanged in 2013 on the website. Thanks for the help in advance.
    • Passat B6 2.0 TDI 170km 2007: Glow Plugs, Engine Lights On & Engine Fault Workshop Message A4C5BB02-A8DB-4A9A-806D-1B0AB3CAAC2E.jpeg (1.71 MB) You must be logged in to download this attachment.
    Staszek49
    Help: 228
    Rate: 1139
    The indicator light (engine) e.g. in Peugeot 1.6 hdi causes a slightly different engine operation. Fault in my case regarding the EGR valve: disturbed combustion, not enough air or a lot of fuel. If cleaning the electrically-controlled EGR does not help, then the exchange awaits me, of course, as in 308 it is terrible access. I add that the indicator itself went out and turned on, and the display showed an English message and a sound signal.
    In your case, the first fault may also apply to EGR. The glow plug control on VW cars is usually multifunctional and can signal one of several faults, so it's best to get help from someone who has a computer with the right program.
  • #3 17196639
    AnjaZab
    EGR can be cleaned by yourself?
    kowal5
    Help: 25
    Rate: 69
    First, start with diagnostics using a diagnostic computer. This indicator can light up for many reasons. Do not undress or replace anything in the dark because you can only do unnecessary work and unnecessary costs.
    kortyleski
    Help: 957
    Rate: 3847
    The error code table for this engine is one hundred items. Each error lights up the MIL. So giving opinions that it's egr or Turbo or other trouble is shooting in the dark. Connect the interface and you'll know a lot
  • #6 17199028
    AnjaZab
    I went to a mechanic today and this is a mistake.
    • Passat B6 2.0 TDI 170km 2007: Glow Plugs, Engine Lights On & Engine Fault Workshop Message 3A517CBC-5124-4BD1-9E66-21FBAA79EB37.jpeg (1.29 MB) You must be logged in to download this attachment.
