Determining Correct Wire Cross-Section for 12V 10A, 2 Meter Installation
arturmt26 42849 5
  • #1 12394474
    arturmt26
    The subject of the post is the question: what wire cross-section should be for a 12V 10A installation, 2 meters long.
    Thank you for your help.
    Sołtys_Elbląga
    Help: 113
    Rate: 564
    If you give 1.5 mm it will be perfect.
    ladamaniac
    Level 40  
    Help: 721
    Rate: 2065
    Continuous or instantaneous load, wire loose or bundled? 4 to 6 A per 1 mm? is assumed. I would recommend 2.5mm?, since this length will not add up to much of the cost.
  • #4 12394794
    Quarz
    Help: 1646
    Rate: 629
    If it is a copper wire, it will have a voltage drop of almost 0.5V (from the source to the receiver):
    ?U = (2 o 2m / (56 (m / (? o mm? ;) ) o 1.5mm? ;) ) o 10A = 0.476190 ... V
    ignoring the power losses in such a 'conductor'.
  • #5 12394800
    arturmt26
    Rather continuous work for me - two hours of work followed by an hour of break and the cycle repeats itself all over again. Free-lying cable.
    Quarz
    Help: 1646
    Rate: 629
    arturmt26 wrote:
    [p] P. rather continuous flare because as for [space] I have two hours of work, then an hour of break, and the cycle repeats itself. Free-lying cable.
    Look up...
