Excel VLOOKUP Issue: Fixing #N/A Error, Converting Text to Numbers & Displaying Searched Values
adamza 10551 4
  • #1 12415834
    adamza
    Rate: 8
    Can someone explain to me what is wrong with this VLOOKUP ??
    I tried to convert the text to a number but it crashes me some nonsense, i.e. the values do not match. Please explain what I am doing wrong so that I know for the future :) Moreover, the function does not display the searched value
    Thanks
    • vlookup.xls (89.5 KB) You must be logged in to download this attachment.
  • #2 12415864
    cbrman
    Help: 177
    Rate: 61
    Actually, it works fine because VLOOKUP looks up the values in the column on law from the searched column, in your case you need to use INDEX from MATCH / MATCH
    =INDEKS($A$1:$B$875;PODAJ.POZYCJĘ(F2;$B$1:$B$875;0);1)
  • #3 12415908
    adamza
    Rate: 8
    Why not VLOOKUP ????
    please clarify the topic, I like to use VLOOKUP and I do not understand why it does not work because it should compare the tables and give the result
    adamas_nt
    Help: 1508
    Rate: 659
    cbrman wrote:
    because VLOOKUP looks up the values in the column to the right
    and that's it ... More precisely: it searches the leftmost one.
    Swap the columns and it will work ...
  • #5 12415971
    adamza
    Rate: 8
    Thanks a lot. :)
