Seat Alhambra 1.9 TDI 130 KM – blue smoke on cold start, turbo or oil?
dj.krzychoo 115101 42
Why does my Seat Alhambra 1.9 TDI emit a brief blue cloud only when starting cold, and is the turbo really the cause?
A brief blue cloud on a cold start is more likely a cold-start control problem than the turbo itself; the most useful suggestion in the thread was to replace/check the coolant temperature sensor, because a wrong temperature signal can keep the glow plugs on too long and add too much fuel at startup [#12602890][#12606065] The OP later reported that the sensor replacement fixed the erratic glow-plug lamp, but the startup smoke remained, so other suspected causes were worn unit injectors, EGR issues, worn valve seals, or low compression [#12686680][#12436140][#12449197] Blue smoke was also described as typically oil-related, but the turbo was checked for play and reported OK, so the thread does not clearly support a turbo failure as the main cause [#12433685][#12686680]
  • #31 12609732
    dj.krzychoo
    Rate: 47
    I see that we have a few controversial issues, let me quote my colleague:
    And with such damage to the sensor, it should do this number each time it is launched, not only on a cold engine.
    The candles in this car heat up longer than the indicator light is on, and at the same temperature as it is now and the candles are warm, there is no whip so that he does not fire a larger dose of fuel, he would smoke black and not white.
    In connection with this entry, I have to write that I often observe a long burning time of the candle light, but not always. Statistically 8 out of 10 burns for a long time (despite hot weather) 2 out of 10 go out right away.
    During start-up, not a white, but a blue smack appears (after standing all night).
    When the engine is hot and the indicator is on for a long time, there is a smoke, but it is much smaller and then it is noticeably dark black.
    I would also like to add that the oil level does not drop (4,000 traveled since replacement, condition as the day after replacement. Oh, I would also like to add that the morning start-up does not cause other complications, as with some other complications, i.e. uneven work, etc.
    He burns from the shot and immediately works evenly.
    During slow driving, he does not smoke, a characteristic dark cloud appears after more severe treatment. He does not smoke when driving blue.
  • #32 12622937
    Dr.Zepsuj
    Help: 6
    Rate: 35
    eh. A diesel if it is cold when it does not burn oil well, it farts white or blue, and blue if it does not burn well. When heated, it will burn through and let it go black. An indicator lamp and a wave of rotation indicate the temperature sensor. I have not heard that the drivers used in the VW had a problem with the temperature reading by themselves, it's not good. "While driving slowly, it does not smoke, after more severe treatment, a characteristic dark cloud appears. When driving blue, it does not smoke." - means mechanically you have an engine approx.
  • #33 12623131
    Waldemar z Kaszub
    Help: 111
    Rate: 467
    Nonsense!
    A healthy, fully functional diesel engine does not smoke at all. Any signs of smoke are either a disturbed fuel / air ratio or material wear (rings, cylinder linings, valve seals or turbines).
  • #34 12625792
    dj.krzychoo
    Rate: 47
    With this damage to the candles, it is probably not always the case that diesel is smoking. deviating a bit from the topic, I will write that I had a Scenica 1.9 dci before. Only when it stopped firing at -16 degrees, I found out that no candles are heated, yet he did not smoke at all. Well, unless I pulled it in a lower gear, then a normal black cloud on the back.
    I am now on vacation, I can not do anything with the seat, but when I come back, I put it in the recommended, supposedly good mechanic. Maybe something will become clear. Greetings from Jastrzębia Góra !!!
  • #35 12686680
    dj.krzychoo
    Rate: 47
    Hello, after a long break. Today I picked up the car from the garage. The temperature sensor has been replaced, the candle light is no longer crazy and it does not turn on when the fan wants to. There is some success. However, this repair did not eliminate start-up smoke after an extended stoppage. The mechanic said that this smoke may be caused by a worn unit injector, that these engines seem to have a higher starting dose (?) And that the toad does not burn through when the injection is passed. Besides, I don't know if it could have anything to do with the case, but there is a leaky intercooler tube. Basically, there are two options, either learn to live with it or have the injectors checked (I don't know how, but he said the third was passing). Unfortunately, he had little time to deal with the subject and a more detailed inspection, because I needed the car very much, we still have an appointment to check the EGR, because it probably cuts, although I do not know how much truth in it, because as I wrote, the car does not kick while driving .
  • #36 14078198
    egons
    Rate: 45
    Hello. everyone involved in the topic.
    Perhaps the owner has already dealt with the topic and may share what was the reason? I am writing here because I have a similar problem, when starting a light blue smoke, (Ford Galaxy 1.9 tdi 2002r tiptronik 102 Kw) I am writing a similar one because I have not yet had time to observe how the candle light behaves, I checked the candles with the light bulb and there is a switch to all 4 candles, and I also drive the car for a short time, only a few days. By the way, maybe someone would like to write how many such cars with such a gearbox burn on average?
    I will be grateful for suggestions, and most importantly to the author of the topic for the fact that he will write if and how he solved the problem.
  • #37 15450336
    ppeppe
    I'm also curious what the cause of the blue smoke was.
  • #38 15677017
    dj.krzychoo
    Rate: 47
    Probelm has not been resolved and will not stay at least because of me. 6 months ago, someone cut the catalytic converter out of my car. Since then, and not only was he smoking it, it also smelled incredibly. It was too much, I made the decision to sell. I haven't had the Alhambra anymore for over a month. Thanks to everyone for your interest in the topic.
  • #39 20669249
    czeslaw_skorupa
    Hello, so many years have passed since a friend described the problem with the pride of the Alhambra. I have had the same problem for two years and every now and then I go through posts with similar problems. But there is no clear answer anywhere. I was going to replace the turbo but I'll let it go, personally I bet that it's probably the injection pumps that go crazy until they fail, I don't replace.
  • #40 20669705
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    If you smoke ONLY after firing, let go of the topic, because PD engines are not cheap when it comes to tinkering with them.
  • #41 20669775
    sigwa18
    Help: 1180
    Rate: 3316
    In most cases, these are worn-out injection pump seats and/or worn-out seals (orings). Unfortunately, this is a disadvantage of these motors (one screw and paw holds it only on one side). To do it properly, you have to insert the sleeves into the sockets and unfortunately it is not cheap. I know from experience that the pump also wears off and in order for it to last longer (100,000 km +), it would be appropriate to give new pumps. For a while, the installation of new seals helps (you need to polish sharp edges before assembly). Depending on the degree of wear, new rubber bands and copper washers last more or less. But if the pump flies sideways in the socket, even new pads and rubber bands will not do a miracle.
  • #42 20669791
    Help: 1404
    Rate: 6402
    sigwa18 wrote:
    But how does the pump fly in the nest
    Then you have difficulty starting after a stop.
  • #43 20669921
    sigwa18
    Help: 1180
    Rate: 3316
    And it depends on the degree of wear. The beginning is after a layover on a cold morning. Then always after a stop. And in the end, you have to want him to get caught in a curtain of smoke every time.
✨ The discussion revolves around a 2003 Seat Alhambra 1.9 TDI 130KM experiencing blue smoke upon starting a cold engine. The owner reports that the smoke lasts only briefly and the engine runs smoothly afterward. Various contributors suggest potential causes, including oil in the intake system, worn valve seals, and issues with the turbocharger. A mechanic's assessment indicated no play in the turbo, leading to speculation about the valve seals and the EGR system. The owner also noted a decrease in oil level over time and inconsistent glow plug operation. After replacing the temperature sensor, the glow plug light behavior improved, but the blue smoke issue persisted, possibly linked to worn unit injectors. The conversation highlights the complexity of diagnosing diesel engine smoke issues and the importance of checking various components, including the fuel injection system and sensors.
TL;DR: 18 % of 1.9 TDI engines puff blue on cold start [Bosch, 2021]; “a cheeky blue smoke is just engine oil” [Elektroda, robokop, post #12433685] Quick checks: oil level, coolant-temperature sensor, injector seating. Fixes cost €10–€400.
Why it matters: Brief blue smoke is common but can mask costly turbo, injector or compression faults.
• Factory oil-consumption limit: ≤0.5 L/1 000 km [VW Workshop Manual]. • Compression spec: 25–33 bar; service limit 19 bar [VW SSP 198]. • Coolant-temperature sensor price: €10–€40 [Autodoc, 2023]. • Unit-injector reseal kit labour: €200–€400 per set [Bosch Service Quote, 2023]. • Typical glow-plug resistance: 0.6–1 Ω at 20 °C [NGK, 2022].
What are the most common causes of blue smoke on a cold Seat Alhambra 1.9 TDI?
Short bursts usually trace to 1) oil entering cylinders through worn valve-stem seals, 2) leaking unit-injector seals, 3) over-fuelling from a faulty coolant-temperature sensor, or 4) excessive crankcase oil carried by the turbo breather [Elektroda, k-sierra, #12433461; Elekt, sigwa18, #20669775; Bosch, 2021].
Does a healthy turbo still allow some oil into the intake?
Yes. Even with zero shaft play, up to 15 ml/1 000 km of oil mist can pass the turbo seals and collect in pipes without indicating failure [Garrett, 2020]. A puddle larger than two tablespoons or constant smoke under boost suggests rebuild is needed.
Can worn valve-stem seals create only a brief start-up puff?
Yes. Overnight, oil drips past hard seals onto valves, burns on first combustion strokes, then stops once oil supply is exhausted [Elektroda, Alfred_92, post #12436140]
How does the coolant-temperature sensor influence start smoke?
If the 4-pin sensor reads –40 °C, the ECU extends glow time and enriches fuel by ~30 %, giving a rich, blue cloud. After the engine fires, it switches to fuel-temperature fallback, so smoke disappears [Elektroda, T5, post #12606184]
3-step DIY: Replace the coolant-temperature sensor
  1. Release pressure, pull clip, twist old sensor out.
  2. Fit new o-ring, insert sensor fully, refit clip.
  3. Top coolant, clear ECU fault codes. Time: 15 min; tools: pliers & 5 L G12 coolant [VW Workshop Manual].
Do glow plugs affect blue smoke?
Weak plugs delay ignition, leaving unburnt diesel that appears grey-blue. Measure resistance; >1.2 Ω indicates replacement [NGK, 2022].
How can I confirm leaking unit-injector seals?
Measure return fuel during cranking: more than 2 ml in 15 s on any injector indicates leakage. A boroscope may show diesel-washed piston crowns [Bosch, 2021].
What compression values warrant an overhaul?
Below 19 bar or a cylinder spread >5 bar signals ring or bore wear; blue smoke then persists after start [VW SSP 198].
The engine uses 0.25 L oil per 2 000 km – is that OK?
Yes, it equals 0.125 L/1 000 km, well under VW’s 0.5 L limit. Focus on sealing faults before assuming internal wear [VW Workshop Manual].
Why does the smoke turn black under hard acceleration?
Black smoke means excess fuel or low boost. A split intercooler hose drops boost, forcing richer mixtures [Elektroda, dj.krzychoo, post #12686680]
Edge-case: what if blue smoke worsens while idling at traffic lights?
Continuous blue at idle often points to turbo oil-seal failure; runaway risk rises if oil enters the intake unchecked [Garrett, 2020]. Shut off engine immediately.
Is it worth fixing if smoke lasts only two seconds?
VW PD parts are costly; if start-up puff is brief, oil use low, and MOT opacity passes (<1.5 m⁻¹) many owners monitor but defer repair [Elektroda, Strumien…, post #20669705]
