[Solved] Scenic 2 1.9 dci - Hard Starting in Frost, Smelly Smoke, Glow Plug Wear or Other Causes
prezo1983 7890 5
  • #1 16211297
    prezo1983
    Rate: 47
    Hello. The problem is starting the car at low temperatures. When it starts, after about three attempts, the engine runs erratically and behind the car there is a cloud of smelly smoke for a few seconds. Later it's ok. Could it be a symptom of glow plug wear or look elsewhere?
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    Either there is air in the fuel system or the glow plugs have run out, or maybe the temperature sensor gives information that the engine is warm and the candles do not heat up.
  • #3 16211369
    prezo1983
    Rate: 47
    When a little bit of a vehicle it burns without a problem. The only problem is with longer standstill and low temperature. I drive most of the small sections. New candles put on 4 years ago and driven 50,000 km on them. So far, there has been no problem. It started when the temperature dropped below 5 degrees.
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    As I wrote, check whether the candles are burning and whether they are under voltage. I also had a stage and the O-rings were shrinking under the influence of temperature and he was catching left air. When the candles were changed and how many were driven over does not prove their correct operation. Sometimes new doesn't mean good.
  • #5 16902098
    robi1133
    Check the fuse from heating candles :-)
  • #6 17000577
    prezo1983
    Rate: 47
    Hello. The problem, however, was with the candles. One was operational. After replacing everything ok.
